Thorfun
    36
Thorfun last won the day on October 17 2025
Thorfun had the most liked content!
Personal Information
  • Location
    West Sussex
Thorfun's Achievements
Advanced Member
Advanced Member (5/5)
1.7k
  1. We used 50mm and I think it was fine acoustically. it’s amazing how small 39mm space is for running cables (14.5mm either side of the insulation) depending on the size of the cable you’re not left with much before the boards. So can’t imagine how tight 75mm will be.
  2. I ran 15mm everywhere from my central manifolds. I was just a little worried about flow rate for the 10mm plastic pipe. Option 1 for me. Every tap/outlet has its own pipe. One major benefit is no pressure drop when other outlets are being used and you don’t get scalded or frozen when another tap is used or a toilet flushed!! plus it looks really cool in the plant room for showing off your plumbing prowess. 🤣
  3. We just got back from a holiday and the apartment we stayed in had one of these. thought it was a great idea and something we’re thinking about building. The good thing is the wood beams are far apart so removing the fabric in the winter will still allow the solar gain whereas the tight spaced pergola fins would probably still reduce solar gain in the winter as well.
  4. I fail to see how a drawer will fit. It would have to be a shallow drawer to allow the Pro3 to fit behind? And then accessing the unit could be a faff maybe? We just have a wide double door cupboard that has no shelves to give space for all the plumbing and Quooker units. It does all take up quite a lot of space. sadly I don’t have a photo to hand.
  5. We had plenty of space under our sink to install it without cutting holes in the base! And we have the cube installed there as well. Have you got a particularly deep sink or something?
  6. That’s why I use the loctite. Much easier for us amateurs.
  7. Also check the planning permission as I had time limits on the period work was allowed. E.g. up to 12:30pm on a Saturday.
  8. Financial compensation should the time period overrun? Which it will. There is no penalty for overrunning stated currently.
  9. Just remember that everything takes longer than you think so take the builder’s time estimates with a pinch of salt and negotiate for the worst (and then add some extra time on!)
  10. I’ve not read everything in this thread as I’m too lazy, but our back garden is now where the old bungalow used to be and after the demolition it all got filled in and levelled-ish with clay. Was a dried out baked slab of solid ground that pooled water. I rotavated the clay and added 20 tons of manure which got turned in as well. The covered the lot in 100mm-ish of grade B topsoil and seeded the lot. We now have a nice green lawn that wasn’t waterlogged at all this year during the constant rain so I’m happy! the bit to the right of the house will just have some topsoil put on it and then sown with wildflowers eventually.
  11. We were told we needed two units but I pushed back as I didn’t want to pay for two units and to pay to install two units and to maintain 2 units with filter changes etc. So the M&E company calculated that if we upped the duct size to 92mm we could use one Zehnder 600 which is what we did and I have no complaints at all.
  12. Not sure about anyone else but I built our house for us and couldn’t care less about any future buyers!
  13. we have multiple 5A sockets controlled via Loxone for ambient lighting.
  14. If only there was a way to nicely automate this I’d be on it as we currently use the cheap period on Cosy to heat the DHW for evening showers at 1pm (or PV if the sun is shining) using the ASHP.
  15. I didn’t install a solar diverter for our PV as I figured I’d get a better COP from the ASHP than a 1:1 using a diverter. The ASHP is also run from the PV anyway so, in theory, I believe I’m using less PV to get the tank heated.
