Everything posted by ToughButterCup
Planning officers reports contradict
ToughButterCup replied to Offtopub's topic in Planning Permission
I forgot that @BigBub 😑... thanks -
Welcome. Nothing like starting with a bang eh? To help you we need the following detail: unless you want us merely to speculate ... The Delegated Officers report The Planning Officers original report The Decision Notice. In general terms ( speculation) , it seems - as written - that two officers offered different opinions on same topic. Its what they wrote - and how they phrased it - that's very important. -
Fess up or just crack on (water main)
ToughButterCup replied to flanagaj's topic in General Plumbing
How many joints will there be in the pipe that'd be under the road? 0 ? Forget and carry on ... Several? Suck your teeth for a bit longer..... -
Give us detail... summat to get our teeth into, otherwise we're just guessing - and so not helping as efficiently as we might.
Hello, welcome. My Groundworks truisms. An experienced person and his machine will do it -better- in a tenth of the time it takes you to do it on your own. Buy a digger anyway.
After 8 years I've just about stopped doing that. Much to SWMBO's relief. My 'line' was to say that it should be a criminal offence to leave a digger unused in a field where passers-by can see them. Diggers should either be hidden or in use, and NOT left out in the open to cause distress to needy non-digger owners. Mind you, my mate has a 60 tonner out in a field within sight of the motorway: every time we drive past, Debbie dares me not to look. Fail every time. He won't let me play on it. Wonder why.
Can I Build a Fence or Plant Trees Over Utility Pipes?
ToughButterCup replied to MariaD's topic in Building Regulations
Imagine you had the responsibility for maintaining the services under the wall. If the wall incorporated a suitable duct or 'bridge' through which the services pass, then that would enable the ducting to be maintained. They may never ever need maintenance - but that is irrelevant. On our site, water and electricity pass under a properly specified building foundation in a suitably designed duct (specified by the relevant authority). Ring them or write to them and ask, or get your builder to do so. The Water and Electricity people are keen to help usually - for obvious reasons. -
Planning refused and we want to appeal. Is it worth it?
ToughButterCup replied to Dee3003_'s topic in Planning Permission
Welcome. You've had a hard time - you're amongst friends. Many of us have similar stories to tell. One way of making progress is to take each point , and list the arguments the Officer made rejecting your application. For each point, in as few words as you can : list the ways in which you have sought to address those arguments look at recent builds where the LPA has not followed the advice given to you (I see you've started to do so already) I 'see' more clearly in some form of table: arguments for in one column, against in a parallel column. That technique reduces mental clutter. Present that table to a Planner (whom you employ) - with the end-in-mind being - If we present this case for Appeal, is there a chance of winning? If you can clearly show that Planners have applied different criteria for your Application than those used in other Applications, then you've stated to weaken the LPAs case. Brevity and clarity of presentation are powerful tools Good luck, Ian -
When Can We Move In?
ToughButterCup replied to MortarThePoint's topic in General Self Build & DIY Discussion
The point made above about water supply is correct. No water no habitation. But the District Valuation Officer who visited us never saw our water supply. She did see a sink (through our kitchen window) and assumed we had a water supply. I asked her to substantiate her claim. Silence. As I understand it, Valuation Officers appear to be becoming more assertive. And that fits the pattern of increased pressure on Local Authority budgets. -
Keep the HERAS up and secured. And if possible a time lapse camera - to evidence who has - and who says they have (but hasn't) - visited the site. The BC is irrelevant: but the District Valuation Officer is relevant . How I wish I'd known that four years ago. -
Should I do something or leave alone ?
ToughButterCup replied to Pocster's topic in General Construction Issues
Where did the mud come from? Its hard to tell from the image...... I ask because I'm not sure whether you have merely one problem or several. If the issue is the mud - stop that, and (one of ) the problems disappears, perhaps? Could it be that when the drive is swept, the rubbish ends up in the 'trench' ? Or do you jet wash your wheel arches and the mud gets into the trench -
Novice wanting to learn possibilities
ToughButterCup replied to Alice67's topic in Introduce Yourself
Morning.... you've brought the sunshine with you . Thanks Waste time on here and you'll wonder where th day(s) went. -
If you have, what's the point of demanding one? Annoyance drips from almost every sentence of your post. A couple of years worth of annoyance. May I suggest you ask yourself why - after all that time - you haven't worked out how to let the annoyance go.
Is Ecobrix worth the extra £££?
ToughButterCup replied to Great_scot_selfbuild's topic in Foundations
Yes it does. Almost Durisol is 86% air. Unlike a sponge it dries out as fast as it gets wet. Bit like my old Landover. Water leaks out as fast as it leaks in. I would not consider using Durisol underground: in fact it might well be useful as part of a soakaway design. -
The research evidence on security alarms
ToughButterCup replied to Adsibob's topic in Networks, AV, Security & Automation
M6 North bound : Lancaster, just short of Lancaster North junction (34), 21:00 and later any day on a warm evening ..... The Prison staff are mostly at home You can hear from the Northbound carriageway, the inmates - many of them , not just one or two - banging on the windows with metal plates, screaming, crying - over the motorway noise. Riding my bike home on the track next to the prison after a late teaching session : I never got used to the noise - and won't forget it either. No Butlins methinks. -
ICF How much more expensive ?
ToughButterCup replied to Dave Jones's topic in Insulated Concrete Formwork (ICF)
Oh how many times did that have to happen before someone enlightened me about shock-load? Hundreds. From hand-held hammer drivers to dumping heavy objects on shelves, or being catapulted out of a mini-digger seat, or tapping a 'locked' nut, or opening a tight jam jar. -
You write about possible motive. ( fishiness). Almost always a mistake because normally nobody can evidence motive. You want to test the principle? Do so. You want to reduce the risk of doing that? Ask another Planning Consultant. Research -online- similar Applications in your LPA : know why and more importantly why NOT you should be given Planning Permission on the basis of evidence. And that's there for anyone to find.
Biodiversity protection method statement
ToughButterCup replied to Drellingore's topic in Planning Permission
First port of call: the LPA website. Download and pick apart any that you find..... Next : heres what ChatGTP spewed forth.... -
One of my early errors was to assume that self-builders got worthwhile discounts. We generally don't. Because most often we're one-off customers. However, that doesn't mean you shouldn't try....
Geberit in wall WC frame - instal height?
ToughButterCup replied to markharro's topic in Bathrooms, Ensuites & Wetrooms
Back injury makes one a God sent answer to a problem that appears when it decides to ruin a couple of days for me. Get one with a drier as well as a 'hose'. Download the app (Geberit) and tune it to your particular Botticelli. There is genuine fun to be had if a relative refuses to use the app. For example they might be sitting there with a smile of benign relief and you - using the app from elsewhere in the house - change the water temperature to cold , or the strength of flow to ArseBlast: Or both. On hearing the screams, jump in the car and off to the only pub in the area which is in a mobile signal dead spot. Flowers from the garage on the way home. -
The closer you get to the full squat position , the healthier it is for anyone to drop the kids off in the pool. It reduces strain, straightens the rectum out, and stretches yer hips. The puborectalis muscle is also relaxed. A footstool helps because your knees should be higher than your hips, the old puborectalis again . So lean forwards slightly, rest your forearms on your knees, and then think of England, Harry and St George. A long way of saying Lower is Better Please don't ask me why I know so much about this particular issue. -
Good start. Head down - go -go go
Removing tree ear marked for retention
ToughButterCup replied to flanagaj's topic in General Self Build & DIY Discussion
Here's the West Lancastrian answer to your problem Ring my nearish neighbour: outline the problem and if you can understand the reply book a holiday leave your phone at home leave for your holiday my neighbour turns up at 08:00 on Sunday morning while you are away parks so his Land Rover's number plate is not visible fells the tree if small enough, he logs it and drives away with the trunk in bits in his trailer hope his LR doesn't break down you come back from holiday and say Nowt-to-do-with-Me-Mate. I know Nuffin. Problem sorted Worst case: he gets busted by Mrs BizzyBody and he is hauled up in court pays the fine smiles smugly because you reimburse his fine and he uses the tree for next years firewood Meanwhile at the inevitable sophisticated Christmas drinks parties you tell the story of how you have no idea what happened and that you have already plans to plant several replacement trees. And everybody's happy: you all can piddle in peace and my mate keeps his feet warm for a month or two. Whas' not to like? I tell ya - West Lancs: it's the new Wild West -
Architects, ballooning fees and estimates
ToughButterCup replied to Drellingore's topic in Costing & Estimating
Which is what we did. Here's the charging schema used by our architect - easy, simple, open. More detail here.
