Nick Laslett
Everything posted by Nick Laslett
MVHR drone
Nick Laslett replied to Mattg4321's topic in Mechanical Ventilation with Heat Recovery (MVHR)
@Mattg4321, I did link to the iPad/iphone spectrum analysis tool I use earlier in this thread. -
I’m sorry, I’m just an amateur. You’ve probably already seen this, but this is what Google Gemini says: For me, thinner paint and getting the pressure right had the biggest effect. Distance from surface and movement speed came next. I’d also heard about the “warming the paint technique”. Buy a different brand of paint, see if it is still a problem. I’ve only sprayed Benjamin Moore ceiling paint, Benjamin Moore Scuff-X Matt, and Valspar Premium Walls & Ceilings Matt. They all sprayed differently. I have a Graco sprayer, so I don’t know anything about Wagner sprayers. For ceilings I used FFLP514 spray tip. Google Gemini says this about tips:
Usually 70/30, but I tend to do a test batch.
@kentar, a lot of variables in airless spraying. I find this YouTube channel is a great source of information. https://www.youtube.com/@PaintHQ In my experience you need to thin the paint a lot more than you’d expect. Keep the spray gun, perpendicular to the surface. The spray nozzle sets particle size and fan angle, this has a big impact on the finish and distance needed from surface to prevent running and orange peel effect.
@Mr Blobby, talked about it in this thread. A couple of us used this product. This link is in the thread above, to a blog with video discussing the render reveal bead. https://www.beconstructiveltd.com/why-use-external-wall-insulation-reveal-bead/
Just a note for anyone looking at the BES flexible hoses for ASHP. Part Number: 25287, Manufacturer's Part Number: FH-500-28F https://www.bes.co.uk/flexible-hose-1-bsp-f-swivel-x-28mm-x-500mm-pair-25287/ For some reason they list them as having a 28mm bore, not sure why? This is just the outer bore, so how useful is that? On the manufacture’s spec sheet they are DN25, e.g. 25mm inner diameter. https://diversitech.global/storage/app/media/DataSheets/Technical Data Sheets/HOSES/H-FLEXIBLE HOSE-TDS.pdf They also have a DN32 flexible hose, this seems harder to find. Not really that important, but when I was getting the flexible hoses for my ASHP install, it was frustrating that the inner diameter information wasn’t easier to find.
Too much glycol?
Sewage Treatment Plant self install
Nick Laslett replied to MortarThePoint's topic in Waste & Sewerage
The main issue my ground workers had, was very high water table, and sandy/gravely soil. The site is a former gravel pit. We have the same STP as @ProDave. They were worried about the unit popping out of the ground. They took the concrete from the back of the mixer into the digger bucket. -
What kind of soil do you have? My ground workers first install attempt failed, when the hole collapsed. They abandoned that hole and started in another location. We needed expensive shuttering and bracing to support the install. Special attachment on the digger, rams the shutters into the ground. -
I don’t believe you need the dual temperatures. Supply water just above the dew point and I expect you will get the house cool enough with UFH and Fancoils running at those temps. Plenty of anecdotal comments here about Fancoils delivering at temps above dew point. The trick is to never let the house overheat in the first place. The ASHP weather compensation will supply the cooling before the house ever gets really hot. You can use Home Assistant connected to a dew point sensor to control the Panasonic ASHP flow temp. @Dave Jones
Panasonic aquarea wall fan coil - condensate?
Nick Laslett replied to SBMS's topic in Air Source Heat Pumps (ASHP)
Here is the link to the Installation Manual for the Aquarea P-FMM units: https://www.library.aircon.panasonic.eu/GB_en/doc/rUbm7oIgxvs=/ Google is so useless, now. I switched to DuckDuckGo and it was the first link. 16mm diameter condensate connection on the P-FMM15 model. -
I would think the P-FMM15 will also have a 14mm condensate pipe. You can always speak to the technical dept of the supplier, they will give their take on how best to plumb the condensate pipe. -
Here is the page from the installation manual for the floor standing unit. Source: https://shop.dhps.nl/Article/DownloadAsset/Installatiehandleiding Panasonic ventilatorconvectoren P-FAL serie (Engels).pdf?documentId=assets/1043/d4cdab92f98c4a15b453b97b9addb49e Basically you route the condensate pipe to a soil vent stack. Use a waterless waste trap between the condensate pipe and the SVP connection. Like this: https://wavin.com/gb/p/c5d3a02d-0d50-4ebb-a3a7-ff44fe446e57/osma-hepvo-waste-valve-32mm-white The condensate pipe will need an adapter to convert it to 32mm for the waterless waste trap. I did find a smaller 21mm trap here. The condensate pipe diameter is 14mm. https://www.greenmillac.com/Waterless-Trap-3-4-inch In an ideal world you will be able to access the waterless trap, as eventually it will need replacing. -
We have 3 pocket doors, and I spent a lot of time looking at the various options, Eclipsse is very popular and there are some good YouTube installs. Other systems I looked at were from Portman, Ermetika, and Scrigno. https://portman-pocketdoors.co.uk https://www.ermetika.com/en/sliding-doors https://www.scrigno.com/en/categoria/wooden-sliding-doors/ This was something I was going to install myself, so I spent a lot of time looking at the install guides to see which was the easiest to install. You really want a carpenter that has experience with one of these systems or a specialist that deals with these installs specifically. In the end I did a bespoke install using the sliding door product from Smart Systems Aluminium that matched our French doors. Because I was building the stud walls from scratch, it made incorporating the doors a lot easier. The various kit options do have some neat extra features. Hafele also do a kit which gets a lot of positive ratings. https://www.hafele.co.uk/INTERSHOP/web/WFS/Haefele-HUK-Site/en_GB/-/GBP/ViewParametricSearch-Browse?SearchTerm=+pocket+door&SearchParameter=%26Category%3DhmAKAOsFdfwAAAF.B87iJvmA The point of the kits is that it should remove a lot of the issues about getting everything plumb and true.
For my design I targeted 90m long loops. The piping comes 100m long reels. I went with 200mm centres which I think is the rebar grid distance. Anyway they follow the rebar grid whatever size that is. My installer fitted less pipe than on the plan, but it doesn’t seem to have affected the house. Some good discussion here.
@JohnnyB, the latest Grand Designs is a hempcrete build. Very helpful to have visited your build, before watching this episode.
MVHR drone
@S2D2, I bought all my spiral ducting form the Duct Store, like @JohnMo. https://www.ductstore.co.uk/acatalog/Attenuators.html They have attenuators. I used the Lindab Safe Click system, which has rubber gaskets. I bought all these components direct from Lindab. Just find the nearest sales office to you. https://www.lindab.co.uk/Products/ventilation/Sound-attenuation/?sort=popularity&display=16&page=1 They have a huge choice of attenuators. If you want to be confident that you are going to cut most of the MVHR unit sounds before they hit the manifold, you need an attenuator that is 1000mm long. If you look at the spec sheet for the Lindab Attenuator, the difference between 500mm and 1000mm is significant. A semi-flexible radial system will also help mitigate the noise. Also, you don’t want your individual ducts going to a supply outlet being too short. Here is a photo from one of @Nickfromwales installs showing 500mm attenuators, foam insulated ducts and a Ubbink manifold. -
MVHR drone
I agree. It is quite confusing. @Bitpipe implies in this thread, that he got the foam inserts from BPC and used them at the plenum to reduce sound. But he might have had the old fashioned Vents with no attenuation properties. -
MVHR drone
BPC used to do foam dampers at the plenum. They have something similar here. https://bpcventilation.com/collections/acoustic-solutions/products/quiet-vent-adjustable-flow-control-damper The previous version was talked about on BuildHub, years ago. I did find these products, which I liked the look of: https://ventmann.co.uk/products/inline-foam-damper?srsltid=AfmBOoq-8qHhLQ_amR3s3V39sjjcbggu86fNVxxn-ttVyy9-eZ3zq-lI -
MVHR drone
@Mattg4321, you can buy these semi-flexible attenuators direct from Lindab. https://www.lindab.co.uk/Products/ventilation/Sound-attenuation/circular-attenuators/slfa/?sort=popularity&display=16&page=1 Unlike the BPC product, they actually have a spec sheet with the attenuators reduction for different frequencies. The BPC product might be great, but need more details. You can get an audio tools app for your iPhone/iPad, which will tell you the frequency you are trying to reduce. There maybe some free ones, but this is the one I recommend. https://apps.apple.com/gb/app/audiotools-db-sound-audio/id325307477 They have a video on their site demonstrating the FFT function. https://studiosixdigital.com/audiotools-modules-2/acoustic-analysis-modules/fft/ There are many MVHR ducting attenuators out there, but the good ones will provide the frequency attenuation charts. Good site here with multiple examples of different types. https://en.ventilatory.net/duct-elements/silencers Good BuildHub thread here about MVHR attenuators. -
In west Suffolk, I used Clarkes of Walsham for the plywood for my flat roof deck. And a few sheets of 18mm OSB. I’m close enough for free delivery. https://www.clarkesofwalsham.co.uk/product-category/building-construction/sheet-materials/plywood-sheets/ For a number of other timber purchases I used Suffolk Timber Supplies https://suffolktimbersupplies.co.uk/sheet-materials This was material I wanted cut, so collected direct. They appear to have branched out to building timber frame houses.
Go for it. Loads of videos on YouTube. So many ways to improve the thermals. I had 2 solar panels on mine, before they went on the house. Enough juice to run 800w microwave from the attached batteries and charge all my tools.
I use these for my storage container. https://www.ebay.co.uk/itm/264424304680#:~:text=They will not leak or,-lasting%2C effective moisture protection. They have a few different sizes. The container has very tiny vents at the top on both sides at either end. As long as you don’t add any moisture, they will stabilise with the outside humidity levels. The worst thing you can do is spend a lot of time in the container, adding moisture through your breathing. Also put plenty of 20g silica packets in all the boxes.
This was back in May 2022. 15mm 2440x1220 Medite Exterior Medium Density Fibreboard @£39.17 per board, 48 in total 15mm Medite Exterior MDF is quite hard to source from online sellers. Just had a Quick Look online and 12mm Medite Exterior Mdf was priced at £65-70 per board. I’m sorry if my comment was more confusing than helpful. I just wanted to make a distinction between Medite MDF and unbranded MDF. Plywood is another generic term, where there is such a range in prices for the different specs. So I assume Latham’s plywood might be expensive compared to B&Q, even when bought in bulk.
