Declan52
    10
Declan52 last won the day on November 24 2019
Declan52 had the most liked content!
2 Followers
Personal Information
  • Location
    Co. Armagh
8483 profile views
Declan52's Achievements
Advanced Member
Advanced Member (5/5)
1.7k
  1. You do the same thing when your leaving the cills out to be put in later on to prevent damage. I assume some sort of door threshold will be installed at a later date.
  2. Won't matter what way it starts.
  3. You have a better memory than me!!
  4. Welcome back Jeremy. I'm glad you got your issue sorted. If I remember was one of sunamp main guys not a member here for a while.
  5. Anything basically below finished floor level has always been referred as the great unknown. Nobody really knows what's under that lovely green grass until the digger comes in and starts working. You could be lucky and hit hard earth/rock pretty shallow or end up with 3-4m of trench fill or piled to 15m. That's why you never get a definite price for a job until your at FFL. If you get a SI done and they come back with bad news that it has to be piled to beyond 6m would this make the build a no go?? Have you contacted a SE to see if a series of trail pits to 4-5m would be suitable. Would require a much larger digger 8-10t but would still be cheaper than a full SI.
  6. You can't use that sample for anything as it's classed as a disturbed sample. They can check it for organic materials is about the height of it so waste of time. When you do a borehole you use a hollow pipe/cone to perform a spt which is basically counting how many blows it takes to move a set depth. If it takes under 10 blows the ground makeup is very soft and on the other hand you can get over 50-60 blows and even refusal where the tool just bounces, usually when you hit rock. You can see on the logs above they have performed 2 tests, with 7 blows and 50 blows. So a massive difference in the bearing capacity of the ground in a few metres. Did building control come out and look at your trial pit or just you and the digger man??
  7. They are just being safe by asking for all the information so they can correctly give you a solution. Are you any way handy with a spade and a set of post hole diggers?? Easiest way to figure the first step out is to dig down at the side of your house and see what's there. Remove around 1m square of material to give you enough room to get at the foundations. You should either find rows and rows of blocks then a ledge of concrete. Or a ring beam with reinforced concrete. I used to do this it's not that hard and will take an hour or so. You do look like you have enough room for trail pits which could be an option. 1 day hire of a digger and dig a few holes. Ideally if access isn't an issue a 5 ton digger will get you 3.5m deep. Which might be enough as you will be into the firm clay going by the borehole logs. The different water strikes are just the depths the guys doing the drilling hit water. Nothing unusual with that. By getting a SI done you will know what method is available. It's really the only way to find out exactly what's there and include data to let the SE perform his calculations correctly.
  8. If they won't replace the window due to the lines on them, they will if the seals go and they are under warranty.
  9. Leave it as it sits. To remove that wall is a massive job with that bank it's holding back. Any replacement with be either at least 200mm wide reinforced concrete with a footing off over a 1000mm wide with lots of steel or block wall 1000mm wide at the bottom and stepping up to at least 450mm at the top. Either option is going to be very expensive. I would use battens and clad it in something nice. You could even use thin real stone cladding that won't be much more than 50mm extra.
  10. My kress will go through a corridor of 60cm.
  11. The dealer where I got mine was telling me he couldn't give away ride on mowers anymore. No one wants to pay more upfront and then all the fuel and servicing that they require each and every year. A replacement battery for mine is £55 so easily replaced. A set of blades is £10 and that should last a year.
  12. Think you need one with rtk and 4wd which is code for expensive!!
  13. Most don't cope well with slopes unless your spending major money £2-£3k.
  14. It only cuts a tiny amount of which falls in to the ground and is like compost eventually. You use one to maintain the garden more than cut it. After your first cut then you can reduce the cut height week by week till it's at what ever suits you. Mine is at 45mm.
  15. Looked at them but if I was spending that amount I want a specialised dealership network I can call if I'm in trouble.
