sgt_woulds
Everything posted by sgt_woulds
Considering scaffold tubes for a ground mount.... thoughts?
sgt_woulds replied to TedM's topic in Photovoltaics (PV)
You could use something like this to control it: Single Axis LCD Solar Panel Tracking Sun Tracker Controller W/ Wind Speed Sensor | eBay UK -
Fair enough 🙂 Our customer was an Econutter who was eeking out every last watt. Eventually, even he only adjusted his array twice a year. End of October and end of April from memory. In the first year he changed it daily; his panels faced slightly east of East of South, if he laid them back in the late afternoon he captured a few more rays before the sun set. Like I said, 'Econutter'. You can afford to play if you are retired I guess! These days an automated single axis tracker would be easy to set up, though -
You could always look at a design that allows the array to tilt at different angels for summer / winter. We did this for a customer many years ago and it made quite a difference to his outputs - he kept daily records, and after 2 years had worked out the optimal time of year to adjust the angles which was a 30 minute job with spanners twice a year. I can't remeber the details of the frame we used but I can see it could work well with scaffold tubes as it would be easy to create a pivote around the poles. -
Assuming 5x1 row then no! 5 x 1134 = 5.67m without considering the clamps (assuming approx 25mm width for each clamp that would add an additional 150mm) Best get 2 lengths at 6m. You need to make sure that you add enough support to the unistrut rails with the scaffold poles - a proposal sketch would be useful. If you have large overhangs with unsuported unistrut then use 41 x 41mm unistrut instead of 21 x 41 mm. -
I like those scaffold/panel clamps - not seen them before but I've been out of the game a while. Bloody expensive though! Before MCS was introduced to extort money out of the system suppliers and legacy installers, we used unistrut for everything. My vote would be for galvanised unistrut as it will last longer than mankind. Having said that, if you don't mind a bit of surface rust after a few years then BZP will be fine. We used to get ours from CEF (2 x 21 x 41 mm). I'd use aluminium T-clamps and mount them to the strut with with short-sprung unistrut channel nuts. (the springs are a luxury but it makes locating the bolts easier). Be aware of the clamping zones for your panels - clamping outside the zones can induce stress and create microfractures in the cells. In extreme cases it can cause 'rapid, unplanned dissassembly' in strong winds... -
Unistrut. Mechano for big boys... 🙂 Scaffold poles are harder to cut, not as easy to fit together, and you will still need a way of mounting the panels. However, if the tubes and labour are free... -
Exploring the ratios and losses between building elements
sgt_woulds commented on SteamyTea's blog entry in Energy Ideas
Talking of screwpiles reminds of another GSHP project in London; They were using a machine to fit a vertical deep-bore heat pipe. TFL arrived and asked them to stop - less than politely but for very obvious reasons -when it was pointed out that their back garden was directly above part of the Norhern line... -
I've not been able to check your calculator yet Steamy - no computer at home at the moment. Could it include occupancy levels and biogenic heat sources? I read this recently: The small passive house problem - a solution? - passivehouseplus.ie To my mind, most PH builds have been massivly oversized because it works better on paper. It would be nice to have a tool that advocates for sufficiency. -
I guess my thinking was, if you have a digger in anyway, just dig a few trenches for GSHP as well. All points taken on board, and I do think GSHP has had its day. I vaguely remember reading in (I think) Green Building Magazine (great magazine sorely missed now that the deathly boring PH+ has replaced it) that someone had built a heat store under the foundations, using a tarmac drive with pipes to heat it up. Maybe it was a school - it was a looong time ago. Back then we had a lot more people willling to experiment. Back when I was installing solar (when the average system was £25000 for 1.5kw), we worked with a some fantastic experimenters and early adopters. One chap - who lived in a Walter Segal designed, and self built house - dug out his entire back garden to shoulder depth using nothing but a shovel and wheel barrow to bury his GS pipes. He was powered by Rum and Wacky Backy and was older than I am now when he started! The soil was removed by barrow to skips at the end of the lane, stored offsite, and then returned for the reverse process. Unbelivably he finished it all in a couple of months. Then he realised there was a leak and had to repeat the process... -
In the colder regions of America they sometimes extend insulation out from the foundations, or create a skirt of insulation deeper than the foundations. I think this is for frost heave, but it should also make the temeperature under the slab more stable. Could GSHP pipes be layed under the raft at the same time to take advantage of this, or would removing heat under the slab cause other issues? -
Talking of sums, this is a bit out of date now (I saved this about 5 years ago), but posted for further discussion: This does not include running costs. Perhaps someone here can update the MVHR / MEV costs based on real life experience. I've costed iPSV componants at around £800 for my small 3 bed, two storey house. at current prices
These only list temperatures at 1m depth, which is barely below the subsoil in most regions. We are on solid chalk and our topsoil depth is only about 300mm max. At depths of 1.5 to 2m the rock should be at stable temperature. In Hungary i've visited peasant wine cellars built into slopes where the depth above the vaulting is less than two metres and the resulting drop in air temperature is very noticable even in sustained heatwaves. Soil pipe / Earth tunnel. Same thing - just don't confuse it with the other type of soil pipe 🙂 Cooling only. I gather it is quite popular in French public buildings and schools & used by enviro-mentalists (like me 🙂 ) in California . Measures need to be taken to ensure that rain/rodents etc cannot get in. I suspect that clay pipes would work better than plastic to for energy transfer. It's not about energy gain, this is about drawing in cooled air for sustained high temperature situations where subsoil and rock maintain a lower temperature. Even a 2 degree drop from ambient air temperature can be a significant health benefit in a sustained heatwave. Could we see your sums on this? Are you talking about a planned and 'intelligent' passive stack in a well sealed or even 'passive' house or retrofit to leaky fabric? If it is the latter, then none of the ventilation options are perfect...
One of the drawbacks I can see with iPSV is hot days and sustained heatwaves with little wind to drive ventilation. Currently we 'sail' or house through heatwaves by closing off all ventilation and shading the south facing windows (curtains, but we are planning external shades when we replace the front windows). Our roof and walls contain lots of woodfibre so we have good decrement delay, and occupation is low during the day so CO2 and moisture levels are not an issue. In the evening after the sun has set and the air temperature has dropped, we open the north facing windows and the skylight and purge ventilate the house - you can feel the cooler airflow and it is very refreshing. However, after a couple of days of heat, the night time temperature difference is reduced (due to radient heat from the earth and buildings) so this option tails off and CO2 levels inevitably rise. We then use portable fans to make life bearable. I know they considered this issue with the Bedzed buildings and tried using ventilation cowls / wind catchers but I don't think it was very successful. It is pretty much a given that climate change will lead to more frequent and longer heatwaves so I'm considering building a solar chimney with soil pipe ventilation - I have to build a patio out the back anyway so it is just a little extra excavation. The chimney might be an issue with building control, but sod 'em! We'll stick it up and see if anone notices! I have a couple of ideas on the design, and I'm considering buying the Handbook of Domestic Ventilation but I don't know if this is a good sourceof information or if there is better text elsewhere. It is an expensive book to take a punt on...
With iPSV you don't need a fan in the bathroom or kitchen, to maintain overall conditions. You might want a small fan to assist with kitchen odours though. We do have an extract fan in our kitchen, as an easy route for passive stack was not available. Building from scratch, these problems could all be mitgated at the design stage.
Restricting moisture sorbing and release to the surface materials (Gypsum plaster boards) limits the positive benefits of stable indoor moisture levels that natural insulations can provide. Not an issue with MVHR of course (unless there is a sustained power cut in winter with high occupancy) as this is artificially removed. Personally, I'd rather not rely on a mechanical system to stay healthy indoors. Horses for courses. And I prefer my straw hat to tin foil 🙂
I remember working in a factory conversion many years ago. They wanted the high vaulted ceiling look, but realised that in winter all the heated air would be above their head. They had a wierd looking single bladed fan to force warm air back down to occupent level...
Interesting comments on Gypsum plaster. For our woodfibre IWI, lime plasters are always specified because it is more breathable than Gypsum in the same situation. The sorbative properties of woodfibres (and natural fibres in general), can release moisture quicker with direct lime plasters than than gypsum. Some testing in Germany has shown woodfibre insulation to activily transport moisture from damp structures to the surface, so breathablity is critical. We have an alternative system using battens and boards with plasterboards and flexible woodfibre behind a moisture vapour variable membrane. (M-V VL membrane restricts moisture entering the insulation, but still allows it to breath out effectively when contditions allow. (After the Gypsum has (slowly) released its moisture) This works technically, but holistically it reduces the moisture buffering and moisture exchange rates and is not the best use of natural products. (Essentially, building moisture buffering is almost wholly down the the plasterboard and skim).
Thats the point. I'm concentrating on airtightness, then introducing a controlled volume of fresh air, based on internal moisture levels. As long as internal moisture levels are low, the vents remain closed so over-ventilation shouldn't be an issue. Empirically, I have noticed CO2 levels rising pretty much in line with moisture levels and occupancy so I'm not concerned about passing out from hypercapnia using moisture as the controlling method. It would be nice to have some heat recovery and filtration, but since Ventive pulled their product from the domestic market this doesn't seeem to be commercially available.
Always a worry when Governments mandate a solution. You'd hope they would learn from past mistakes... Building regs should set standards and highlight agreed solutions, but not prohibit alternatives measures where effectiveness can be evidenced. As to MVHR, I prefer long term ruggedness over perfection. Currently our house is manually ventilated and we have dumb window vents. CO2 is not an issue but moisture can be. I'll add the new moisture sensitive vents and ridge vents just as soon as I finish all the other building works. Only been at it for 12 years so far... @SimonD how did calculate your ventilation and sorbative insulation efectiveness?
I planned my house upgrades around using the Glidevale I-PSV system, combined with natural internal insulations for humidity buffering. (Windows ready for inteligent trickle vents, undercut doors, and additinal vents between rooms and a central starircase / stack to ridge ventilation). Benefits - zero power use, nothing to go wrong, and zero maintenance. Occupants are the 'smart' part of the system and we are perfectly capable of sailing the ship as required But now my other half is insisting on an MVHR as she 'doesn't believe' passive stack will work...
Was this 'animal glue' made from boiled rabbit skins? I remember seing this used to reinact the 'solvite man' advert. Amazing stuff in tension, but could creep over time with lateral loads. Fully organic and breathable and much nicer to use than modern urathane glues - apart from the smell
Passive house Shepards hut ?
sgt_woulds replied to Waterworks's topic in Energy Efficient & Sustainable Design Concepts
I've (tried) to sleep in a 6 man tent with one of these: Outbacker® Pioneer Portable Tent Stove & Complete 2.41m Flue Kit | 2.5 Too hot even when there was only a flysheet as insulation. I vaguely remember that the first 'eco' house built at the Centre For Alternative Technology was massivly over insulated (and poorly ventilated) back in the 90's (?) and inhabitants had to strip down to their underwear until the place was rebuilt. -
What is this made of? Ceiling wood fibre board type stuff
sgt_woulds replied to paro's topic in Building Materials
Glass fibre is almost as bad as asbestos, I hope you wore a good mask! Not to mention the zoonotic risk from rodent droppings... I'm so glad that I don't have to crawl around in lofts anymore 🙂
