Coanda
Personal Information
  • Location
    Norn Iron
762 profile views
Coanda's Achievements
Member
Member (3/5)
8
  1. All the air that's in your flat has come from the outside, so bringing in more will just be the same level of pollution. You say it is well ventilated already so whats the point, unless you can filter the incoming?
  2. I set my DIY system up with one I got on a well known online auction site. How accurate does it need to be?
  3. I'm wondering, does any air get sucked in through the condensate drain?
  4. Yip. My bin blew over and a fence that was falling down is now down. To be fair it was as bad as I've seen in a long time.
  5. I'm pretty new on the mvhr scene and while I am researching, I am running a temporary set up which is not powerful enough, but better than nothing. My house, I thought was quite leaky but RH and co2 levels were much higher than they should have been so obviously more air was needed. I think my mvhr won't have to work as hard as one in a tighter house, but is still necessary.
  6. I had the bucket left over from drilling the ceiling holes. I put my hand up through the hole with a sealer and held the drill inside while I drilled the holes, the bucket caught the dust.
  7. I balanced mine up with the aid of an anemometer bought off ebay, a plastic bucket with a hole cut in the bottom and a sponge seal around the top. I had to add a speed controller to one of the fans as it was more powerful than the other. I wasn't too difficult. I've got some mods to do so I'll be doing it all again soon.
  8. So far there has been no condensation in my DIY unit. However, I am in the design stage of DIY unit 1.1 which will be a much better insulated twin core model. Am I right in thinking, should any condensation form, it will be in the extract (from home) chamber and that is where I should put a drain? Just in case.
  9. I wouldn't recommend it. I had a large GSD which was mostly a yard dog when not competing. A few years back during a heavy frost SWMBO decided to bring him into the house, "Poor thing is cold" she said. Bed time came and she decided it was still too cold for him to go outside, and the cat claims the living room, so he was permitted to sleep on the bedroom floor. He never settled all night, sniffing snorting, farting , moving back and forth. I said to her in the morning, "We won't be doing that again", she didn't disagree.
  10. If there's a flow through the building of x m3 doesn't it follow that there must x m3 coming in and x m3 going out or am I missing something?
  11. I Took a oic this morning. Which gives SAP 73.6% PHI 76.9% I adjusted the incoming air to within 2,5% of each other. Life is to short to strive for better. I left things for a few hours and took another. Which gives SAP 71.2% PHI 80.8% Making the SAP findings a bit lower and the PHI findings a bit higher. Is it better or worse?
  12. I know that my input exceeds the output by maybe 20% but I bought a speed controller for the faster fan. So that's a job for tomorrow. But the formula doesn't know that input air is more than output so it's the same for both.
  13. What I think is skewing it is that intake temp is higher than exhaust because of the heat on the south facing roof. If we take yesterdays figures of intake 0.4 exhaust 3, supply 7.9 and extract 10.6. 7.9-0.4=7.5 and 10.6-0.4=10.2. 7.5/10.2=73.5% for SAP and 10.6-3=7.6 and 10.6-0.4=10.2 7.6/10.2=74.5% If the formula was correct you'd expect similar results over a range of readings. No?
  14. Have i got this right. Using todays figures 13.4-12.1=1.3. 14.4-12.1= 2.3. 1.3/2.3= 56.5% 14.4-10.6=3.8 14.4-12.1= 2.3 3.8/2.3=165.2% Hellova difference.
  15. Nothing has been changed, it's just that it's a lovely sunny day here and the intake is on the south facing roof side. I've been reading here to try and get my head round this % thing. Cheap MVHR or expensive MVHR? The science behind Heat Exchanger Efficiency - Heat, Space and Light Ltd (heatspaceandlight.com) Why different methods. I mean 2 and 2 is 4 but apparently not in this case.
