FuerteStu
Personal Information
Location
Suffolk
FuerteStu's Achievements
Regular Member (4/5)
215
Number one. Not just because the more grey colours seems to contrast with the block, and overpower the eyes (this will lead to your eyes looking more at the smaller surface area of the wall and be distracting, rather than the feeling the blockwork is the wall, and the mortar just s supporting role) But because there are green tones in the first that will age better. Over the years this will allow nature to grown alongside it in a complimentary way. If you intend an ultra modern gravel and slab surrounding design, then fair enough, but anything growing next to the grey would seem like a weed in a lawn and out of place. (just purely my opinion and feel free to ignore)
For future reference, these are a fantastic way of getting around bad edges. Several on the market, but these 'skim over' ones are loved by the plasterers I've fitted them with. As they can just go straight over. They even make downlighters ones
Saw a balcony panel in Spain with a basketball net attached to the bottom.. Can't imagine that will last long 😂😂
What are you doing about cooling? 4" Extraction pipe direct to external wall? Or are you going for a split unit ac?
I used to work with civil formwork and concreting. Bridges, retaining walls and abutments mainly.. Self compacting concrete isn't what people think it is. For the most part it's used when you're unable to access to 'poker' and get rid of air pockets. (like 10 metres down in a bridge pier column, or in situations where it's dangerous to send a crew into an area like a confined space) Personally I wouldn't recommend it unless you HAVE to use it, the reasons to WANT to use It, simply a lack of understanding and skill. It would be a bit like listening to someone who said they can make money really quick, and taking you to a casino. Big gamble.
Time for some new Makita goodies- any good deals on?
FuerteStu replied to Crofter's topic in Tools & Equipment
Just jumping on the comments about dual chargers. I picked up two single chargers, cheaper than a double. Which also meant I had a spare when one failed several years later. Worth considering -
Agreed. Reduction is the first step. But when we can't reduce much more, offset and capture will help stabilise.
The concept was effective because it did not rely on transport, something that makes a large amount of 'green' systems, not very. Carbon was deposited on site, whole system was floating (inflated so sections were easily transported and assembled) and powered by solar. Out of sight of anyone who would complain too. Couldn't see a downside other than the cost of setup and occasional maintenance (if I remember right, a sweeping arm collected the algae and scraped it onto the edge where it was dried using sunlight and then sent to the deep blue.) I wish I knew when and where id seen it so I could find it the actual numbers of tonnes collected per year.
Carbon capture is one that nature does better than humans could ever engineer. Everyone thinks of trees, but that's far too slow. I saw a piece where they were growing algae at sea, and drying it out and turning it to dust. It was de-acidifying the ocean at the same time as capturing carbon. Logic was that it could just be sent to the bottom of the ocean where it was, and the process could be largely automated. From what I can fathom, there is zero profit in it, so it's probably never been embraced.
Could it be a class two fitting (all plastic and no earth). And you're confusing the earth and neutral? Perhaps the wiring you have (red/black + other) is a live, switch live and neutral. I think we'll need the instructions and wiring diagram to confirm.
Struggling to find an sink trap adapter.. Any ideas?
FuerteStu replied to FuerteStu's topic in Waste & Sewerage
I didn't know it was a thing that wasn't done. Considering most of the wholesalers listed it as an adapter on their websites I assumed it would be a common connection and not an issue. The 32mm trap in the downstairs bathroom gets clogged up regularly, I figured keeping it 40 would be better Mcalpine is a brand leader, standard. It's their product It wasn't until I visited local places and just got shrugs that I looked online and nobody had it in stock. And those that said they did screwed me around. The mcalpine store on amazon doesn't even stock it.. Yet nowhere does it say its been discontinued. -
That's what I'll be doing. What's so frustrating is that it shouldn't be a big deal to tell someone they don't have it, or send it the right one. I could have adaptated and fitted this a month ago. -
Update.. Ordered from these guys, after a week I got a call saying they don't have it and they would refund. Ordered instead from 'plumbing supplies delivered' and after 2 weeks it's arrived and they've sent the T12 instead of T12F so the threads are the wrong way round and it's useless. (I paid for a delivery upgrade to get it fast too) I've come to the conclusion that all plumbing suppliers are utterly useless and it looks like I'm throwing away the 40mm pipework and AAV already fitted under the sink and doing it in 32mm. After a month of messing around 🤣🤣ðŸ˜ðŸ˜ -
Wood Bark, and just a little nominative determinism
FuerteStu replied to SteamyTea's topic in Boffin's Corner
This potentially opens up a whole new potential field of bio-mechanics to counteract climate change.. Surface area to volume, large trees are inefficient compared to other structures that could take up the same spaces. Just a thought
