LiamJones
Everything posted by LiamJones
Thoughts on how to finish this? Cut the rubber closure level, then underlay lead that laps the fascia? id like to have gotten the closure tight to the fascia, but there’s not enough material or flex.
Replaced the valleys with the ones you suggested @Dave Jones. Just waiting for the bottom closures to arrive and will have a play flashing the bottom of the valley. Probably with some lead too. just had another look at the photo above. I was going to install a gutter to the dormer, but I’m tempted not to bother now!
Thanks so much @Dave Jones @Mike. Thoughts on the dry valley closures top and bottom? presumably with counter batten, the valley would sit ontop 2 battens? As opposed to sitting on 1 batten for a normally battened roof. the valley is centered to the valley, I think the lead work in the photo is making it look like the center is off to the right, due to how the lead is formed over the tile
Hi, first time doing a roof and lead work. I’ve got a valley to work out, from where the hip meets a dormer. I’ve struggled to find any details online so have opted just to get a bit of lead up here and have a play. Am I on the right tracks here, before I bash it about anymore? Im considering cutting the fascia on the pencil mark, such that I can run that row of tiles under the fascia/soffit
If you want the best of the best, have a look at the BSPB turfgrass seed 2024 pdf it rates all the top grass seeds. You can then use this information to compare blends available on the market. Back in 2019 I used this information to decide on Barenbrug RPR sport. This was used in some premier league stadiums. https://www.thelawnforum.com/ Is a great resource
You may well need the gse mk08 top flashing too, I don’t have a part number for that. also worth mentioning the velux flashing kits are the specific ODL ones. I got the black ones ODL MK08 050001
They were quite hard to source. I couldn’t find any stock in the UK. I ended up going to midsummer and getting them to order in the side flashings from GSE. For the new v2022 frames and for the MK08 velux I needed the following two parts numbers, per window. ART105512 left ART105498 right i obtained these numbers from technical.support@gseintegration.fr who provided a BOM for my project, attached.
March this year. No idea about 300mm
I’ve got a quote from warmcel in Norwich. £19.25/m2 for 200mm
The resin fixings worked a dream, thank you!
Ah yes, good idea! I did suggest resin to the SE in the first instance, because that’s how I fixed my ledger boards. Thanks!
It’s this with the 4x2 swapped for 100x50 compacfoam
Structural engineer suggested Rawlplug FF1 10mm screws. Now fixing to the medium density 7.3n blocks at the threshold, and it’s cracked the block! Any suggestion?
Sliding Door Level Threshold Detail EWI
LiamJones replied to LiamJones's topic in Doors & Door Frames
So replace the 4x2 with 100x50 compacfoam? Resin anchors into the blockwork? 400 centres? I can’t find a detail from compacfoam for level threshold in EWI. -
ah yes, there is a 25mm PIR perimeter upstand -
That’s a good idea, but yeah afraid I’m already poured putting doors in in a couple weeks -
Just noticed I’ve drawn it wrong, the outside limestone tiles will be level with the top of the threshold, like inside. -
Hi. What do you think about this detail. 4m sliding doors to be installed 50mm out into the 100mm EWI. Supported by 4x2 screwed into masonry. aka picture frame. Level threshold in and out. Other options I’ve thought about, compacfoam (pricey), keeping door on blockwork (thermal bridge)
I wonder if you could have gone standard PIR in this kind of buildup, rather than the more expensive k5? What even is the difference?
Just used Cromer vent 3 pro. No complaints
I too am considering the rivius tiles. They look nicer than a concrete thin leading edge (TLE) tile, should hold colour a lot longer and weigh less. Only downside appears to be the cost. Best I’ve managed to find is 1.97ex vat a tile vs 1.16 for the TLE
Any updates to this thread, I too am now considering cladding over 100mm EPS EWI, but not much information is available online, relative to thin coat render. Got quoted £75/m2+vat for render. Weighing up alternatives such as cladding and brick slips.
Window fitting in an externally insulated deep refurb
LiamJones replied to saulgalloway's topic in Windows & Glazing
Hey @will_k back again with another question! Did you run the EWI up to the ply, or did you then run ~80mm over the top of the ply and window frame to create an EWI reveal? Struggling with this detail atm.
