MikeSharp01 last won the day on January 1
MikeSharp01 had the most liked content!
About MikeSharp01
Personal Information
About Me
I am a retired academic of 35 years, I have also run a couple of businesses (engineering) and had a short stint as a TV presenter - at the moment I amuse myself building a new home for my other half and I in East Kent.
Location
East Kent
MikeSharp01's Achievements
Advanced Member (5/5)
1.6k
MCS umbrella scheme. Anyone done it?
MikeSharp01 replied to flanagaj's topic in Air Source Heat Pumps (ASHP)
Yes because only they can get you the grant so they must do the design or sign off on yours, I put together a design pack for them to pick the bones out of to check and transpose the things they needed for the MCS form and no it did not really limit our choices. They would have been happy, I think, just to get the professional fees for the design and commissioning. I liked the look of their tiny ASHP so I purchased that and a stack of other components from them, sadly their cylinder was not suitable for our space but they rolled our Telford cylinder choice into the design even though we purchased it direct from Telford. -
No you would not, because there is also a bill to come from the umbrella company who need to do all the work of calculating the heat losses, setting the spec, providing the design, commissioning and signing off the system. In our case that was a big chunk. (Which we agreed before we signed up.) -
No I am not a plumber but I can plumb! I had the PHPP data which I sent them for heat loss along with a set of drawings and sections along with the air tightness certificate and they used that data to create the MCS form entries. I did the whole install and they came down, did a bunch of checks and signed it all off. Although I am emotionally with @JohnMo on not bothering with MCS I do need to get BC sign off and the part G cert so this was an easy way to get all that. We did make a small return on the grant but not after my time! -
We did it via Cool Energy. It worked well for us overall. The only issue is controlling their heat pump via modbus. The service was great. -
Clearance of Lindab gutter below roof line.
MikeSharp01 replied to peasthope's topic in Rainwater, Guttering & SuDS
Looks like you have identified all the issues and I can't see any reason why it cannot go higher. -
So what advantages does MCS battery install bring over a competent electrician.
Did you need to get your battery install certified or did you jusT plug it in?
Raft disaster! Help, advice and likely copious amounts of Gin needed!
MikeSharp01 replied to lizzieuk1's topic in Foundations
We used AFT for the house slab but made our own former for the garden room which we built prior to the house to prove all the techniques we would need. Cannot see any reason you can't make your own corners but getting the outer render on to match might be a bit tougher. -
Grid flex rhymes with derivatives trading: an observation
MikeSharp01 replied to DamonHD's topic in Boffin's Corner
Naturally - but you have spun out a whole other idea here - real time trading of energy consumption. I can imagine an AI agent getting control of a smart enough home to really drive down costs and consumption. Yes but if you achieve 80% cut in cost and use AI to control it why would you not. -
Very interesting, we are all going to have to get smarter in one dimension or another to manage this are we not? -
New self build design, heat and architect
MikeSharp01 replied to Jack757's topic in New House & Self Build Design
We just went through the summer with our build - not live-able but systems being tested, in the south east! We had the cooling running - just the slab and a bit of a windows strategy with our rear rooflight front floor light (What the other half calls the Rat window, because it will let rats in, - A top hinged window at the bottom of the front glazing that opens to create a stack flow through the house) open them over night and until the Outside / Inside temperature flipped over. (MVHR is not yet commissioned) It worked OK but getting control of ASHP was a pain and I need to work on that but essentially we kept the slab as near as we could to 18. We never saw an upstairs temperature, in the roof apex, above 27, never got to 29, for more than a few hours over the whole heat wave periods and downstairs we held it at a max of 24. So with more active cooling when we are living there I think we will be OK plus I have still to commission the Fan Coil Units upstairs. -
What drove this approach? -
Passiv house costs.
MikeSharp01 replied to Oz07's topic in Energy Efficient & Sustainable Design Concepts
Yes we managed 0.2 on the PH scale. It did need thinking through and attention to detail everywhere but it came out OK for us. We did all the air tightness work ourselves so did not rely on trades to do it. -
Ah - that was to address the issue raised by @Onoff at the top here and not have the groove running through switch as it is relatively small - I think the double sockets work with the groove running through. I could double the switch faceplate as all the switches in the house are on the mini grid system. So I could use blanks in the remaining slots as I only need three switches.
Yes, good point, the table in our case is going to be a shelf just below the plug socket and above the lamp / Network socket. There is only 300mm from the bedside to the in panel door edge so its a squeeze but does need thinking through.
