kandgmitchell
Everything posted by kandgmitchell
List of ASHPs with cooling capability
kandgmitchell replied to Stu789's topic in Air Source Heat Pumps (ASHP)
Quite! -
Well I raised potential cooling with the service engineer who came today. Mines a Vaillant and whilst it apparently can do it he didn't recommend it as the "underfloor pipes can contract and crack the concrete". I wasn't going for the sub-zero approach, merely say 16 degrees....... -
Well Scotland is certainly a foreign country. The English regs state that water use must not exceed 125 litres/person/day with a lower limit (as we have) of 115 litres if required by the planning permission. Never seen a minimum requirement but then few locations around here are without mains water.
First year of ASHP power use
kandgmitchell replied to Post and beam's topic in Air Source Heat Pumps (ASHP)
The pump came with the house package so there was no discussion with the installer prior. The didn't know me from Adam. The house functions well but with energy costs so high you have to wonder if the set up is performing at it's most efficient. Seeing other examples of energy usage for comparable homes does help to put it into context. -
Trouble is the installer does presumably do this but then leaves the system set as they feel is appropriate. A short briefing on the the operation, the manuals (mostly installation rather than operation)handed over then off they go. Two years down the line how does one assess whether that set up matches your lifestyle. Finding accessible information that is understandable to tweek the system is hard. Many posters on here have got a very detailed knowledge of the operational side of these units whereas some of us are loathe to fiddle too much; especially just before the heating season........ My last full year was 5210Kwh for all in power (no gas) in a 178m2 house with two people and the occasional guests. The next hi-tech addition I'm working on is clearing more plot for a washing line to reduce tumble dryer use! -
I think this just makes my point....................... -
This is what I find frustrating about heat pump installations and probably so do many other people considering them - you need a degree in physics to understand their control for the best performance ........ -
Those flippin horses can be mighty nosey........
But only if you were in the woodland or paddock. Not sure an extra couple of feet of glazing below an approved cill level is that material but agreed it does vary from the approved plans. This is exactly what I was trying to say - different people perceive risk differently. I'd run with this because a) the chances of someone seeing it are low, b) if they did, were they aware of the approved design in the planning application and c) should the planners find out are they going to have a meltdown and threaten enforcement?
I tend to use the assessment: would the planners have approved this if I had proposed this in the first place? In this instance I cannot imagine that if you had suggested the smaller windows they would have said "oh no they must be larger" and we won't approve the scheme until they are..." So, the chances of this change from a planning perspective not being acceptable are vanishingly small. Personally (and everyone's acceptance of risk is different) I'd press on and just ignore the change. However, to formalise this submit a VoC application to cover yourself but not stop building (they could take months to deal with the application). But and it's a big BUT - check the means of escape situation as mentioned above because that is a significant risk to the final approval of the scheme by BC.
Quite! One way is to have a drive around a likely location, you often get private signs put up with a phone number. Usually on the urban/countryside edge. Units on farms? Ask on a local facebook page? You need to get creative to find this sort of space, local commercial agents just don't handle it.
LVT Click flooring
kandgmitchell replied to Great_scot_selfbuild's topic in Wood & Laminate Flooring
We fitted Amtico floating LVT in the extended kitchen at our last house. The extension featured large bi-folds looking south across the hills, lovely view... However, the first summer it all buckled between the island and the bi-folds. I chased Amtico and they said the product wasn't suitable for conservatories, having pointed out that this was the ground floor of a two storey extension, they changed to . ..... we wouldn't recommend it in that location due to the heat. Eventually they sent a technical guy down to help the kitchen fitter and between them they glued it down in that area. -
Or use the exemption in Part 7 .... CLASS 7 Extensions The extension of a building by the addition at ground level of— (a)a conservatory, porch, covered yard or covered way; or (b)a carport open on at least two sides; where the floor area of that extension does not exceed 30m2
Generally storing a chattel on land that is movable does not require planning permission ( this is a basic response 'cos planning is a complex subject - national parks, AONB etc) so you could argue that your boat is a personal possession will be movable in due course, is not permanent and thus should not be liable to PP. It all comes down to the attitude of the LPA and how much fuss neighbouring owners make. On a piece of industrial land there are likely to be fewer complaints and thus little LPA interest compared to doing this on the verge in a Cotswold village. In the latter situation the LPA can be very creative in order to pacify the public and so the aggravation factor is going to be larger. Stick to somewhere where you will blend in more. My biggest concern is whether you have been instructed to build this boat and collect animals two by two in the anticipation of .................
Does this floor drain need a separate vent?
kandgmitchell replied to Jess Shannon's topic in Waste & Sewerage
That's not going to need a separate vent as a 50mm bath waste can run 4m without venting and a shower runs much slower. If that was a WC sat on that 100mm pipe instead of the shower trap there would be no question. However, consider a) access for cleaning the trap and that bit of 50mm pipe plus b) the 100mm branch cannot connect to the main stack closer than 450mm from the invert of the rest bend at the base of the stack. -
Kitchen exit door relacement
kandgmitchell replied to Dodbiz's topic in General Self Build & DIY Discussion
If this is a question about means of escape in case of fire, then kitchens are excepted from the requirement for ground floor habitable rooms to have an escape route through a hallway or a suitable window. Mind you I'd think about making that replacement window suitable to get out of anyway (especially given my cooking abilities!). -
ST don't allow building over for new detached structures if the sewer is 300mm dia or more. They may have been more flexible for an extension eating into the working area either side of the pipe. Thames Water for instance will not allow new works over their larger sewers but will allow extensions to existing dwellings. The neighbour may have applied for permission for the extension and have been granted it subject to conditions. The garage could have of course been done on the fly or before any stricter policy has been brought in. You will have some idea as to the depth of the sewer from the neighbour's experience. You could try an application stressing the nature of the building, the depth of the sewer and agreeing to remove the structure if major sewer works are required (and that's pretty unlikely unless it's your works that have caused it).
Percolation test on made ground - how deep?
kandgmitchell replied to Ed_'s topic in Rainwater, Guttering & SuDS
Good point, can't remember the last grey drizzly February Sunday afternoon, mind you I haven't been to Scotland for a while! -
How about suggesting to them a normal pipe away from the dwelling for about 5m or so and then swapping for a perforated pipe in a shingled trench lined with permeable fabric running to your "detention pond". Sketch it out, throw some rough figures at it and present it to the BCO. That's the only way to tell. Despite some horror stories most BCO's are pragmatic. At the end of the day as long as it doesn't undermine your or neighbours foundations and doesn't create a flood elsewhere then it ought to be ok. Given that next year is forecasted to be even dryer than this, then the neighbours will be wanting to dip their buckets in your pond! -
Fire Safety Regs - Timber Cladding
kandgmitchell replied to john0wingnut's topic in Building Regulations
Don't conflate the requirement for cavity closures as required by Requirement B3 - Internal Fire Spread which says: 5.18 Cavity barriers should be provided at all of the following locations. a.) At the edges of cavities, including around openings (such as windows, doors and exit/entry points for services). with Requirement B4 - External Fire spread which says: External walls on, and within 1000mm of, the relevant boundary Unprotected areas should meet the conditions in Diagram 11.5, and the rest of the wall should be fire resisting from both sides. External surface materials facing the boundary should be class B-s3, d2 or better. You will need to consider both (and both are complex and cannot be explained simply here) -
Previously unknown basement rears it's ugly head
kandgmitchell replied to kandgmitchell's topic in Basements
I'm sure I've seen some photo's but can't find them. They tend to show a forest of brand new screwjacks which I believe we have purchased. It's useful to have this sort of feedback as it demonstrates there are alternatives that need assessment before a design decision is made. Just to qualify my approach I'd say using foamed concrete would put an extra 3kN/m2 load on the existing basement floor/sub grade. I'd say that was pretty nominal in the great scheme of things and likewise, horizontal loading on the existing basement walls would be resisted by the existing external ground. Access to pump could be via one of the ground floor windows of the affected flat. Mind you if the costs come in too high it might be just as economic for leaseholders to club together and buy that flat leaseholder out. Remove the floor and put a simple steel stair behind the front door to give access into the basement. It's always worth thinking outside the box! -
Only one basement - the building was mapped using radar. Yes the liability extends to the whole building under the lease so all leaseholders will need to contribute. The initial advice from a firm of consulting engineers was very brief, virtually along the lines of "the beams are severely corroded and should be provided with temporary support immediately". They obviously weren't asked to suggest remedial works. The building and presumably now the basement is owned by a management company which in turn is owned by all of us 25 leaseholders in equal shares. It's down to us. The previous managing agent (part of a national property consultancy) basically told us all at a meeting that the building was worthless. When a couple asked what that meant for their mortgage and investment in their home the advice was to "hand the mortgage company the keys and default. You'll only be credit blacklisted for about five years...." The company then announced it didn't want anymore to do with the building and resigned their position. As far as we are aware only this particular flat is affected as it sits entirely over the basement. Personally I'm not entirely convinced that mass fill isn't an option. The live loads from a domestic floor are small, the dead load from the concrete could be reduced by using foamed concrete and I would have thought the total distributed load across the existing basement floor and the ground below would be well within the ground bearing capacity. I'm not wedded to that approach, I was just gaining other opinions to test my theory. I just want to be sure we are not being led in a particular direction to suit a single beneficiary with the additional costs of that being carried by the majority. -
We own a flat in the north-west in which our daughter lives. It's in an old red brick school built in the early 1900's and converted to flats about 25 years ago. Late last year a ground floor flat owner replaced some flooring and discovered a crack in the concrete which upon further investigation turned out to be a suspended slab over a basement no-one knew about. The developer had removed most of the external access stairs, levelled the ground and put a manhole cover over them. Roll on 25 years and when access is finally gained it is found the steel beams supporting the concrete slab have seriously corroded. So bad that emergency propping was required and the flat owner advised to move out. It appears the basement is entirely under that one flat. This has now blighted the whole building. Two sales have fallen through and no-one is able to move or re-mortgage. The managing agents bailed out as they felt the building was "too much of a risk". The insurers have wiped their hands of it saying it's a maintenance issue. That has been disputed with the ombudsman since the situation was hidden and no maintenance could therefore take place. A decision is awaited. The developer who was also the head landlord has gone into administration. That leaves us 25 leaseholders on the hook for repairs. I haven't been into the basement as yet but my first thought was to cut the beams out, drop the old concrete floor into the basement and then mass fill it with say foamed concrete topped with a slab. However, that suggestion has been poo pooed by the flat owner involved as they say they have been advised by surveyors and engineers not to do this as it would create "maintenance problems" (?) and cause damp in the affected flat, indeed no professional would be associated with any such proposal apparently......... As yet we await a formal suggestion as to how to deal with this but to be honest it has to be cost effective because we will all have to pay and some leaseholders are just young couples in their first home and we haven't got loads of spare cash lying about. Am I barking up the wrong tree with my idea (the volume is probably 4.5m x 5m x 3m) or are we looking at replacement steel beams with say block and beam and screed which involves much more labour?
Refer to Schedule 2 of the Town and Country Planning (General Permitted Development)(England) Order 2015 Schedule 2 Part 2 Class A - Erection,construction, maintenance, improvement or alteration of a fence, gate, wall or other means of enclosure. Para A.1 (b) says: [ development would not be permitted if] the height of any other gate, fence, wall or means of enclosure erected or constructed would exceed 2 metres above ground level; In the interpretation of the order it refers to height being from ground level and if not level then from the highest ground level. That would technically allow you to erect a 2m fence on the boundary but as mentioned above that could be overpowering for your new neighbours. Personally I would like to remain on good terms with my neighbours - it makes life so much more pleasant. Could you set any screening back from the line of the boundary so it lessens the impact?
We used GreenRaft for our build, helpful people and a good service. Supply only but using a straightforward, mostly mesh reinforced slab, we used local labour to cast it.
