Redbeard
Everything posted by Redbeard
  1. Hi. You say Is the wall in question rendered, or was that added as an extra variable? I would do 1 and 2 as you suggest, and add 2(a) remove render for approx 100mm diameter. Fill BIG gaps (should there be any, given a 'clean' hole?) with mortar. Allow to dry Prime area and pipe with air-tightness tape primer. Leave to dry tacky Apply one of the 'fluffy' a/t tapes designed to be plastered/rendered onto. (Pavafix Win or (?) Pro Clima Contega (?may have changed its name?). Lap the tape onto the pipe just a tiny bit less than the depth of the render. Apply render. Alternatively use an EPDM grommet but I have not yet refined the thought-process for ensuring that the EPDM square stays stuck to the wall. You'd still need 'fluff tape' over the EPDM anyway, so maybe this is a non-option. Your mention of render is not repeated in your 'steps', so I may have got the wrong end of the stick. Out of interest what do you mean by taping I am guessing: Bottom piece of tape Tape 2 above overlaps by say 15mm Tape 3 ditto Etc. That sort of thing?
  2. To how far below wall-plate/threshold? I appreciate you will need level access at the door, but I am never happy with the 'standard' 150 to DPC (/wall-plate in this case). No-one told the rain where I live that it can only splash up 150mm, so it does its own thing and splashes up 300.
  3. If you genuinely want uneven render on 'even' blocks you could tack expanded metal on with the odd spacer here and there, and apply the render more with rubber gloves than trowels.
  4. Remember, if it is next to another susp. tim floor which you are *not* converting to concrete, to bed ventilation ducts under the (insulation under the) concrete floor.
  5. Or you can turn it into an insulated solid floor (depends how fundamental your 'redo' is), and have none of the possible issues which can (sometimes) occur with insulated suspended floors even if you follow all the best practice guidance.
  6. If low cost is of the essence then 'contract matt' (once used by volume builders, AIUI, to allow painting a bit 'too early' over plaster - perhaps less so now with taped joints) is probably the one to go for. As @SimonD said, avoid anything with Vinyl in the title (and I think, but don't have evidence to prove, that anything 'silk' may/will be less breathable.
  7. Which is better than many (but not all!) built-up felt roofs, but my slate roof is 130+ years old. Yes, it has had repair, but none of it has had any more than patch replacement. I think the copper roof on my old school is probably 65+ years old.
  8. My first thought was 'yes, you can, but you can also paint jelly'. Slightly more context, yes the jelly would be less successful, but I always fight shy of building in a maintenance liability if I can. Can you reduce potential splash-up by, say, a small gravel-filled trench (even if not a proper French drain), take the cladding down to 150 above GL (The bottom plank may be 'sacrificial' as I would normally say 300) and just rely on the fact that you might not spend too much time lying on the ground looking at the orange bricks?!
  9. Yes, that's effectively the 'Tony Tray' that many on here have discussed. Arguably yes, though it won't be as perfect as a Tony Tray Which continuous top plate? Not sure I get this bit. Can you explain, perhaps with a felt-tip annotation?
  10. Good Q: *Looks* (I think) like a woodburner flue, but as stated above, that should be at v least above the eaves, and quite possibly higher still to avoid downdraught.
  11. I have no connection with them, but I was looking for an independent WUFI-wrangler recently, and Greengauge https://ggbec.co.uk were apparently helpful to the person I was helping.
  12. I am a little confused. The normal suspended timber floor consists of boards of some description directly over wooden joists (175 x 50mm is a fairly typical size but they may be smaller if they are supported mid-span). You say your floor is planks *over floorboards*, and you refer to the possibility of taking up the planks. My first thought/Q is whether a decorative floor has been laid over the original. Is there a 20mm step in the doorway? Pics would be great. Also how do you define 'wonky'. Loose, or far from flat (or both?). Or something else? The more info you can give the more accurate and useful will be the replies.
  13. 1st obvious Q: Is the old house to be demolished?
  14. Last and last-but-one pics - what will happen next?! The phrase 'hanging in the air like bricks don't' - with a little modification - comes to mind.
  15. Lead. Please. You could do stepped flashing or, if you have very good dust suppression on your grinder, do an angled chase. I prefer stepped, but cut-and-angled arguably quicker. Whatever you do it will get difficult as you get up neat the fascia. Are you already sorted for flashing at the top of the slope, at 90 degrees to the bit in question?
  16. It needs to be designed by a SE, I think. If the walls are entirely separate, and not adding strength to each other, I have a feeling 225mm will not be enough. My 1200 - 1500 wall is 600+ thick at the bottom IIRC.
  17. Can you clarify the depth of the PIR already fitted? To get a reliable 0.16W/m2K there should be at least 150mm total. I really do not like plasterboard/insulation laminates as you do not get a stab at taping the joints. When I did this sort of work I would (a) have tight joints unlike those shown (b) have taped all the joints on the (100mm) between-rafter PIR, then fitted 25mm PIR under the rafters, and taped) then fitted 25 x 50 laths across the rafters, with a further 25mm between, then finally a VCL ('ordinary' or 'intelligent', taped at all joints and perimeters) before the plasterboard.
  18. Good point! I was generalising, and thus including some reports which may have 'liability issues'. However it would seem to me that in many cases you are paying for the consultant's depth of experience in their field. If you are 100% happy that AI has the same effect then I guess that as long as the LA accepts them it's 'OK'.
  19. Do you mean Radon? And on the subject of your thread: I suppose the issue generally with reports is that they are 3rd party opinions backed up with PI insurance. I can see AI being your friend if it avoids you spending money but is it your ally when queries arise?
  20. Hello! Have you got any pics of the internals? From the inside do you see just the sloping rafters or, given that you say ...is there a secondary ceiling, whether or not it is plasterboarded? Internal pics will help us see how you could fit a lintel. Then you can take out the existing and fit a new uPVC window from outside.
  21. Gut feeling is that if it is EPDM it needs fixing with EPDM by someone experienced not just in new installations but in remedial work. Nothing wrong with bitumen/felt per se but I wouldn't mix it with EPDM. I cannot 'place' pic 2 w.r.t pic 1, BTW.
  22. Is it only me finding it v had to reconcile the text and the pics? I think what you are saying is that the hole we can see in the roof will accommodate a fixed roof-light in 2 panes? The details such as: I can't reconcile with the pictures. Watch out also for the lead staining the glass when rain runs over it. I hope I am not being unhelpful, but my little brain needs a bit more explanation to make full sense of this. The way the battens are cut suggests the glazing will sit below the roof-line, but then it will 'pond' at the bottom, so I must be wrong. Will there be an additional softwood frame for the glazing to sit in *above* the existing rafters?
  23. Don't hide the pipe? Paint to match background? Paint deliberately *not* to match background (as an adder, perhaps, if you like snakes).
  24. Was the title meant to be *pipe* clips and zip ties? I had assumed not and was waiting for an exposition on the myriad alternative uses for paper clips (apart from temp. replacement clips on split-link chains and repairing my reading glasses).
