Johnnyire
Everything posted by Johnnyire
Loxone Wallbox - benefits for Loxone Integration?
Johnnyire replied to Hilldes's topic in Networks, AV, Security & Automation
Dan, can you assist me not sure if you are a partner or not. I have a loxone wallbox and a single phase loxone meter, I am powering the wallbox with a ultra ev cable which has the combined CAT and power cable. Can you explain the wiring set up for this in terms of where the data cables need to go and the loxone meter? The issue I have is the wallbox is obviously powered from the consumer unit but I presume the cat cable needs to go to the Loxone panel or something? Thanks -
This is what the company have listed - They are 230v and I will be using the Nano2relays, I presume I can just loop the feed in to 3/4 fuse spurs and have a feed from each to the motor,Nano2,tree cable and feed cable?
If the electrican has the blinds looped you should still be able to feed each blind individually from a fused spur? I am actually using Blindspace too and have just started the wiring of the house.
Hope people can assist. I am intalling a loxone system and intend to use Nano2Relays for my blinds. There is a fed in from the board and looped to 3/4 blinds, so I will have the feed for each individual blind, a tree cable from the nearest RGBW spot, the blind motor cable itself and the Nano2Relay cable so 4 in total. My query is how are you meant to install a fused spur for each blind when they are looped? I was going to just have a single gang box for my collections and a blank plate for future access. I am not sure if it is regulation that you need a fused spur for each blind? I was led to believe the way I have described is how partners would wire it if using Nano2Relays? Any help would be great thanks.
I hope it is ok to jump on this thread. I am intalling a loxone system and intend to use Nano2Relays for my blinds. There is a fed in from the board and looped to 3/4 blinds, so I will have the feed for each individual blind, a tree cable from the nearest RGBW spot, the blind motor cable itself and the Nano2Relay cable so 4 in total. My query is how are you meant to install a fused spur for each blind when they are looped? I was going to just have a single gang box for my collections and a blank plate for future access. I am not sure if it is regulation that you need a fused spur for each blind? I was led to believe the way I have described is how partners would wire it if using Nano2Relays? Any help would be great thanks.
Sorry I did mean that but I was wrong, it is one window piece but still opens. Just means it's not two side by side so reduces the mullion by 105mm
Thanks for the comments. I hadn't even though about getting rid of the horizontal mullion, it was drawn like that in the plans by the architect not sure why and then the windows were priced based on this. We have two other windows with the horizontal mullion so I will ask them to get rid of this, dunno why I hadn't thought of that. Good point though, thanks for that. I actually emailed Internorm after I posted this and asked could I do the big window in one piece, they said they can make it as one window so think we are going to go with that.
Thanks for this, they do seem like a really good window. I have read about alot of install issues in the UK, I am based in Ireland so hopefully that is not the case here. Good to know about the sides and top, thats what I was hoping. My only concern is my big windows will have 105mm + 105mm side by side so it will be thick as shown in my pic attached.
Thanks I will query this sealant when the time comes, or even better before I place our order. I have priced around and Internorm are competitive with alot of other brands who supply polish windows. I haven't seen any pics of the KF520 installed, we only saw it in the show room and when I have asked the agent for pics they struggled to get any from installs. I don't think many get this window, I am based in Ireland so might ask UK suppliers for pics.
12V batteries for Loxone Power Supply and Backup
Johnnyire replied to Thorfun's topic in Networks, AV, Security & Automation
Have you solar and a battery? I am building and installing Loxone. Was thinking I will get the Gateway with a Sigenergy system so can run the house if we lose power. -
Thanks Russell, I will email them now to confirm. Do you have the KF 520 window?
We are thinking of going with Internorm KF 520 windows, has anyone pics of them installed? We saw them in a showroom and they looked great however I would like to see how thick the frame is, can it be hidden in the cavity? Also I have one massvie windows so will be two sections, id love to see how the frame will look at the joint? Thanks
What EWI for 1930s solid brick (215mm) wall home
Johnnyire replied to tanneja's topic in Heat Insulation
@tanneja Did you go with the KF520 windows? We are looking at these and would love to see pics of them installed and the frame width on the outside if possible? -
MVHR Options
Johnnyire replied to Johnnyire's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Thanks everyone, I think I will go with a self-install. The prices are a few grand cheaper for a self-install which includes the Zehnder system. -
Hi all, Getting quotes for a MVHR system in my build. I am installing a Loxone system if that has any relevance. Basically should I get a system which has sensor in the ducts? Logically thinking it makes sense so if someone is in the shower or bath the system know, why wouldn't I go for a MVHR that doesnt when this is an option at no extra costs from what I see? I was thinking of getting the Zehnder system from BPC and doing a self install, what are your thoughts on this? Any advice or guidance? If I do a self install I will need someone to commission? Is the cost savings worth it? Also the Zenhnder when supplied and installed is a few grand more, it is hardly worth that?
Blinds that are compatible with Loxone
Johnnyire replied to Dunny1234's topic in Networks, AV, Security & Automation
Just in relation to the cons, does the Nano 2 relay not do point 2 & 3? "The Nano 2 Relay Tree automatically detects the end position of blinds. This not only saves a considerable amount of time during installation but also saves tiresome recalibration of the travel times. Due to the fully automatic end stop detection, the current position of the shading is displayed immediately and accurately within the app. " -
@Andy I think the Faradite is alot nicer looking but am curious if it is an option instead of the loxone flush mounted presence sensor. I guess what I am wondering is, would it be better having a presence senor rather than a motion sensor in areas such as the living room, study room etc. In my halls I hope to use the Faradite sensors. Any advice would be appreciated?
