trialuser
trialuser's Achievements
Regular Member (4/5)
24
Do goats respect electric fencing, or snazzy geofenced shock collars?
We're in a blue tongue temporary movement restriction area. You are slap bang in middle of the the D&G cases. I don't think you can move goats onto or off your property at the moment, but you may be granted a licence. https://www.farmersguardian.com/news/4361142/bluetongue-updates
Texecom home security products
trialuser replied to SilverShadow's topic in Networks, AV, Security & Automation
Perfectly put. In the past Texecom have had loads of trouble with power supplies and batch troubles with various detectors. The app is old fashioned, so are the keypads. You can join their own forum and see what people are moaning about. I have had two texecom system for the past 15 years which I add to and 'upgrade' now and then and it hasn't moved on much at all. I don't love it but it does work as an intruder alarm though but has never been triggered in anger. You can often find their stuff new old stock on ebay. -
There is loads of info on the internet about using mismatched panels, presumably in series, apart from the fit aspect you need to consider the electrical side. It may be the case that your existing panels pull the output of the new panels down considerably and you get little benefit. You also need to consider the max input voltage for you inverter if the new panels are significantly higher.
In my view that drawing is not intending to show a stepped footing, it shows footings at different depths. Where the section 'sections' the building there are no footings other than those show. To see the details of the step it needs to be a simple diagram side on of the trench / footings, or a section in the same plane through the side wall perpendicular to the walls shown. Not sure I'm explaining myself very clearly, but that section is through the (say) middle of the building, the step in the footings will be in the walls that join the two walls shown, I think!
water pipes underfloor: conflicting advice: help sought.
trialuser replied to saveasteading's topic in Barn Conversions
I didn't know this, and didn't do it. Can you provide a reference or link to the relevant section in the building handbook / approved docs. I've looked but I can't find it. Thanks. -
If you haven't got an EV they might catch up with you. I believe their terms and conditions say that they must schedule a smart charge at least once a month (from memory). If they are unable to communicate with your ev, or your charger that is talking to your ev, they wont be able to schedule the charging slots. They say they move you onto the 'go' tarrif if they can't schedule intelligently.
Fire Stop Locations for Timber frame with external cladding
trialuser replied to HanleeHouse's topic in Timber Frame
? Unless the cavity also needs to be ventilated? I had to use intumescent stuff, cant remember what it was but cost a fortune. I could use wood fo vertically aligned stops. -
If you find out, pleease post here. I bought one from ventillationland, and the firmware / deep settings web server page is in Dutch. It's a bt inconvient as I had to use google translate, but once you have had an initial fiddle, it doesn't really need touching again. It also does not have a front control panel, you have to control it by the app (in English) or a 4 way rotary switch to change the flow rate. Most would probably fit these where it would be inconvient to use the front control panel anyway. Mine has been running flawlessly for a few years now, the humidity sensor ups the flow rate if it thinks it need to, I just change the filters now and again. If it packs up I'll either try and repair it myself or buy another. I realise the lack of support is a downside, but I only have to answer to myself, not a paying customer. I suppose the language thing must just be a different firmware file, and there is a usb socket presumably for updating. The CVC one seems the better deal, especially if it is legit. Perhaps also consider the plus version, I can't remember the difference but at the time I thought it was worth buying.
Hi, is this definitely a 4G comms hub? I'm in Scotland (arse end), and unsuprisingly the LRRN hub failed to connect. I pestered them and they installed a GSM hub, but I believe it is 2 /3 G. I still dont have a signal as the meter/hub is in a steel clad outbuilding. I'm now pestering them to fit a T3 external antenna, but a 4G comms hub would also be preferable as the 4G signal hee is great. Thanks.
- 70 replies
- utilities
- electric bill
(and 3 more)
Would you recommend a Brink Flair?
trialuser replied to Philxyz's topic in Mechanical Ventilation with Heat Recovery (MVHR)
I bough what I now asume was a grey import and the built in web server setup page is in Dutch, I can't see an option to change it, but there is an option to upgrade the firmware via the USB socket. I don't know where to get the firmware though, it's not on the Brink site that I can see. It also doesn't have an front control panel so all control is from the app or the 4 position switch. No a huge issue as when it's setup and running no real intervention is required. I didn't realise it was a grey import when I bought it. I'm happy with the performance, seems to just work. -
Not saying this is right or wrong, just an observation, but. I imagine you reasoning is to deprive a fire of any fresh source of oxygen? But given that in fires, people almost always die of smoke inhalation before they are roasted, might it be a good idea to leave the ventillation going to remove some smoke and introduce some fresh air? Or perhaps fire is known to travel between rooms in MVHR ducts? Although most will be a star layout to a distribution manifold. Genuine question.
I haven't read all of this thread, but here is my tuppence. I have a dry ouput of my fire panel (so you could use a relay if not using a panel) connected to a zone in my intruder panel and programmed as fire. I then get a notification if the zone is triggeered in my intruder alarm app (Texecom) You could also use outputs from the intruder panel to switch other devices on or off, via relays or not, depending on the device. In a previous house when the kids were young, I has 5mm leds in the ceiling every meter or so from bedrooms to exit doors which were switched on in the event of a power cut or a fire activation. They had a 48hr 12v battery backup power supply. Seems to work ok.
Ecodan immersion replacement - help
trialuser replied to Tadpole's topic in Air Source Heat Pumps (ASHP)
I agree with you, that is exactly what I have done, although you may be replying to the OP -
Yes there is a seperate thermostat - but Mitsubishi call it a thermocouple so I suppose it is not just a bimetallic type thermostat. It measures the temp of the water and passes it on to the controller which then decides whether or not to switch the contactor depending on what temps / settings are programed. Not sure where it is. On mine, the only feed to the immersion is via the diverter so it can only switch on when electricity is being diverted or if I switch the diverter to manual overide.
