IanP
Personal Information
About Me
Starting another self build (my 4th!) in Argyll soon.
Location
Near Tighnabruaich, Argyll
IanP's Achievements
Member (3/5)
0
Apologies for resurrecting an old topic, but we are getting to the stage of getting the roof (sips) on and then getting the Solar installers on site to fit our trays as we wanted the array to fit nicely around 3 velux's (MK08's). I have lost count on how many people have said you cant have a velux in the middle of a solar array... when I show them the GSE literature i never hear back from them... It just feels like we are the first people ever to do this! This then makes me worried as no one has fitted any like this around me (West Scotland) and worried when it comes to installing they wont have a clue or start ordering the bits needed as they go along! I know there is technical help available from France, but it would be good to have someone in the uk to at least talk to on the phone to reassure myself and the installers... Does the use of the ODL? kit mean that you dont need the standard flashing that Velux sell? All sounds very scary at the moment as still not convinced that the apertures in the Sips roof panels are going to be in the right positions.
Hi, Anyone out there that knows the current Scottish Building Reg for height of Garage floor when garage is integrated into house? I was planning on a step down of about 190mm at the internal door end and then a 1/80 slope down to the Garage door. Finding it difficult to find it specifically noted in the regs.
MVHR Installation and Commissioning
IanP replied to IanP's topic in Mechanical Ventilation with Heat Recovery (MVHR)
Thanks for the replies and comments, guess I will give it a go then when the time comes and it can't come soon enough, been stuck in this caravan for 18 months already thanks the the two architects we have had that have been useless. Still not out of the ground..... one day soon I hope, just getting as much sorted upfront as I can. I remember how the decisions are needed thick and fast once underway. -
Hi, I am looking again at sorting out the MVHR system of my new build and have a number of quotes. BPC in Ireland seem to come out cheapest and thinking of installing myself. Anyone had dealings with them? Is it a simply task? I am quite hands on, so able to do a lot of things to save the pennies. One thing tho is the commissioning..., is it easy to find someone to commission it ? I am in Argyll, Scotland and not sure if companies are willing to commission systems not supplied by themselves. Or is it possible to DIY the certificate to give building control ?
Trying decide on 2 quotes one from Paul heat recovery with a Zehnder ComfoAir Q350, other from Mark heat recovery with the Vent Axia sentinel kinetic highflow. The quote with the Vent Axia is much cheaper, but wondering if it's a lower spec unit. Anyone with experiance of the 2 suppliers? Planning on installing myself and getting them to do the commissioning.
Render on Renderboards..tell me why I shouldn't
IanP replied to SuperJohnG's topic in Plastering & Rendering
@SuperJohnG how did it work out for you with the tender boards? Curious to know, as I too are on the west coast and at the same position you were when starting this thread. I'm undecided as yet if better to go for a solid outer skin over sips or use render board. Got about 80m2 to render and about 150m2 to clad in wood. Even considering using facing bricks and block under cladding and not have to go to the expense of tender after reading some of the comments on here. Anyone got any m2 budgeting figures for methods mentioned? -
Yes, but like the simplicity of Sips. Last build was a traditional tf 20 years ago and was a faff installing all the insulation and Kingspan. Hearing now that Sips Eco panels may be better value than sips industries but still waiting for their reply and not sure if should get a quote from Eco Sips homes too. (very confusing with the 2 companies having almost the same name)
Finally got planning approval for a build in Argyll, now deliberating over what company to go with for the Sips. I have a quote from SIPs Industries and thinking of getting from SIPS ECO and EcoSips (confusing names as they are all located so close to each other too). Architects as pushing for me to use Caberhouse (links to Architect company...) but I'm sure any of the other 3 companies will come in at a better value. Anyone got any thoughts on these companies? The quote i have from SIPs Industries seem high, £145k (incl erection) for a 232m2 build but guess prices have gone up a lot these days. I was looking for a low U value of around 0.13 with 50/50 render board and wood cladding, but been reading a few of the postings tonight on the Mortgage lenders angle of then wanting a block outer skin.... now wondering if i should really consider this. Hopefully don't need a mortgage but...... Keen to get moving on these decisions as don't want to delay the build any longer. Interested to hear peoples thoughts.
Any Scottish builders out there who have recently had a meter fitted? I have just spent several thousand getting Ssen to put a supply in to a shed for a temp supply but when I rang up Scottish Power for a meter, they said as from Apr 13th Scottish Power don't install temporary meters!!! Only permanent ones as they will not move it to the house when built! Any recommendation for a supplier who will?
I am planning the wiring in my proposed new build and wondering what the best way to install lighting circuits would be to help try and future proof it and allow for smart controls. I want to have some 'smart' lighting and looking at using HA to manage it all. Three questions pop up, 1. Is it better to wire all light points and switches (3c+e) back to a central distribution / control panel so you can have full control over what does what and install shelly relays etc in the one panel? 2. If so, Anyone got any enclosure recommendations for DIY build (rather than buying a dedicated Smart Home lighting panel), that allow din rail install, connection blocks and space for relays? 3. Would it need to be a metal enclosure? Thanks in advance.
new build with 2nd consumer in attached garage
IanP replied to gravelrash's topic in Consumer Units, RCDs, MCBOs
I am looking for a consumer unit that I will use use on the temp supply to my static whilst building and thinking it could then be used in my workshop once the main supply is moved to the house. Would a AC rcb be ok or does it need to be a different type for the temp supply? -
I am thinking of using the GSE frames, but finding it difficult to find out which size frames (as not decided on which panels to use yet) integrate with the Velux adaptors. Is the Velux integration kit a 'one size fits all' or are there different sizes to tie in with the different frame sizes?
Hi, Wondering if there is anyone in or near Argyll nearing the end of their builds and have a static (30x10 ideally) and or Shipping container that the will be wanting to sell anytime soon?
