Alwayslearning22
Everything posted by Alwayslearning22
  1. Anyone any experience with the Kudos 2 panel folding bath screen? Are they prone to leaking. Saw this video on YouTube and putting me off buying it. It would be a problem solver for me if I works the way it supposed to.
  2. Thanks for the reply. I was thinking of cutting it flush with the reveal like you have suggested. I wonder would it be difficult to get out the remaining sections that the plasterboard are sitting on without too much damage
  3. Hi guys, I’ve a plastic window board I’d like to replace with a mdf board. Is it possible to replace it without damaging the reveals? How would I go about it? Ideally I’d like as little damage as possible as it walls were recently painted.
  4. My radiator was leaking for 24 hours on my new laminate floor and seeped under mdf skirting boards. would a dehumidifier dry out the water under the laminate and skirting boards? I really don't want to lift the floor and skirting boards, but i worry about mould forming behind skirting and underneath floor.
  5. I don’t have a long enough level to check it. Is it possible that a new door frame is bowed? Would it be caused by poor fitting? thanks
  6. Hey folks I had a Upvc door replaced as it was “bowed” and wasn’t compressing against the frame enough to seal it. I’ve just noticed my new door has exactly the same issue as the old door. I’m wondering now is it a fitting issue instead of a faulty door. It’s tight at the top and bottom but not in the middle. I’ve cam rollers adjusted fully tight but the new door still isint compressing tight enough. I find it odd that the new door has an identical problem to the old one. Anyone know if this is an easy fix? p
  7. Hi Marvin, thanks for taking the time to reply was very helpful information. You’re right about the instructions I think id struggle installing that to be honest. What screens do you recommend? My shower is very high pressure and the problem I have is, a normal 800 wide screen will not keep water in the bath. I can’t use a wider one as the toilet is at the end of the bath and this could be a hazard climbing out of the bath due to so little space. Here’s a photo of another bathroom to give you an idea. I’ve less space than this. Thanks for your help
  8. Anyone ever fitted one of these? Do you know if there any good? I’ve been told bath screens are famous for leaking?
  9. Hi folks I have had a new door fitted and the guys that did it weren’t the best. The house is owned by a housing assoocation and they don’t care too much about there houses to be honest. I’ve attached pics of the way it was fitted. it’s a Upvc door set and they fitted flush to the vertical battons no problem there. Then they propped up the bottom of the door which has a low threshold attached to it with a Batton. They didn’t use a sill. told me didn’t need one and batton will do the job. Is this done correctly? As it’s a bit draughty I’d love to improve it to be more airtight.
  10. Is it ok to seal around multilayer pipe with silicone sealant? I read on uponor's website that you should not use silicone sealant on there multilayer pipes as it can damage the pipe. I've sealed loads of pipe penetrations in my house with silicone and never knew this.
  11. Good afternoon lads, I'm preparing to install some outdoor Poe Cameras. I've some spare conduit/ducting going through my wall, its inside a box on the side of my house and ends up under my stairs were my ethernet cables terminate. could i use this ducting for my camera cables? would save me from drilling a hole through the house, im planning on having the nvr in there anyway. I'm wondering how i would get the cables inside the outdoor box though without it looking like crap?
  12. thanks for all the replies lads. some helpful tips there to improve my security which i will implement.
  13. I probably am overthinking it. Still though what's the point of security alarms if they don't actually work. What I worry most though is someone entering my home during the night when my family is sleeping. That was the main reason i bought my alarm.
  14. I've been thinking about home security recently. its got me thinking that my home which i thought was secure may not be at all. I have a Hkc alarm system which is supposed to be a good alarm. what worries me though is the alarm panel is near the front door. what's to stop a burglar from just ripping it off the wall and throwing into water? would the internal/ external alarm sirens still sound if this were to happen? my house has thumb turn locks with a letterbox and I've just saw videos of people using tools to reach through the letterbox and unlock the front door. So a burglar then has 30 seconds entry time to rip my alarm panel of the wall then there free to walk around my home. could this actually happen? or am i worrying for nothing? If anyone has any good suggestions to improve my security I would be grateful.
  15. Ok so it makes sense why its not water tight around the inner seal. I've the door compressing a bit tighter now although it doesnt look water tight to be honest. As i said above the sealent at bottom of the frame is peeling. that could be my main problem area?
  16. thanks for the reply. actually that makes sense. I have the door compressing tight now at the bottom it wasn't very tight. I have noticed that the bottom of the frame had some sealant where it sits on the threshold but that's peeling away. I'm thinking that would allow water to enter the threshold. would it be a bad idea to run a bead of silicone along the bottom of the inner seal and frame, to stop water from getting inside?
  17. thats actually the sill you see outside its all in one. threshold/sill. ill get a pic tomrorow when its light
  18. My front door is letting water in when it rains heavy. The water gets into the threshold and drains ok but if too much water gets in, it finds its way into the house filling the channel where the inner seal sits and over flowing into house. Anyone have any idea what I could do to fix this issue. I marked with a blue line in the picture where the water seeps through into the house, fills underneath the channel where the seal slots into.
  19. Thanks for the reply would of been handy though if it existed
  20. Hi bit of a strange question. friend of mine bought a house a few years old. House was plumbed for an en-suite but never connected ( pipes are inside walls supposedly) is there anyway one can get a hold of the plumbing drawings somehow? For an older house? would make plumbing the en-suite handier he thinks.
  21. yes my house has press fittings but also they have used compression. I'm in Ireland, I think its an Irish company probably not very popular. They sell an adaptor/insert that can be used on standard compression fittings. looks to be very handy especially for the DIY type like me.
  22. thanks for the reply. Sanbra Fyffe Instantor
