Everything posted by Susie
Your welcome another time, DM me when you’re free.
Solar PV, more cladding and my first plasterboard jointing.
Susie commented on Susie's blog entry in The Old Cow Shed
Update on costs so far B/f from previous blogs £212983 I added the windows in twice when paid for and in the window blog, -£20869 B/f should have been £192114 Solar internals final fix £4217 Render £3090 Consumables, insulation, electrical and alarm £3450 Total cost to date £202871 -
We are mixing two widths so we get a little wriggle room so far we’re ok see the blog for pics.
Susie posted a blog entry in The Old Cow Shed
Weeks 35 to 39 The build is close to our existing working barn and home, close enough that as a Cow Shed power and water was fed from the working barn. We have renewed the power cable and water connection so that the new build with its 7.5 kwp of solar can power the working barn. With the solar on the roof the plant room became my priority to get the CU and wiring ready for the solar installation to continue. This meant us plaster boarding in the plant room, a new plaster board lifter up to 16ft for some rooms, and me watching loads of U-Tube and learning a new skill of paper taping and jointing, drylining. We have knocked old plaster off solid brick walls and put up a small amount of square edged plasterboard for a plasterer back in Manchester but never used tapered edge plasterboard or had to think which way round is best to hang it on stud walls and around windows. To make things a little easier for a first timer I used ready mixed Knauf Fill n Finish, this sanded easily and I didn’t have to waste time thinking about the consistency of the mix. I really enjoyed the process, I wasn’t quick, I wasn’t perfect, but the end result is very good. I did get a few blisters in my first ceiling joints, but I know why and I solved it and overall I quite impressed David with my new skill, so much that later on I can do other more important rooms. The main problem I had in the plant room was its size, a small room with a high ceiling in parts, the tall step ladders wouldn’t fully open width ways and then when they did open fully I was not close enough to the wall/corner. Just moving the ladders around was muscle building but our smaller ladders were not quite tall enough. Once I had painted the walls I handed the room over to David to do the wiring. Back in Manchester we have an Industrial and Commercial Electrical business and David was the NICEIC qualified supervisor for the business, he has now handed that role over to his younger brother but still has the knowledge (once checked the new regs) and skill to get the plant room wired ready for the solar to be finished. That meant he had to stop cladding and come inside the build so I went outside to get ready for the renderers who were coming to render the North wall. Due to the change in ground levels around the building, as it’s situated between the field and the concrete farm courtyard, I wanted to protect the walls with stick on waterproofing, that the renderers batten over. There are so many variants out there of sick on or paint on waterproofing membrane but not many that say they have no solvents or can be used on ICF, most of the small print says block or concrete. I chose Newton Hydrobond SA as it acknowledges its use in ICF builds, but the warranty is provided by the waterproofer ie me in this case. Once the soil is level with the build there will be a gap between the ground level and the render I hope to stick on the roofing slate I have saved possibly with tile adhesive. The walls currently being clad will also eventually be waterproofed below the cladding but I didn’t want the stick on membrane getting damaged and the ICF needed protecting from the sun so as a temporary measure for the ICF walls and a permanent solution on the concrete dolly block, in the area we park the cars I have painted on a bitumen membrane. David will love that I am now sharing my ‘kitchen utensil methods’ with you all, for the sticky black paint I used a washing up dish brush (also good for patio grout, and bathrooms), Its stiff bristles worked the paint in well and long handle kept me relatively paint free and I can also recommend a spaghetti measure that has various size holes and spoon end for stirring paint but his favourite one was me tiling the bathroom and trying to get the grout up between some wood cladding and a tile, a wooden spoon was used, in my defence I was very tired. So now I’m back collecting stone from our excavation piles to fill the gabions and next week when the weather is not supposed to be as sunny I shall be inside continuing with the insulation I’m on my 3rd pallet of Rockwool and soon will have completed two thirds of the roof, next is PIR insulation. A bread knife is great for this as I have to cut various shapes out of the insulation for the eaves, steel ridge beam and the join of the flat ceiling collars to the sloped ceiling rafters. Before the windows were fitted the openings were covered in roofing membrane so this was a cold job and the daylight hours limited my progress, now I’m extremely hot in the loft wearing a polo shirt as protection against the itchy insulation. I’m nearly done for now as I can’t reach any higher in the vaulted lounge/kitchen until we insulate and screed the floor then I should get another row completed before handing the job over for the last bit of insulation and the plastering from off a scaffold tower. May 2025 front cladding completed and March 2023 before we knocked down. -
Rafter spacing with internal dividing walls?
Susie replied to Digmixfill's topic in Roofing, Tiling & Slating
BC need to know the size of the new rafters and roof design and that it will all hold up the weight of the roof covering, and amount of insulation, warm or cold roof ventilation, getting the roof signed off as completed is one of their checks. -
It sound like you have plans submitted to BC and have now decided to change the roof. If that’s correct if you are changing more than 50% of the roof you do need BC approval of the work. It sounds like you need to check with your local BC before you go to far. -
As someone currently trimming Rockwool about an inch to fit between the rafters I would consider what insulation is going in, on or above etc, especially if you don’t need rafter spacing for the plasterboard. Do you not have drawings of roof spec for building control? -
It looks like we’re thinking the weekend 21st/22nd. either date is fine for me, if anyone has a preference or we can wait until nearer the time and check the weather.
Cornwall show is on 5, 6 and 7th June so traffic will be bad then, for any one driving up via Wadebridge. Sunday 8th is ok Saturday 14th is ok Sunday 15th is Fathers day Saturday 21st, Sunday 22nd both ok Saturday 28th, Sunday 29th both ok Anybody have a preference @SteamyTea. @BotusBuild @Gone West @Omnibuswoman
Would any BH members like to meet up at our build. As mentioned in my blog due to our geographic location I found visiting shows and suppliers difficult so if anyone else in the South West wants to see the options we have chosen so far or it would be great to chat about everyone’s experience’s on their builds. The renderers are due to start next week, 8th May but we are still slowly cladding 3 other walls in wood. Inside it’s mainly just the ICF walls except the plant room which is half plasterboarded and the solar will be finished soon and CU is in place getting wired up by my husband. The blog is nearly up to date, I shall update and show off my new dry lining skills soon. Dates are flexible, week or weekend, day or evening, May or June. If weather is nice to us we could have a BBQ. Plenty of parking available. Add your thoughts and suggestions to this topic and I can PM you the address. Susie
Weeks 27 to 34 Cladding After securing our planning permission I arranged for a few samples of wood cladding from various trees and from a few different suppliers. I propped them up in the sun and watched for months as they changed colour and silvered off. We made a short list of which we liked, something with a definite grain pattern so not Poplar, not too knotty so not pine, thermally modified wood as it is less prone to shrink and swell and as it’s no longer sappy less interesting to insects and lighter for handling. We also wanted tongue and groove with secret fixings through the tongue and minimal fixings elsewhere if necessary, this often varies by supplier some say screw, some nail very few actually say nail gun as it can damage the brittle wood. We decided Ash was our favourite and got a few quotes from different suppliers, unfortunately when the time came to order prices had increased and we had to rethink as delivery became a big problem. We wanted it delivered by Hi-ab but most said the charge for hi-ab to us would be quite expensive or that they didn’t offer that service or it would be delivered to a hub then onto us and they couldn’t guarantee against damages. Read the delivery small print if you are thinking of having wood cladding. As it’s just me and my husband we weren’t looking forward to manually offloading the wood whilst the driver was waiting to make his next delivery and as no specific time frame for deliveries were available we couldn’t arrange for help offloading. A local company in Somerset could deliver by Hi-ab at a reasonable cost but it would be knotty pine. We really didn’t want pine but as it was cheaper and the delivery method ok we reconsiderd but still couldn’t make that final decision. Then I found Russwood after initially discounting them due to the fact they are in Inverness and we are in Cornwall and at the time I had at least 4 other companies all based lower than Birmingham some much closer to us. I spoke to Russwood and discussed delivery with them and discovered they deliver by Hi-ab on a big double length trailer but arrangements could be made that half of the trailer was left in a local lay by if necessary and our wood came on just the front half. They offered us Thermo Pine but it is slightly different the knots are fewer than on other pine samples we had from other suppliers Russwood describe them as butterfly knots, through the length of the knot rather than across the heart (round knots), you do still get some round knots. The tongue and groove is better designed in that each piece is fully pushed to the next but on the hidden side has room to expand. Most other tongue and groove needed a few millimetres between each plank for expansion which would slow the process down of putting it up and a bit more fiddly in general. Another difference in our wood is the face edges are rounded it gives a slightly more finished wood that could easily be used internally as well. As we we’re saving quite a bit on the Ash price we decided to over order enough that we can use some on the overhang, I don’t think we know yet how much spare wood we will have. A few comments from my husband are that it goes up really nice, screwing in the groove on the tongue with electric screwdriver so most fixings are hidden. It’s all fairly straight and not warped, some damaged pieces by handling but can be sorted into useable lengths over or under windows for example. On a sunny day he is enjoying this job. Cost to date Brought forward £207626 Cladding £5357 Cost to date £212983 I have noticed the Suffolk meet up chats and thought that If anyone is interested I could have an open day once we have done some more cladding and the rendered wall is complete and hopefully solar installation finished. The renderers are due to start soon so I was thinking May or June. It will only be for Build hub members so just PM me and we can all discuss dates that suit a few of us. If nice weather BBQ outside in the Bude sunshine.
Another vote for Norrsken you can read about the installation in my blog.
Have you got room for a turning circle or hammer head turn as fire appliances are not allowed in to reverse so far.
Weeks 24 to 27 Windows Installation Choosing window style and supplier has been one of the hardest decisions. We finally decided on Aluclad wooden windows from Norrsken. It’s been a long journey and Norrsken have been with me on that journey since December 2022 to installation end of February 2025. A big thank you to Nick at the window company for sticking with me on my numerous window quotes, that took over 2 years to finalise. Due to my architect not thinking ahead how Part O would effect the design, the windows had quite a few changes and quotations from a few companies. In summary Part O (Overheating) was first published in December 2021, we didn’t submit plans until May 2022, we passed planning in October 2022. Then we realised that the original design wouldn’t pass Part O that’s when I started understanding that in my opinion the architect should have been planning ahead and designing with Part O in mind. We had an overhang in the design but not large enough to qualify as shading for Part O calculations. I spoke to a local company who could do the Dynamic modelling route to pass Part O but they had a backlog of customers who like me needed help to pass Part O some of which we’re probably going to end up spending thousands on solar glazing and various other mitigating factors. The company suggested I look at the simplified version first which basically is a spreadsheet on which you enter your room sizes, window sizes and orientation of the building. Although our windows were not too big the daytime overheating looked like it could be managed by tweaking window sizes a bit but nighttime bedroom overheating was more of a problem because we are a bungalow and the windows needed to open for ventilation but also be secure overnight against intruders whilst we slept, Part O offers some guidance and I found future homes https://www.futurehomes.org.uk/library#Guidancetoolsandtemplates particularly helpful. In the end we settled on replacing 4 windows with 6 large Velux windows that allow for more air flow and by changing some windows to tilt and turn inwards this allows the bedroom windows to be safely partially open in the tilt position whilst still being secure at night. We had to go back through planning for the window changes but the architect did the amendments free of charge and the revised plans were passed in May 2023. I’m happy with the end outcome. I still have lovely big picture windows allowing viewing far into the distance and without any glazing bars. The opening inwards will allow for easy cleaning, but cleaning is a long way off. The Velux windows free up room for kitchen wall units where we previously planed to have non opening windows. A Velux in the pantry as well as freeing up wall space for shelves lets more light in and probably will result in less switching a light on and off. The house is designed for us in that our en-suite is larger than the bathroom shared by the two guest bedrooms and by changing that window to a Velux it allows for a shower area that doesn’t have a window sill almost in it. I started researching windows quite early on because I wanted to make the most of the views but also I expected it to take a while actually getting round to see different companies. We moved to Cornwall to start a new business, have a field for our Greyhound to run in and be a bit warmer and sunnier than Manchester. I love living in Cornwall but it does have its downsides in that we live one and a half hours away from a motorway, our local home building shows are smaller than one hall of Birmingham NEC. We visited some of the local window suppliers but we mostly got to see one small window or a cut away demo window for each supplier and they didn’t offer a great deal in choice, mostly double glazed not triple glazed samples. If we went away for the weekend I would try to find a larger showroom we could stop at on the way, luckily for us Norrsken has one showroom in the UK near Bournemouth that we stopped at on the way to The Isle of White. We decided to get the window openings measured by the supplier, it cost approximately £800 for this but it was worth it. I had some questions about window opening sizes during the build before the concrete pour and Nick helped answering all my little questions, he knew how the window sizes had been changed to pass Part O. Even though the person sent out to measure ended up having a hour and half travel delay he still spent over 3 hours measuring and discussing the window location within the ICF opening and we marked on where I was to put the EPDM so it would be under the window and coming up the inside at the window board. The ICF is capable of load bearing the windows and fastening them back to the concrete core but the windows were going to be big and heavy (they come fully glazed) so we decided to use stokbord at the base of each window as our ICF was still soft enough that you could make an indent with just your finger (much like PIR) so when the weight of the window was resting on a shim it could push the shim into the ICF and general handling during installation could cause indents in the ICF. We used 3mm stocbord under the windows and 12mm under the sliding door. The 3 windows that look down the field were levelled and measured using a laser to ensure they would be the same height from the floor, and again a laser was used at installation. On installation day the fitters arrived at about 8am and the windows arrived shortly after, it was a great feeling that we were finally going to be watertight and to see our chosen windows. The installation team were all great you could tell they all had a role during the installation, Illbruck FM330 airtight foam was used and Silka EBT+ sealant. I am now taping the windows inside and out using Pro Clima tapes. We purchased 10 windows (4 non opening, 6 Tilt and Turn) and a sliding door. Windows P33A, 10 windows average uW.80 Sliding door S319A 2m wide uW 0.76 Aluminium clad, Marine Finish, Trip,e glazed. External colour 7030 Stone Grey Matt Internal white stain Breakdown of window costs Windows £11,500 Sliding door £3500 Sills and trims £740 Installation £2600 Stocbord £500 Survey £750 Delivery by small HIAB £1320 Total to date £207,626 I have been continuing the installation of the Rockwool in between the rafters and building the gabion wall when the weather is nice. I researched and purchased a plasterboard lifter that will reach 16ft and a table saw for the insulation under the rafters. The renderer is booked in for May, colours chosen. The wood cladding is ordered and ready for final payment so hopefully the next blog will cover the cladding.
Keeping the birds and critters out
Susie replied to Post and beam's topic in Roofing, Tiling & Slating
I have 140mm of Rockwool and. 50mm air gap I have put mesh up to protect against birds and insects. https://www.robinsonwirecloth.co.uk/online-shop/Soffit-insect-mesh-stainless-steel-30m-roll-p49612077 the soffit is still yet to be closed up we haven’t clad the walls yet in the meantime we are very vulnerable to birds -
German kitchen brands - Nobilia, Bauformat or Leicht?
Susie replied to Indy's topic in Kitchen Units & Worktops
VAT A hob with a built in extractor in the hob is allowable, a hob only is not allowable, an extractor is allowable. an oven, washing machine, dryer etc not allowable an Aga type oven if it also heats water is allowable Having a plug or being hardwired doesn’t change anything. The whole ‘what is allowable?’ Can be looked up in the VAT guide. I wouldn’t rely on any logic. -
Reading the Land Registry runes?
Susie replied to Alan Ambrose's topic in Party Wall & Property Legal Issues
Incomplete histories in titles is common, I checked all the bordering properties titles and plans when purchasing our property. They make interesting reading as it was all farm land owned by a family and sold off at different times. Our land has 5 different properties bordering it but more than 5 titles and one property unregistered. As for covenants when it came to our possible build, years later after the purchase of our home I rechecked all the titles and reread them all many times till I understood who owned what and when the land was split and found numerous covenants on one title but not carried forward when the same title was updated or made digital. The main farm house sold more land off recently and the newly created title has a lovely plan neatly showing various other titles. -
Weeks 18 to 23 So it’s been a while since the last update, but a couple of weeks ago the scaffolding came down and we can finally see our lovey slated roof and the solar. I am very happy with the roofers who worked so hard in the cold and the wind, as we are quite exposed. Anybody in the South West looking for a roofer I would be happy to recommend them. On the inside I have started with the insulation between the rafters. I am using Rockwool flexi slabs 140mm thick with an air gap above. On the outside I have put some insect mesh up already before the soffits are closed up, it’s attached to the ends of the rafters and will eventually be attached to the battens/cladding. As per previous blog the costs of parting with the builder and finding our own roofer and solar has proved to be good. Their respective quotes have been invoiced for the same amounts as the quotes, no extras or surprise costs. A saving of at least £12,000 against staying with the builder as his quote would have also incurred extras no doubt as he didn’t include Soffits on his build quote or roof quote, and he acknowledged they had not been included in any quote. Carried forward total £140,645 Scaffolding for roof £1440 Roofing. Felt and batten. Slate with Brazillian Graphite natural slate 500 x 250mm. Hook fix system to costal zone spec as per plan. Dry ridge system Con6 with Marley modern smooth grey ridge tiles. Two vent slates. Total supply and fix. £16786 Supply and fix softwood treated facia and bargeboards. Eave ventilation. Complete counter batten. £2111 Solar 15 x500W solar panels and GSE in roof trays. (Interior fit to be completed once windows are fitted) Supply and fit £4357 DPM for windows £316 1 Pallet of Rockwool 46m2 (Expect to order 2 more pallets to finish between rafters then PIR under rafters) £580 First electrical order (cable and back boxes, enough to make a start) £280 Windows all paid for £20869 A few incidentals from B&Q and Wickes etc Brings the total to date of £186,757
I think it’s 25mm air gap minimum but our BC suggested 50mm for us to allow plenty of air in at the eaves and out at the ridge.
First timers attempting an ICF and Oak Frame house in Devon
Susie replied to MCoops's topic in Introduce Yourself
Hi and welcome, looks a nice plot but no doubt a few challenges with the slope and wildlife. im over near Bude doing an ICF build and have a blog on here about it. I need to update the blog as the roof is now finished but no windows yet. -
Gutter supports for exposed rafter tails (feet/ends/etc
Susie replied to PlumbBob's topic in Rainwater, Guttering & SuDS
Our gutter is screwed on to the rafter tails. It’s been up 20+ years no problems if you get the required drain slope to down pipe it’s ok. -
I took a photo of the crates.
The blue car is a customers Jensen 541 and the grey one is our Jensen FF arriving back from the painters ready for us to complete its restoration.
Yes the trays are up but not flashed yet.
