  • entries
    24
  • comments
    282
  • views
    8362
The Build - Mission accomplished! We're in!!
Redoctober
A busy November saw all the trades coming good, albeit some were cutting it fine for the moving in day – 30th November – However, we have moved in with all the services up and running. Having said that, BT and Openreach have missed the deadlines and as a result we are without any internet, phone line or TV for at least a week! Also the master bedroom built in wardrobes are still be fitted.
The landscapers have finished their work, providing us with a patio area and a driveway area which will see plenty of activity. Look closely and you should see the hedging that has been planted. 330 separate plants in all. This was a planning condition and the hedges are a mixture of Hawthorn, Beech, Holly and Maple. Locally referred to as native hedging. The turf will be laid next Spring.
Our Air Tightness test was conducted by a guy from Perth - a good couple of hours away. We never set out to achieve such low levels because we didn’t want the capital outlay of such a system as well as the infrastructure it requires. Our score was 4.9 which in our eyes is very good.
There are a number of minor jobs which I need to do such as touching up the paint work here and there; re-oiling some wood in places but all that can wait until we have given the whole place a deep clean. The main external jobs outstanding are the erection of the oak framed porch and the downpipes. Both of which should be completed within the next 10 days or so.
Anyway, this was not a self build in the true sense of the words but it was project managed by myself and built using a main contractor and sub contractors after the TF had been erected. I hope you have not only enjoyed reading about our project but have found some useful bits of information within the blogs in order to assist yourselves with your projects, whatever that may be.
Overall my experience has been a good one. It hasn’t been without its difficulties, such as additional unforeseen expenditure and additional expenditure as a result of our mistakes, or due to us changing our minds!
Such examples include ordering the wrong door frame - we failed to realise we hadn't ordered a threshold suitable for level access - a mistake that cost us £1k. Changing our minds over the 3 toilets we had ordered. They simply looked lost in their respective environments so 3 new ones were ordered at an additional cost of £850. A failure to get a full grip of the scaffolding cost an additional £1k and a failure to budget correctly for the foundations and dwarf wall for the carport cost an additional £4k.
Final facts and figures -
Build schedule – 6 months from the day the TF arrived.
Cost per sq metre - £1850 – includes everything, and I mean everything - from the scaffolding through to the landscaping and it includes the car port and porch [ still to be erected] but not the land or fees.
Only two skips were used throughout the build – everything else was removed by us to the local dump or burnt on site – best investment was a £25 oil drum which we used as an incinerator.
Thanks for reading - Paul.
  • Like 14
35 Comments
Recommended Comments
31 minutes ago, newhome said:
Que? It's south of me, as near to England as you can get pretty much ;)
Oh... easily confused I am...I should know better, been following this since the first post.
I thought you’d been drinking. It’s that time of year again ?
Just looked at the pics again - just gets better every time I look at it!  Shame we dont have £1,850/m2 to spend on ours!
Be interesting to get the rough split between materials and labour. This was pretty much an all trades build apart from a few bits so bound to be much higher than a hands on build.
I think my bathroom is coming in around the £18.50m/2...
:ph34r:
Yes this was very much an all trades build - I supplied the materials were I could and just paid the labour costs. An example of that is the Joinery. I supplied all the oak materials etc., whilst the Joiner worked on an hourly rate of £25 per hour. Again the floor tiles and associated sundries were supplied by me and installed at a rate of £35 per sq m.
The builder supplied and fitted, so to speak, all materials for the ground works & drainage systems. His costs also covered the stone mason, although I supplied the stone at £70 per sq metre. The same is said of the roofer - He supplied and fitted everything required for the house, car port, porch [ when fitted] and the Rainwater goods.
The timber frame, additional insulation and erection costs came in at £316 per sq metre.
I supplied all the landscaping materials and just paid for the Landscapers labour - A breakdown of £5500 for labour and £6100 for materials.
I hope this helps and should anyone require more specific details, please send a PM.
Don't forget to take the covers off your smoke alarms now you are in....
Would love to have a nosey at your house sometime ;)
Congratulations - it all looks very much as though it belongs in the landscape and I hope you will have many happy years there.
1 hour ago, Square Feet said:
Quote
Many thanks @Square Feet you would be most welcome so if in the area make contact, the kettle(hot water tap) is always on?
Edited by Redoctober
On 05/12/2018 at 14:41, Redoctober said:
@Onoff exactly as @CC45 has described. The TF is doing all the insulating and air tightness. The stone is for appearances. Render was not an option as it wouldn’t tie in with the local housing stock albeit 3 farm workers cottages and a Smiddy!!
what sort of cost did the outside stone add compared to render? looks great
A message was sent via PM but for others who may be interested here are the details -
As for the stone / render costs, I'm not sure how much render would have cost as we never proceeded down that route - it was always going to be stone. The cost of the stone worked out at as follows -
Stones themselves - £70 per sq metre
Unfortunately I no longer have any reference as to how much the lintels and quoins cost but my total overall spend on the exterior wall materials was £19,418.00 [No VAT] - On top of that I had the labour costs but again, his costs were incorporated within the builders general costs, so I had no breakdown of his actual costs.
