The Build - Getting there
Hi all - a few photos showing the house 95% plaster boarded and some plastering started. Just the cloakroom and plant room off the utility room to complete. Somewhat frustratingly, we will have to wait a full week before the plasterer returns, which holds up the decorating and second fix joinery. The ceilings for the first floor have had two layers of plaster boards fitted, which helps with sound proofing.
Whilst this has been going on, the stone ,an and his labourer have really cracked on and finished the front of the house. The stone has been taken up to just above head height around the rest of the house. they just need to build up from there and to do the external chimney.
The kitchen fitter came out to do final measurements and noted that the external waste pipe in the utility room was a bit snug to allow both the washing machine and tumble dryer to fit in, so has recommended a breakfast bar type work top which is 665mm as opposed to 600mm deep. This will allow sufficient room at the back for the appliances and removes the hassle of having to adjust the pipework / drainage.
The next phase will see the plastering completed and the second fixes started. Outside I hope to see the house fully stoned and the chimney started. We'll see.
Recommended Comments
