Howard B Posted April 11, 2019 Share Posted April 11, 2019 Unfortunately we have a HDMI cable hardwired in to the walls and the end snapped off. Has any body attempted crimping a new connector on to a HDMI cable? if so any issues with quality? TIA Link to comment Share on other sites More sharing options...
ProDave Posted April 11, 2019 Share Posted April 11, 2019 Never seen one. A very fine 19 core cable and very fine pitch connector would not be easy even if someone sold one. 2 Link to comment Share on other sites More sharing options...
Temp Posted April 11, 2019 Share Posted April 11, 2019 (edited) There are solder repair connectors available but I've never used them. Will need a small iron with fine tip. https://www.ebay.co.uk/itm/HDMI-Male-19-Pins-Connector-A-Type-Solder-Termination-Repair-Replace-Kit-5-Pcs/162962886822?epid=1538358618&hash=item25f15850a6:g:jyUAAOSwfuBazLNs I don't see any instructions. edit: or a backshell? Edited April 11, 2019 by Temp 1 Link to comment Share on other sites More sharing options...
Temp Posted April 11, 2019 Share Posted April 11, 2019 Also google "repair hdmi" without quotes for other ideas. Crimping is probably best but the tool isn't cheap and might be connector specific? 1 Link to comment Share on other sites More sharing options...
Sue B Posted April 11, 2019 Share Posted April 11, 2019 (edited) We had a similar issue a few years ago. Both HDMI leads within a month of each other. I googled, I watched you tube then we hacked away at part of the wall and fed through the new cable where we could. It was a nightmare. Edited April 11, 2019 by Sue B 1 Link to comment Share on other sites More sharing options...
Ferdinand Posted April 11, 2019 Share Posted April 11, 2019 I read that as chimp. Sorry. ? 1 Link to comment Share on other sites More sharing options...
Howard B Posted July 10, 2019 Author Share Posted July 10, 2019 Thanks for all the replies, I think we are going to end up ripping it out and putting in HDMI over Ethernet so save from future issues. Link to comment Share on other sites More sharing options...
