ToughButterCup Posted April 10, 2019 Share Posted April 10, 2019 Theres a large price range in the offers online for tape that seals the gap between PIR insulation boards . Screwfix £3 or so, Toolstation more than double that. What's the story here? Are some tapes air-tight (and so more expensive) and others not? Link to comment Share on other sites More sharing options...
ProDave Posted April 10, 2019 Share Posted April 10, 2019 I can't give a recommendation. But I was first fixing an extension on Monday, and I noticed at least half the silver tape joining the gaps had simply unstuck, and appeared to have virtually no tack left in it to re stick. So some of it is utterly rubbish and not fit for purpose. Does it have to be silver? I would be happy to recommend Tescon Vana Air tightness tape that I used, and if you search on the bay you will find a German seller selling it a lot cheaper than anyone in the UK. Link to comment Share on other sites More sharing options...
Moonshine Posted April 10, 2019 Share Posted April 10, 2019 i brought some a while back, and it was almost like silver parcel tape, it was crap and didn't stick, make sure you get the proper alu stuff. Link to comment Share on other sites More sharing options...
ToughButterCup Posted April 10, 2019 Author Share Posted April 10, 2019 Vielen Dank Dave! Ich hab's gefunden. Viel billiger - muss ja 10 Stuck bestellen, aber das geht in Ordnung. Aber £11 Versandkosten. Hmmm. Na ja. Spitze, Mensch! Thanks Dave. Found it. , much cheaper - need to order 10 but that's OK. But £11 postal charges. Ah well.... Tops! Ian Link to comment Share on other sites More sharing options...
scottishjohn Posted April 10, 2019 Share Posted April 10, 2019 (edited) 1 hour ago, ProDave said: I can't give a recommendation. But I was first fixing an extension on Monday, and I noticed at least half the silver tape joining the gaps had simply unstuck, and appeared to have virtually no tack left in it to re stick. So some of it is utterly rubbish and not fit for purpose. Does it have to be silver? I would be happy to recommend Tescon Vana Air tightness tape that I used, and if you search on the bay you will find a German seller selling it a lot cheaper than anyone in the UK. If there was any dust on sheets when you did it that could be the reason why it came unstuck ,also temp could be a factor . was this aluminium tape or plastic type that is coloured silver. the real aluminium tape sticks very well if surface is dust free downside to alli tape is it will not like movement as it does not stretch ,it breaks so a good quality plastic type should be good if you have any movement in things I used both and found the plastic type was better for my under joist " supa foil blanket " as it tended to be flexible and moved alli great if things were solid non of them were good to seal joints in polystyrene boards --fine if foil backed but not direct on to foam go for 52mm minimum -not the 38mm wide -- Edited April 10, 2019 by scottishjohn Link to comment Share on other sites More sharing options...
