32 minutes ago, Russell griffiths said:
Pre made panels, looking for
decent tin snips, duckbill pliers, and anything you found good for bending bottom hems and other bits and pieces.
decent tin snips
my guess you might need 3 types --straight +l/h cut +r/h cut
duck bill pliers --maybe panel gripping  shaped mole grips and remove the locking bar
https://www.ebay.co.uk/itm/NEW-5PC-TRADESMAN-TROWEL-SET-CONSTRUCTION-HAND-TOOLS-BUILDING-SOFT-GRIP-HANDLE/302969987144?hash=item468a6b2048:g:~LcAAOSwNYtb-D45:rk:11:pf:0
cheap i know --but can,t find duck bill on its own
a site that does metal roofing tools
https://www.ebay.co.uk/itm/CRANKED-180-mm-DECK-SEAMING-PLIERS-TONGS-FOLDERS-ROOFING-TINSMITH/401701040496?hash=item5d873f7170:g:92cAAOSwK9ZcWJEb:rk:3:pf:1&frcectupt=true
goggle the world --someone has it somewhhere
Edited by scottishjohn
Did you look at the Kalzip type aluminium roof? Not for DIY but a very good product. They use a machine that they walk alongside and it zips the seams together.
I think @scottishjohn you miss read my question, I can find loads of tools, that is not the problem
what I asked was what tools anybody had found useful when they did their roof
did they find that the left handed food whisk made purposely for stirring angel delight was the precise thing needed to form the left hand fold on the eaves over hang.
Thats is what I’m after, I have loads of snips, just looking for something that was invaluable in the fitting of raised seam panels.
Yep had a brief look, but the rental or purchase cost of the seeming tool is a bit off putting.
yep, you are right
thought you just looking for correct tools
probably just experience .lol
Hi Russell
Sorry for the delay, only just seen your post.
For my Tata roof they supplied, 3 tools. Eaves closer, Stubai pliers and Flange mate.
I also bought left and right off set tin snips.
Best bit was Makita 136mm 30 tooth metal blade for circular saw, I cut all the panels with this.
On 15/02/2019 at 09:29, JamesP said:
Hi Russell
Hi
Can I ask how you like your TATA roof, and which one you went for, we are just researching different roofing options.  We are going for an industrial roof appearance.
Thanks
8 hours ago, BNF said:
Hi
Thanks
Hi there, very happy so far with the roof. I chose it because I could fit myself and it was within my budget. Lots of other options on the Forum here.
