vivienz Posted November 1, 2018 Posted November 1, 2018 This is the acoustic board sold by Sydenhams; has anyone used it? Any opinions on this versus Soundbloc?
Mr Punter Posted November 1, 2018 Posted November 1, 2018 Try Knauf Soundshield Plus as it is also tougher / harder and holds fixings better. They recommend it for schools etc. Out dryliners used it so I don't suppose they paid over the odds v. normal DB board. 1
Moonshine Posted November 1, 2018 Posted November 1, 2018 the main thing you want to look at when comparing 'acoustic' plasterboard is the surface density (kg/m² ), the higher the number the more mass it has and better it performs and a mass barrier From what i can see 12.5mm GTEC dB is 10.2 to 10.7 kg/m² , and 15mm is 12.5 to 13.1 kg/m². other boards as below; Gyproc wallboard 12.5mm - 8.0 kg/m2, 15mm - 9.8 kg/m2 Gyproc fireline 12.5mm - 9.8 kg/m2, 15mm - 11.7 kg/m2 Gyproc SoundBloc 12.5mm - 10.6 kg/m2, 15mm - 12.6 kg/m2 Gyproc plank 19mm - 15 kg/m2 Gyproc SoundBloc F 15mm - 14.1 kg/m2 Knauf Soundshield 10mm - 8.4 kg/m2, 13mm – 12.3 kg/m2 Knauf Standard Wallboard 15mm - 10.2kg/m2 Knauf Vapour Panel 15mm - 10.2kg/m2 Knauf Moisture Panel 15mm - 10.2kg/m2 Knauf Sound Panel 12.5mm - 10kg/m2 Knauf Fire Panel 15mm - 12kg/m2 Knauf Impact Panel 15mm - 12.8kg/m2 Knauf Soundshield Plus 15mm - 12.8kg/m2 Knauf Performance Plus 15mm - 12.8kg/m2 Knauf Plank 19mm - 14kg/m2 Knauf Core Board 19mm - 16.3kg/m2 So between 15mm GTEC dB, Soundbloc, and Knauf Soundshield Plus, the GTEC dB is marginally more dense, but if you go for Gyproc SoundBloc F you get a bigger increase. 2 2
vivienz Posted November 1, 2018 Author Posted November 1, 2018 Thanks chaps, really helpful. I will get some price comparisons in the next week or so.
dpmiller Posted November 1, 2018 Posted November 1, 2018 I've got a big stack of it waiting for my attention...
Weebles Posted November 1, 2018 Posted November 1, 2018 (edited) 2 hours ago, dpmiller said: I've got a big stack of it waiting for my attention... Stack of what exactly? We are at the same stage of looking at plasterboarding spec. Its a minefield. The list above is really useful - thanks @Moonshine 15mm acoustic on ceilings. But has anyone used acoustic on walls too? Anyone not used acoustic on walls and finding it noisy? Worth putting acoustic on the wall between the WC / utility and the lounge, for example? Edited November 1, 2018 by Weebles correct username referenced
dpmiller Posted November 1, 2018 Posted November 1, 2018 Gtec db, Siniat standard and MR boards. All 12.5mm, and supplied under our TF contract. 1
nod Posted November 1, 2018 Posted November 1, 2018 4 hours ago, vivienz said: This is the acoustic board sold by Sydenhams; has anyone used it? Any opinions on this versus Soundbloc? I regularly use both Exactly the same 1
