ProDave Posted September 21, 2018 Posted September 21, 2018 I needed some more 22mm by 19mm pipe insulation to cover the last of the pipes before the ceiling goes up. Screwfix stopped listing it except in bulk packs of 50 metres. Toolstation list it but out of stock. Went into Jewson while in town, out of stock. eventually found some in Travis Perkins, twice the price I would have paid if screweys or TS had it.
Onoff Posted September 21, 2018 Posted September 21, 2018 Wickes? Where I got mine but I didn't need much: https://www.wickes.co.uk/Wickes-Pipe-Insulation-Byelaw-22-x-1000mm-Pack-3/p/210012
ProDave Posted September 21, 2018 Author Posted September 21, 2018 4 hours ago, Onoff said: Wickes? Where I got mine but I didn't need much: https://www.wickes.co.uk/Wickes-Pipe-Insulation-Byelaw-22-x-1000mm-Pack-3/p/210012 I was in the town, not the city. And that is about what I paid at TP, still twice what screwy's were selling it previously.
PeterW Posted September 21, 2018 Posted September 21, 2018 No shortage of Climaflex but Screwys have done a deal with a supplier that is similar to Polyflex or KFlex and it’s cr@p....
Adsibob Posted August 2, 2022 Posted August 2, 2022 On 21/09/2018 at 22:44, PeterW said: No shortage of Climaflex but Screwys have done a deal with a supplier that is similar to Polyflex or KFlex and it’s cr@p.... is climaflex considered inferior?
JohnMo Posted August 2, 2022 Posted August 2, 2022 B&q do climaflex, I know Elgin had stock at the weekend, maybe Inverness have stock also?
PeterW Posted August 2, 2022 Posted August 2, 2022 15 minutes ago, Adsibob said: is climaflex considered inferior? Nope it is one of the best polys, some of the others are rubbish. If you can stretch to it then go for a nitrile rubber insulation such as InsulTube or Armaflex.
JohnMo Posted August 2, 2022 Posted August 2, 2022 Toolstation Elgin has bylaw 49 in stock 11 lengths, Inverness has 1. When I bought it last it was climaflex.
Adsibob Posted August 2, 2022 Posted August 2, 2022 (edited) 37 minutes ago, PeterW said: Nope it is one of the best polys, some of the others are rubbish. If you can stretch to it then go for a nitrile rubber insulation such as InsulTube or Armaflex. Is this recommendation for nitrile rubber also the case for internal use? I just need to insulate the copper pipe coming out of my boiler and into the HW cylinder. Edited August 2, 2022 by Adsibob
PeterW Posted August 2, 2022 Posted August 2, 2022 Nitrile can be used anywhere. It’s 2/3rd the thickness of Poly for the same uValue
Adsibob Posted August 2, 2022 Posted August 2, 2022 1 hour ago, PeterW said: Nitrile can be used anywhere. It’s 2/3rd the thickness of Poly for the same uValue So nitrile is better than poly. But what about things like Isover pipe insulation (which I believe is a type of glass fibre covered with alu foil, like this) or rock wool pipe insulation, like this). Where do they fit into the hierarchy? There are a couple of spots where I only have about 12mm of space between a pipe and a wall for pipe insulation, so would be good to understand where to use the more expensive stuff and where I can just increase the thickness (e.g. some places i have up to 40mm of space).
PeterW Posted August 2, 2022 Posted August 2, 2022 Isover and Rockwool are semi rigid usually used for process pipework / steam etc, and used in commercial premises where fire resilience is required. Using Nitrile can be a lot easier as it’s softer and compresses better than poly, and can be slightly more resilient.
Adsibob Posted August 2, 2022 Posted August 2, 2022 10 minutes ago, PeterW said: Isover and Rockwool are semi rigid usually used for process pipework / steam etc, and used in commercial premises where fire resilience is required. Using Nitrile can be a lot easier as it’s softer and compresses better than poly, and can be slightly more resilient. Thanks. Is there a benefit of using isover/rock wool over nitrile though? I ask because I have a few 1.6m straight runs of 22mm pipe which could take a rigid insulation product relatively easily.
PeterW Posted August 2, 2022 Posted August 2, 2022 It’s 3 times the cost and half as good efficiency wise so why would you ..? Nitrile takes minutes to install.
Adsibob Posted August 2, 2022 Posted August 2, 2022 3 hours ago, PeterW said: It’s 3 times the cost and half as good efficiency wise so why would you ..? Nitrile takes minutes to install. When you put it like that, it's a no brainer. Why would people buy anything else? I wonder if it's because Nitrile is a bit more limited product range. For example, the thickest wall insulation Armaflex does for a 28mm pipe is only 25mm thick walls. But maybe that's because any extra thickness wouldn't make a difference??
Adsibob Posted August 2, 2022 Posted August 2, 2022 (edited) Scratch that, I've just found 32mm thick in armaflex although whilst it is slit, it's not self sealing, which is a pity: https://www.jtmplumbing.co.uk/insulation-c555/armacell-armaflex-class-o-insulation-32mm-wall-c623 Edited August 2, 2022 by Adsibob
Adsibob Posted August 3, 2022 Posted August 3, 2022 12 hours ago, Adsibob said: Scratch that, I've just found 32mm thick in armaflex although whilst it is slit, it's not self sealing, which is a pity: https://www.jtmplumbing.co.uk/insulation-c555/armacell-armaflex-class-o-insulation-32mm-wall-c623 I found a 32mm wall thick self sealing insulation for 28mm pipe: https://www.jtmplumbing.co.uk/insulation-c555/rubaflex-class-o-pipe-insulation-c921
