Pocster Posted September 17, 2018 Posted September 17, 2018 (edited) Hey all I’m nearing the point where I need to think about the routes mvhr ducting , water supplies , electrics etc . need to run . Is it best just to pick a corner in a room ; cut through the flooring and use that one route at the point for everything to run ?? Or is there a more methodical route ?? Edited September 17, 2018 by pocster
recoveringbuilder Posted September 17, 2018 Posted September 17, 2018 Well we were told water had to come in a straight line not go round corners, electricity will need to come into your consumer unit and telephone into where you’re going to have your main socket
Pocster Posted September 17, 2018 Author Posted September 17, 2018 16 minutes ago, Christine Walker said: Well we were told water had to come in a straight line not go round corners, electricity will need to come into your consumer unit and telephone into where you’re going to have your main socket Hey I don’t mean how they get into the build . I mean once in the build . Do I have one corner where I run all the mvhr ducting , electrics , cat5 , hep20 pipes etc ??
Mr Punter Posted September 17, 2018 Posted September 17, 2018 Often the people supplying the MVHR unit will do a plan showing unit and duct locations. They can also do a take-off of what ducting / connectors you need.
Mr Punter Posted September 17, 2018 Posted September 17, 2018 Although it can make sense in a commercial building to have a main service duct / core, for individual houses the service runs are more ad hoc per service.
Pocster Posted September 23, 2018 Author Posted September 23, 2018 On 17/09/2018 at 16:23, dpmiller said: got a plant room? hot press? I do have a ‘ plant room ‘ All services come in here . Was going to stick a router here and run cat 5 to each room . Also manifold to supply water to each ‘tap’ .
Mackers Posted September 23, 2018 Posted September 23, 2018 It's a bit more complicated than that. We'd need more info on your build and what you want?
Ferdinand Posted September 24, 2018 Posted September 24, 2018 (edited) On 17/09/2018 at 15:43, pocster said: Hey all I’m nearing the point where I need to think about the routes mvhr ducting , water supplies , electrics etc . need to run . Is it best just to pick a corner in a room ; cut through the flooring and use that one route at the point for everything to run ?? Or is there a more methodical route ?? I have one (high quality ... complete sod to drill the bricks) house built in 1913 that came with service ducts from downstairs to upstairs, made from hollowed timber - one up the side of a chimney breast, the other up the side of a window. I would generally say keep the inter-floor runs concentrated if you can, but that there are other factors too. F Edited September 24, 2018 by Ferdinand 1
