Russell griffiths Posted August 1, 2018 Posted August 1, 2018 So as the title says i have seen a product on you tube for fixing fence posts, that is an expanded foam type stuff that got poured around a post anybody seen it or know where to get it. I have a couple of loose gate gate posts that are moving due to the clay cracking around them and a series of 75mm wide cracks around them that would be perfect if I could pour something down them.
Cpd Posted August 1, 2018 Posted August 1, 2018 Not seen this one but if you can’t track it down I would use a liquid grout, i used one for a job in Aus for a very specific loose 1 ton stone slab. Rather than lift it we just poured grout in. Worked great. Conbextra do a range of really good ones the GP is genaral purpose and the UW is underwater both pourable to fill gaps 10-75mm. fairly well priced if you can find a local supplier. Col 1
Onoff Posted August 1, 2018 Posted August 1, 2018 Didn't someone already post on here about this? Just search "Sika Fence Post Mix". Sellers on Amazon, eBay etc. About £12 a pop. Not sure how many posts that'll do.....think one bag per post. There seem to be makes other than Sika too, eg: https://m.ebay.co.uk/itm/Post-Mix-Post-Set-Post-Fix-Expanding-Foam-Bag-Fencing-Post-12-75-/132689108507? & https://www.toolsfirst.co.uk/product/osmo-post-fix/?
ProDave Posted August 1, 2018 Posted August 1, 2018 If it's just the clay soil shrinking in the dry weather, I would just be watering the ground around them for a while to make it swell up again.
