Yes indeed although whilst I anticipate that my engineer in fitting the new sensor will have been astute to the possibility that the same problem could reoccur, there are many other wires and checking them all will not be easy. The one which caused the problem on this occasion was partially hidden behind the pcb.
  • 2 months later...
I’m involved in the installation of an ex display therma-v that didn’t come with the in-room display/controller and the dhw tank sensor. I’ve got part numbers and sources for those,  but could someone sanity check my thoughts:
It’s a 2 core cable from the display to the heat pump?
The therma-v has a built in flow/buffer temperature sensor?
There isn’t a volt-free call for heat input, just a 240v thermostat wiring strip?
I should add that I don’t have the manual, just going off the wiring diagram on the inside of the door.
@adam Huttel
umm... get the manual?
Yeh, found it now... LG aren't the easiest things to find details for. It's nicer in some ways than the Cool Energy, but much worse in other ways...
Edited by HughF
I think somewhere back here is a post that says that the current Therma V generation controller does not work with the previous generation heat pump.  Better check how long this ex-display model was on display.
  • 7 months later...
@adam Huttel
Can you confirm that the thermostat uses a L, N and switched L as call for heat - all 240v?
I am planning on using a wifi relay switch powered by the L and N and controlled by home automation (samsung smartthings) to use my smart thermostat to control the unit operation.  With a thermostat controlling call for heat, will the AI still control the flow temp based on the external temp?
Thanks
Edited by Michael_S
I have a 2nd gen (U32) 12kwh purchased second hand.  It is set up and running, heating only with the secondary immersion heater disabled via the dip switches.
I am using the weather comp AI (-10 +55, 15 +25) to control the operation with the 'hysteresis' On-off range set to the highest values to minimise short cycling.
On the controller you can manually apply a flow temp offset between +/- 3.  Is these any way to automate this offset on a time programme so I can have a night time set back so we can have the house cooler at night?  Thanks
 No.  Unless, I suppose, it is an undocumented feature.
Thanks.  Seems an odd omission, my 15 year old gas boiler with weather comp had this option.  Perhaps they expect everyone to use a programable thermostat to control the unit?
 Maybe, but then you can't use the Load Compensation capability ("Air + Water").
Another question - LG Therma V and power cuts.
Default behaviour seems to be go to standby after a power interruption and lose the unit time and for mine set a random 'holiday' programme active every day.  Having the unit default to basically 'off' after a power cut seems like a potential disaster if you are away on holiday in the winter and have a power outage - any way around this?
  • 6 months later...
Can anyone advise on LG part numbers for the LG wall controller? This is to fit a 7kW therma-v.
helping my mate commission his unit that came ex-display with the controller missing. LG have been particularly useless on the phone/email so far.
Will depend for on the serries Uxx number
  • 3 weeks later...
