EdLyd Posted May 10, 2018 Share Posted May 10, 2018 Hi, Just got a practical question regarding scaffolding... Scaffolding will be required to put up the timber frame and subsequently the roof covering. However, when it comes to building the outer skin, would my brickies need to work around the scaffolding that's already in place, or would it need to come down, then go back up again? Any advice on this please. Thanks Link to comment Share on other sites More sharing options...
CC45 Posted May 10, 2018 Share Posted May 10, 2018 Mine worked around what was there - not ideal but can be done. Some drop it completely if theres a delay before brick work starts, then perhaps use tressles for a while and then get scaff back on site. Ask your brickies. Link to comment Share on other sites More sharing options...
EdLyd Posted May 10, 2018 Author Share Posted May 10, 2018 Thanks, I'm in the early stages, toying between building via traditional brick/block or going Timber Frame - so just weighing up pro's/cons/costs. But yes, as you say, I think the answer lies with the brickie, but to take scaff down then put back up seems illogical/costly but from a practical point of view, obviously makes sense. Cheers Link to comment Share on other sites More sharing options...
ProDave Posted May 10, 2018 Share Posted May 10, 2018 If you use something like Kwikstage or Cuplock, you can fit "hop up" extensions to take the scaffold closer to the frame, then remove these as the brickies build up the outer blockwork. Link to comment Share on other sites More sharing options...
Brickie Posted May 10, 2018 Share Posted May 10, 2018 For a TF a system scaffold is ideal. Working through the lifts on an already erected scaffold is a PITA. Link to comment Share on other sites More sharing options...
PeterW Posted May 10, 2018 Share Posted May 10, 2018 You can set up a Kwikstage on three sides to allow you to get the frame in then drop the remaining side in when you are done to allow the brickies to do the skin. Quicker and simpler than a trad scaffold. Link to comment Share on other sites More sharing options...
