readiescards Posted March 4, 2018 Share Posted March 4, 2018 In process of converting a farm barn to a holiday cottage. Had planned to install a single property sewage treatment plant (maybe a Clearfox - expensive but quiet and low maintenance and zero running costs). However longer term I might convert two more barns and longer term again the current old but working septic tanks might need replacing. Any suggestions for a suitable system (and rough costs if known) for a 5 property sewage treatment plant capable of handling 19 bedrooms (38 persons) - into a soak away or maybe water course. (Plenty of land all down hill from all the properties.) Link to comment Share on other sites More sharing options...
ProDave Posted March 4, 2018 Share Posted March 4, 2018 Will building control allow a shared system for multiple properties? I thought they discouraged that? The people that make mine Conder do large systems http://www.premiertechaqua.co.uk/products/wastewater/conder-saf-sewage-treatment-plant.aspx# In fact quite a few different systems are available http://www.drainstore.com/sewage-treatment-plants/26-50-sewage-treatment-plant.html 1 Link to comment Share on other sites More sharing options...
ToughButterCup Posted March 5, 2018 Share Posted March 5, 2018 I am pretty sure that all the main suppliers offer a table which matches their products to 'demand' . I understand that intermittent use is challenging for off mains systems. That leads me to guess that something which injects a small air 'trickle' through the liquor might well be useful. Paul Usher from Klargester has been a tremendous help to us: he was honest enough to (after two site meetings) suggest we didn't need one of his products. He also has (had?) a blog about off mains drainage. Top bloke. Ian 1 Link to comment Share on other sites More sharing options...
PeterW Posted March 5, 2018 Share Posted March 5, 2018 As @recoveringacademic says the issue is intermittent use and the buildup of nitrates in the tank. I installed a big commercial Biodisk unit (18,000 litre) and it has a recirc pump on it that keeps recycling clean water into the main tank if the level gets too low - this reduces nitrate buildup apparently. You may be better with 2 or 3 smaller ones - or speak to someone like MPC Services who I can recommend as being excellent with this sort of thing. 1 Link to comment Share on other sites More sharing options...
readiescards Posted March 6, 2018 Author Share Posted March 6, 2018 Thanks got someone from Klargester coming out Friday to review options Link to comment Share on other sites More sharing options...
readiescards Posted April 5, 2018 Author Share Posted April 5, 2018 Seems non-viable because of the long runs So back to trying to find a smaller plant Link to comment Share on other sites More sharing options...
readiescards Posted May 11, 2018 Author Share Posted May 11, 2018 On 05/03/2018 at 10:18, PeterW said: or speak to someone like MPC Services who I can recommend as being excellent with this sort of thing. Luke @ MPC Services very helpful - 2 separate units best bet he says. Thanks @PeterW 1 Link to comment Share on other sites More sharing options...
