Just for the record. I have absolutely no loyalty or association with BuyMaterials, but I thought I would give it a try recently to see whether I could get a better deal than I was getting from the local merchants.  Cut a long story short, I have already saved a pretty large chunk of cash.   For example
61 sheets of Caberdek P5 Eco - £9.10 / sheet
57 sheets of 18mm OSB3 - £17.24 / sheet
The only negative, is that having submitted a quote. they do tend to hassle a bit and ask whether you need anything ....
But all in all, I am impressed and if you get tired of trying to haggle with the local merchants, then you might find it useful.
1 minute ago, Square Feet said:
Can you add what the local merchants had quoted you for comparison?
Also if both quotes include delivery etc.
Cheers
The quote I accepted was < £20 delivery and was nearly a £1000 cheaper than the next merchant quote.  It came from a reputable supplier on the South Coast.
The quote I received from the local merchant was as follows.
Caberdek £12.15
OSB3 £18.55
My aim with all material purchases, is to beat the price specified on my 'Estimators Online' QS.  Every time I do that, it hopefully helps in either bringing the build in cheaper or helping to offset those unnecessary costs that you incur along the way.
Estimators had flooring at ~ £17 and OSB3 at ~ £27
  • Like 3
I think if nothing else, it serves as a useful tool to validate quotes you receive from a local merchant to make sure that you are not being robbed.
  • Like 3
