Novice Posted 14 hours ago Posted 14 hours ago We have been living in our certified Passivhaus since it was completed in August 2017. It's a relatively large house (approx. 400 m²) and overall has proved extremely comfortable and energy efficient. However, in recent summers we have increasingly experienced overheating in the main living areas. Despite using night purging and running the MVHR in summer/bypass mode, there are periods when we struggle to bring the internal temperature back down. We are therefore considering installing a couple of air-to-air heat pump/split AC units – probably one serving the main living area and another on the top floor. My main concern is maintaining the integrity of the Passivhaus airtight layer when installing them. The wall construction is shown in the attached drawing. The airtight layer is 12 mm SmartPly/OSB on the inside of the 300 mm twin-stud timber frame, with a 38 mm internal service cavity before the plasterboard. Obviously the installation will require refrigerant pipework, condensate drain and probably cabling to pass from inside to outside. I don't want an installer simply drilling through the wall and filling around the services with expanding foam. Has anyone installed split AC/air-to-air heat pumps retrospectively in a Passivhaus or similarly airtight timber-frame building? In particular, I'd be interested to know: How did you detail the penetration through the OSB airtight layer? Did you use proprietary airtight service grommets/collars or tapes around the pipe bundle? Is it better to install a larger airtight sleeve through the wall and pass all the services through that? How was the sleeve/penetration dealt with at the breather membrane and external cement board? How did you deal with the condensate drain without creating an air path? Would you pressure-test the house again afterwards to confirm the airtightness hasn't been compromised? I'd be very interested to hear from anyone who has done something similar, particularly on an existing Passivhaus.
ProDave Posted 13 hours ago Posted 13 hours ago 51 minutes ago, Novice said: running the MVHR in summer/bypass mode Bypass mode, as it's name suggests, bypasses the heat exchanger. In a hot summer, that will result in HOT outside air entering via the mvhr with no cooling effect. Leave it in normal mode. Then outside air that is hotter than inside, will be cooled by the cooler extracted air. I have struggled to find any time when it is actually advantageous to use bypass mode.
JohnMo Posted 13 hours ago Posted 13 hours ago 5 minutes ago, ProDave said: struggled to find any time when it is actually advantageous to use bypass mode When inside is hotter than outside. That is the only time.
Oz07 Posted 2 hours ago Posted 2 hours ago 10 hours ago, ProDave said: Bypass mode, as it's name suggests, bypasses the heat exchanger. In a hot summer, that will result in HOT outside air entering via the mvhr with no cooling effect. Leave it in normal mode. Then outside air that is hotter than inside, will be cooled by the cooler extracted air. I have struggled to find any time when it is actually advantageous to use bypass mode. Evenings i used to set mine to come on.
Oz07 Posted 2 hours ago Posted 2 hours ago 11 hours ago, Novice said: We have been living in our certified Passivhaus since it was completed in August 2017. It's a relatively large house (approx. 400 m²) and overall has proved extremely comfortable and energy efficient. However, in recent summers we have increasingly experienced overheating in the main living areas. Despite using night purging and running the MVHR in summer/bypass mode, there are periods when we struggle to bring the internal temperature back down. We are therefore considering installing a couple of air-to-air heat pump/split AC units – probably one serving the main living area and another on the top floor. My main concern is maintaining the integrity of the Passivhaus airtight layer when installing them. The wall construction is shown in the attached drawing. The airtight layer is 12 mm SmartPly/OSB on the inside of the 300 mm twin-stud timber frame, with a 38 mm internal service cavity before the plasterboard. Obviously the installation will require refrigerant pipework, condensate drain and probably cabling to pass from inside to outside. I don't want an installer simply drilling through the wall and filling around the services with expanding foam. Has anyone installed split AC/air-to-air heat pumps retrospectively in a Passivhaus or similarly airtight timber-frame building? In particular, I'd be interested to know: How did you detail the penetration through the OSB airtight layer? Did you use proprietary airtight service grommets/collars or tapes around the pipe bundle? Is it better to install a larger airtight sleeve through the wall and pass all the services through that? How was the sleeve/penetration dealt with at the breather membrane and external cement board? How did you deal with the condensate drain without creating an air path? Would you pressure-test the house again afterwards to confirm the airtightness hasn't been compromised? I'd be very interested to hear from anyone who has done something similar, particularly on an existing Passivhaus. Didn't Jeremy install aircon with a similar wall make up? You could search his threads i don't even remember his user name.
JohnMo Posted 1 hour ago Posted 1 hour ago He did, think he mentioned the insulation was so well packed it came out as a plug. 12 hours ago, Novice said: couple of air-to-air heat pump/split AC units Why not just one multi split? Remember if its just for cooling you need planning permission, if it's for heating and can also do cooling you do not.
Nickfromwales Posted 1 hour ago Posted 1 hour ago I’ve done this umpteen times, with all kinds of services; matters not a single jot what service(s) it is / are . For the split AC on my current clients build I simply used offcuts of 92mm MVHR duct as the sleeves, taped these to the interior AT layer, fed the pipes and cables through, and then the duct will get pumped full of Illbruck FM330 AT foam to complete; the foam seals for AT but is also, in a nutshell, liquid PIR insulation to boot. Condensate cannot be terminated internally I assume? If not, just send that through the same oversized duct. Externally I just use a mastic such as CT1, or similar NON silicone sealant, and bond the duct to the external medivent board, leaving a load of it as excess. Then push the outer membrane into the mastic, smooth with a tool, then go over the lot again until mummified. I’m home today but back on site tomorrow, so I’ll post some pics for you. Very easy to do, so don’t be intimidated by this at all
