I have a 25mm MDPE pipe that I want to connect to 22mm copper and have a stopcock. I could either use a coupler, 25mm MDPE to 22mm copper, and a 22mm stopcock or use a stopcock that has a compression fitting onto the 25mm MDPE itself. How robust is a compression fitting onto the MDPE as that's one hell of a place to have a failure!
I know Plasson make a combined pushfit adapter and stopcock, but availability is low, the price is high and I'm not so keen on a plastic tap.
Edited by MortarThePoint
I like the ball valves with a handle.  You may need to adapt to copper first.  The old screw down stopcocks can seize and leak.  We have about 8 bar pressure at home and have a pressure reducing valve as well.
I was already thinking I would have a lever handle ball valve, but I was thinking to have it downstream of the stopcock as those stopcocks are so standard I assumed that I'd have to have one for regs.
I'll have a PRV downstream as well.
I don't know exactly, but I used a compression elbow on the 25mm MDPE coming into the house. It was ok for the three years we lived there. I didn't use a standard stopcock but a lever ball valve.
On 18/08/2026 at 18:27, JohnMo said:
I just used a 25mm to 22mm stop cock. Been installed 6 years - no issues at all.
just don,t forget to fit the liner to the plastic pipe before using a compression fitting on it
In 10 years, all good:
20161002_192122
SAM_4102
I did have to back it off at installation and smear with Jet Blue Plus because of a drip:
SAM_4099
20161018_181259
I've decided to go with one of the Plasson adaptors so I can use a lever full bore valve instead of a stopcock. If the BCO says I need to change to a standard stopcock, I'll do that with confidence provided by contributors to this thread.
stop cock should have a non return valve in it --so you cannot pollute the mains -
