Alan Ambrose Posted August 16 Posted August 16 Is there an advantage to putting an intermediate thin-ish insulation layer under UFH screed in a PH-style house? We have 300mm XPS with a 150mm slab on top and we plan to have 100m screed with UFH. But I’m wondering whether, say, a 30mm insulation layer and then 70mm screed would provide a shorter time constant for more rapid heating & cooling. I know some peeps subscribe to always heating to 20/21 degrees and cooling to 25 degrees 24/365 using the slab as a big heat reservoir. But that assumes you never want to change the temperature any, and if ever you do, then it’s going to take days i.e. a v long time-constant.
Mike Posted August 16 Posted August 16 Only if you think that more rapid heating and cooling is good. In which case why not use radiators?
JohnMo Posted August 16 Posted August 16 2 hours ago, Alan Ambrose said: 70mm screed would provide a shorter tjme constant for more rapid heating & cooling. If want a short time constant for some reason, you could use Jaga Strada fan radiators, so you can cool also. Cheaper than fan coils, and designed to provide above dew point cooling. Also way smaller than radiators. Seems a strange design choice to do 150mm concrete then another 100mm screed on top.
Nickfromwales Posted August 16 Posted August 16 5 hours ago, Alan Ambrose said: Is there an advantage to putting an intermediate thin-ish insulation layer under UFH screed in a PH-style house? We have 300mm XPS with a 150mm slab on top and we plan to have 100m screed with UFH. But I’m wondering whether, say, a 30mm insulation layer and then 70mm screed would provide a shorter time constant for more rapid heating & cooling. I know some peeps subscribe to always heating to 20/21 degrees and cooling to 25 degrees 24/365 using the slab as a big heat reservoir. But that assumes you never want to change the temperature any, and if ever you do, then it’s going to take days i.e. a v long time-constant. Ask yourself why and when you'd ACTUALLY want to change these temps I doubt there's much practical / real world need to follow this route tbh.
Alan Ambrose Posted August 17 Author Posted August 17 I remember working in a very air-condition building in Bahrain. I used to open the windows to warm the place up. Luckily we could. Sometimes, I think, you just want to control the temperature rather than living in a isolated machine-controlled cocoon. Maybe you're cooking Xmas dinner for the family and want to stop it getting too stifling. Yeah open the windows but you would like to stop heating the place too.
-rick- Posted August 17 Posted August 17 34 minutes ago, Alan Ambrose said: I remember working in a very air-condition building in Bahrain. I used to open the windows to warm the place up. Luckily we could. Suggests the temp was set wrong on the place. With a home you get to choose the setpoint. With a well designed and insulated house (taking account of solar gains as well as heat loss) you should be able to find a temperature that just works and doesn't really require fiddling. Exceptions being if different family members have very different comfort temperatures (but that's at least as much of a pain if you have a more dynamic system, if not worse). Nothing stopping you opening or closing windows as you desire. 34 minutes ago, Alan Ambrose said: Sometimes, I think you, just want to control the temperature rather than living in a isolated machine-controlled cocoon. Maybe you're cooking Xmas dinner for the family and want to stop it getting too stifling. Yeah open the windows but you would like to stop heating the place too. The heating would naturally switch off if it went about the setpoint. With the windows open the internal temp would relatively quickly return to normal and a low/slow system with lots of concrete likely helps speed up the return to 'normal' temperature. Though on cooking, for my own future project I'm definitely leaning towards a directly vented solution (if I can get comfortable with air tight closable vents when not in use) despite what a lot of the advice for recirculating systems in an airtight house here. Reason being is if I am doing much cooking I'm likely batch cooking and that means heat output for hours that will likely overwhelm a well insulated airtight house. So replacing hot cooking air with direct outside air is a way of controlling heat gain more than anything else. Saw some Americans building custom cooker hood shrouds that directly push the make up air into the cooking area to then be sucked back out again from the stove. With low and slow you are going to smooth out a lot of temperature variation that we experience in normal houses. Sharp changes caused by opening windows/cooking will still happen but the reversion to mean will be a lot stronger in a house built for low/slow. The decision for a fast response system is in theory the safer choice, it's more like what we are all used to living with and moving away from a low/slow system once it's in is difficult/expensive. But going based on feedback from people who have low/slow, it is the way to go for many people if you can get comfortable with the idea. I want to find a setpoint that I can just set and forget about (bedrooms being on a separate floor expected to be cooler/or directly zoned).
Mike Posted August 17 Posted August 17 (edited) 2 hours ago, Alan Ambrose said: Maybe you're cooking Xmas dinner for the family and want to stop it getting too stifling. Yeah open the windows but you would like to stop heating the place too. In that example, once the air temperature reaches the floor temperature (typically between 23 & 28°C), the floor is unable to release any more heat into the room. Not until the air in the room cools below floor temperature as a result of opening the window, when the draft will likely be enough to carry away the excess. Edited August 17 by Mike
JohnMo Posted August 17 Posted August 17 4 minutes ago, Mike said: In that example, once the air temperature reaches the floor temperature (typically between 23 & 28°C), the floor is unable to release any more heat into the room. Not until the air in the room cools below floor temperature as a result of opening the window, when the draft will likely be enough to carry away the excess. Was typing similar. Well insulated house, floor temp is very often only a couple of degrees above room temperature so as room increases floor heat out put reduces. Once room temperature is above floor temp, the excess heat starts to be absorbed by floor also.
Alan Ambrose Posted August 17 Author Posted August 17 @-rick- you couldn't achieve the same with MVHR or wouldn't it have enough throughput?
Mike Posted August 17 Posted August 17 3 minutes ago, Alan Ambrose said: @-rick- you couldn't achieve the same with MVHR or wouldn't it have enough throughput? Not Rick, but no. MVHR doesn't shift enough air to make a big difference. Much better to open the window.
-rick- Posted August 17 Posted August 17 31 minutes ago, Alan Ambrose said: @-rick- you couldn't achieve the same with MVHR or wouldn't it have enough throughput? I assume your question relates to what I said about cooker hood? That's what the general advice is here. Use a recirculating cooker hood and use the MVHR on boost to swap the air in the room. I think this is fine for normal cooking smells. Some people have suggested not so great if you fry though. But my thought was more about the heat output of long cooking sessions. In a well insulated home there's nowhere for that to go and the MHVR doesn't shift enough air to do the job AFAIK. Opening is fine though it's less controlled. An externally vented cooker hood with a designed make up air solution would seem the better solution (assuming appropriate air tight shutters are used to seal them up when not in use). Only ideas for me at this point. Not got to the stage of actually planning something. I suspect it's a relatively low cost thing to do but if not then I'd likely stick with the recirc + MVHR + window.
Alan Ambrose Posted 2 hours ago Author Posted 2 hours ago It's just occurred to me that another 'use case' for a shorter time constant would be a relatively rapid change in internal air temperature caused by say strong sunshine through windows or a sudden heatwave.
JohnMo Posted 4 minutes ago Posted 4 minutes ago 2 hours ago, Alan Ambrose said: It's just occurred to me that another 'use case' for a shorter time constant would be a relatively rapid change in internal air temperature caused by say strong sunshine through windows or a sudden heatwave. Really makes zero difference, it's the floor surface temperature that's important. Surface temperature is defined by heat loss of the property and how many W/m2 it needs to generate. A well insulated house will have a floor temp only slightly above room temperature, so solar gain effectively switches off floor output as soon a room temp is equal to floor temperature. Once room temp is above floor temp floor will actively remove room heat. Some advantage and disadvantages of thick screeds Good Agonist to heating period, use floor as a buffer for cheap heat. Will retain and give back to the house over many hours. Very gentle heat, you don't notice the heating on or off. Use very low flow temp over many hours, great to reduce running costs. Bad Takes an age to heat up if you allow to cool too much. Different approach to heating than normal. Thin screed, is more like a low temperature radiator system. Still takes a while to heat house but not as long as thick screed. Cannot store heat for later release. Asking for opinion will yield a possible or negative reaction depending on the experience of the person answering. If you want a thin screed vote with your feet and do it
