NSS Posted 10 hours ago Posted 10 hours ago Just noticed this today. Car not even plugged in to Zappi. Any ideas? Â
-rick- Posted 10 hours ago Posted 10 hours ago Does the Zappi still work? Â Either something went pop inside it or it's just mometary glitch in the data (maybe noise pickup)?
NSS Posted 10 hours ago Author Posted 10 hours ago 8 minutes ago, -rick- said: Does the Zappi still work? Â Either something went pop inside it or it's just mometary glitch in the data (maybe noise pickup)? Not home at the moment, but will check when I get back. Â Have refreshed the data but it still shows, and would it use 2.8kWh if something went pop?
-rick- Posted 9 hours ago Posted 9 hours ago (edited) 32 minutes ago, NSS said: Have refreshed the data but it still shows, and would it use 2.8kWh if something went pop? Â Wasn't sure over what time period that was. If it's just for the period shown on screen then does seem high. A component short-circuiting will draw a very high current for a very short period of time (equally true for a noise spike). Maybe the sample rate of the monitor is only a handful of readings per second. In which case a huge but very short spike might appear to use more energy than it did. Â Edit: quick maths: To produce a reading of 2.8kWh for a recorded spike of 1 second you'd need to measure a draw of ~10kW or about 42A. A brief short circuit could be much more than that. Â Edited 9 hours ago by -rick-
SteamyTea Posted 9 hours ago Posted 9 hours ago A stuck fridge or freezer compre4ssor might use that much, but should trip out. Â My energy monitor had the battery fail, just before it did that, it was showing 1000 times the usage
NSS Posted 9 hours ago Author Posted 9 hours ago Just arrived home. Zappi appears fine (can't plug in at present as caravan in the way). Nothing has tripped on the the consumer panel. All seems fine 🤔
-rick- Posted 8 hours ago Posted 8 hours ago Probably just noise then. If the charger still works and there's no smell of electronics in the garage then don't worry about it. 1
ToughButterCup Posted 5 hours ago Posted 5 hours ago (edited) Next door neighbour - knows you are away - pops round for a quick top-up 🫤 Edited 5 hours ago by ToughButterCup
