August 8Aug 8 Does the Zappi still work? Either something went pop inside it or it's just mometary glitch in the data (maybe noise pickup)?
August 8Aug 8 Author 8 minutes ago, -rick- said: Does the Zappi still work? Either something went pop inside it or it's just mometary glitch in the data (maybe noise pickup)? Not home at the moment, but will check when I get back. Have refreshed the data but it still shows, and would it use 2.8kWh if something went pop?
August 8Aug 8 32 minutes ago, NSS said: Have refreshed the data but it still shows, and would it use 2.8kWh if something went pop? Wasn't sure over what time period that was. If it's just for the period shown on screen then does seem high. A component short-circuiting will draw a very high current for a very short period of time (equally true for a noise spike). Maybe the sample rate of the monitor is only a handful of readings per second. In which case a huge but very short spike might appear to use more energy than it did. Edit: quick maths: To produce a reading of 2.8kWh for a recorded spike of 1 second you'd need to measure a draw of ~10kW or about 42A. A brief short circuit could be much more than that. Edited August 8Aug 8 by -rick-
August 8Aug 8 A stuck fridge or freezer compre4ssor might use that much, but should trip out. My energy monitor had the battery fail, just before it did that, it was showing 1000 times the usage
August 8Aug 8 Author Just arrived home. Zappi appears fine (can't plug in at present as caravan in the way). Nothing has tripped on the the consumer panel. All seems fine 🤔
August 8Aug 8 Probably just noise then. If the charger still works and there's no smell of electronics in the garage then don't worry about it.
August 8Aug 8 Next door neighbour - knows you are away - pops round for a quick top-up 🫤 Edited August 8Aug 8 by ToughButterCup
August 14Aug 14 On 08/08/2026 at 20:00, ToughButterCup said: Next door neighbour - knows you are away - pops round for a quick top-up 🫤 This guy is going to be looking at his home cameras now, just in case it is!
August 14Aug 14 Author On 08/08/2026 at 20:00, ToughButterCup said: Next door neighbour - knows you are away - pops round for a quick top-up 🫤 Not unless he has the code for my garage door.
August 16Aug 16 Just had a SigEnergy setup with a DC EV charger included - to start the charger you need an RFID tag to start it going (and/ or maybe the App; no EV yet so not not tested). Seems to be a good anti-charge theft device 😀
