I have been driven up the wall trying to figure out how to connect pipework to a Crosswater Fusion concealed shower valve.
To my mind the installation instructions contradict themselves and I'd appreciate to hear a more qualified interpretation than my own (I'm a Carpenter not a Engineer of any description)
The valve has:
  • G 3/4" (BSPP) female shower head port. There is no seat for a rubber seal to sit in this port (and none show on the diagram)
  • G 3/4" (BSPP) male H&C inlet ports. Rubber edged gauze washer/filter are required to be installed on the ports
The instruction specifically state:
  • Make all pipe connections using a proprietary thread sealer
  • Do not use tapered threaded adaptors
My understanding is that a female port (where a rubber seal and seat for that seal is absent) requires the mating male to be tapered thread (BSPT) and wrapped with thread sealer to make the joint; and where the male ports have a rubber edge filter provides the seal then using thread sealer (Locktight 55 cord for example) may hinder making the joint.
If that understanding is correct then the instruction are surely contradictory?
Can you post a pic of the ends of the hot and cold union please.
For the shower outlet this is simple.
This goes into the top.
Then this goes into that.
Likely 2 of these for hot & cold.
The bush simply gets 21 turns of PTFE tape, same with the 1/2” male thread, or buy liquid PTFE like pipe superglue if you’re not confident.
Those 3/4” fittings should be just a bit over hand tight and a little pinch with a spanner and all good.
Make off stubs of 15mm into them before mounting them onto the shower, so you’re not swinging off them and putting the rubber seals under undue stress / movement etc ;)
There are circumstances where tapered thread fittings are not appropriate. Clearly this is one of them so follow the manufacturers instructions. I generally find Loctite 55 to be 100% reliable although surprisingly I've just done an installation where 2 of my radiator tails are seeping on pressure testing, but that's more down to unbranded rad tails with built in drain off that I needed in a hurry so took what was available off the shelf and manufacturing tolerances aren't great!
