On 06/08/2026 at 14:43, LSB said:
DIY new build has a flat roof (12 degrees)
What do your plans actually say about roof angle? Big difference between 12 degs and pretty much flat. Our 12 degs roof is 2.5 block work one side of the building and closer to 3.5 to 4m at the other (staggered wall).
21 hours ago, saveasteading said:
In summary then.
Flatness is in the perception of the user specifier
For solar we want it to tilt a long way up.
To keep rain out it depends entirely on the construction and product.
For insurance, Insurers make their own rules without understanding construction. I've certainly never declared anything at 10 to 15%.
In real life, I regard my walk to the shop as far from flat.
It's been interesting. For fun I asked AI how steep Ben Nevis is  (not direct via the cliffs)
The average gradient of the standard tourist route (the Ben Nevis Mountain Track) is approximately 10% to 15% (or roughly 1 in 10 to 1 in 7 overall), with a maximum gradient capped at 1 in 5 (20%). [1, 2]
Route Gradient Details
  • Overall Average: Roughly 10% to 15% grade across the entire ~8 km horizontal distance (1,345 m total ascent).
  • Maximum Gradient: 1 in 5 (20%), which was specifically engineered when the path was originally built for ponies supplying the top observatory.
  • Steepest Sections: Parts of the lower slopes and the upper zig-zags approach that maximum 1 in 5 limit.
So, @LSB back to the original post: from the pictures it looks as if your estimate of 440mm or whatever is about right. So you have 2 challenges. 1. You have to detail and build the roof very well to keep the rain out, esp at edges and interfaces.
2. That is very flat and inefficient for solar so maybe play the game, using the newly allowed balcony solar.
Later you might go back  to planning for a higher system. A few hundred mm would likely be allowed.
in fact I'd want to reclad with double skin, insulated. That will be higher but nobody will question it unless you have an enemy with binoculars.
Thanks @saveasteading having looked again, put some string lines from bottom to top we can get 5 degrees maybe even 6 with some consideration on wall plate thickness.
So, pretty flat, we look over fields and are pretty rural and the neighbours are only interested in how we are progressing, I suspect that we could put tilted solar and no one would comment.
They know our planning includes the 'new stuff' as they call it.
But, our planning also stipulates a metal roof so I need to understand the weight of solar on this as it's a large span.
I've not yet even got a definitive answer as to how many panels I need.
I've spoken to a couple of local supplies and they are not interested, I suspect too complicated for them and they all deal with retrofit and not new builds.
Thanks for everyones assistance in this.
Almost as quick to DIY than actually speak to installers. Our first array was me fitting all the trays, the electrician wired it up the roofer did the slates around the trays etc. and all the flashing details.
Panels to buy are around £100 each tray £70 plus flashing. So 10 panels (4.65kW) around £2k plus inverter/battery. Yes get a battery then run your whole house in cheap rate.
Installers are looking for a bigger job because of the grants.
More about the roof please. What construction do you intend? Closer purlins gives lots of strength.
just to throw a spanner in the works
 why have a tin roof
why not OSB +GRP
then cover whole area in solar panels ?
 if you want to inset it you just make roof the right shape with OSB and grp and make it lower at bottom  to drain the water  before you mount panels
Edited by scottishjohn
 why have a tin roof
why not OSB +GRP
Planning stipulates metal, to be replace like for like, although we won't be using the old tin shed look, but maybe profile steel.
I had some quotes and they were scary so we might have to DIY.  One company wanted 40k just for the roof, no solar and no batteries!!!!
I'd suggest using 40mm pir filled double skin. It is a good balance between stiffness and practicabiliry, price, insulation. And it will be much the same height as you have already. Flashings and seals need detailing
Easy to source too at about £40/m2.
 BUT, with waste that's coming to 10k already. Plus vat.
So let's say 10k sheeting
2 for sundries
Gutter 3
Scaffold towers etc 2
2 workers x 3 or 4  days say 2k
Tool hire 1.
20k and rising.
Plus vat.
Plus the risk that you make mistakes.
Are the purlins OK?
Is it worth approaching your planning department as, with your new solar panels, it will be most certainly NOT like-for-like. Given that all local councils like to big-up their green credentials then an amendment/new planning application might allow you to consider other, less expensive, material choices
Regards
Tet
Regards
Tet
The other thing if the panels aren't on your plan is it legal to install them. Your planning documents are a legal document for you to follow once approved.  Do a variation showing the roof full of solar.
Edited by JohnMo
Yeah we had to submit a NMA for this, no problem getting it approved but an annoying hoop to jump through plus the cost of application
Solar is in the planning, but very contradictory, just really just says that it should look like it did before, which it can't as none before.
They also want ASHP, MVHR, rainwater harvesting etc and 2 EV chargers.
Basically, none of the existing barn exists due to very shallow founds which we replaced and walls converted from single skin to cavity.
Planning guy came round one day and said fine, carry on.
BC is just concerned with the BC bits and architect has lost interest.
That said, it does look like it did before, blocks with openings.
It won't as we are having render and cladding, all approved.
I think the planning just didn't want anything bigger or higher.
Most of the current roof has been removed and the rest will in due course.
Insisting on MVHR is a big and expensive "requirement". I chose (and would heartily recommend) MVHR but as a planning stipulation it seems excessive - same with TWO EV chargers
Regards
Tet
Agreed, and I don't think that planners have the skills or knowledge to know if it is appropriate.... they've had a free seminar with sandwiches, from an mvhr body or energy consultant, and now think they are experts.
I had a similar argument re green roofs.
And superfoil nearly had one council convinced that it was effective. ( I went for that sandwiches and to be a pain at question time)
You could tick a box with a tiny mvhr. I saw a pretty useless one at an exhibition..  a box on the inside of an outside wall. The guy couldn't explain why the same air wouldn't go straight back out again.  You might find something a bit better with some ducting.
If the bco doesn't want one then that might kill it.
I would like MVHR or similar, my hubby gets terrible hay fever and wants filtered air in the summer and doesn't want me to open the windows.
the build will also be air tight so I don't want stuffy.
But, what system we have is yet to be decided.
The advantage with DIY is you are slow and have time, but there are so many considerations to everything.
MVHR and not opening windows... You open windows for cooling mostly, MVHR and any meaningful cooling doesn't really occur due to flow rates being so low.
Edited by JohnMo
1 minute ago, JohnMo said:
MVHR and not opening windows... You open windows for cooling mostly, MVHR and any meaningful cooling doesn't really occur due to flue rates being so low.
I've still got lots to learn.
You can add a cooling coil to MVHR and it will cool the incoming air. You should get a 3 to 4 Deg reduction in air temp coming out of the MVHR unit.  But you change the air in the house every 2-3 hours so it isn't that useful on its own.
