markharro Posted 11 hours ago Posted 11 hours ago Looks like our electrician has only allowed for 2x double sockets here whereas red marks on the wall were showing 2 x doubles on left and 1x on right. I suspect this is an easy fix and think I know how to do it but be grateful for some guidance. Thanks.
MikeSharp01 Posted 11 hours ago Posted 11 hours ago No they have just put in the base cables. When they come to fit the socket they will add another length of cable between the sockets on the left. 1
Onoff Posted 11 hours ago Posted 11 hours ago The two cables coming down the wall will go to double sockets 1 and 3. The other length of cable taped to the two coming down the wall will link socket 1 to 2 then socket 2 to 3.
ProDave Posted 10 hours ago Posted 10 hours ago The beauty of timber frame with a service void. You could make it 4 doubles if you wanted, 2 in each section of wall. Just make sure he know how many before he cuts the holes in the plasterboard.
markharro Posted 10 hours ago Author Posted 10 hours ago Brilliant thanks thats good news. So does this look ok for 2x on left and 1x on right? and if I did want 2 x doubles on right as well just do the same with the wiring?
Nickfromwales Posted 4 hours ago Posted 4 hours ago 5 hours ago, Onoff said: I'd say there's enough cable to do 2 left and 2 right. There's enough to do as many as you want here, perfectly compliantly . Cables would drop into any two of these 3 'sockets' boxes, and the link cables would daisy chain to all the others, forming a ring of x number of sockets instead of just linking 1 > 3. Cables all tight to boxes to stay in cable safe zones obvs, just drawn loosely here to show how this can be done.
