Mr Punter Posted 5 hours ago Posted 5 hours ago 11 minutes ago, Beelbeebub said: you get no points for batteries. If that is the case, make no provision for them. Do not suggest to tenants that they are authorised to install batteries. A world of liability for you. 1
-rick- Posted 5 hours ago Posted 5 hours ago So these properties are all owned by a single person with no plan to sell separately? If you wish to preserve an easy option to sell separately it sounds a fair bit more complex than otherwise. If operating as a pooled resource there may be options to get more efficiency out of the system. (Multi-tenant inverters exist, someone posted a link here recently). 1
Beelbeebub Posted 2 hours ago Author Posted 2 hours ago 2 hours ago, -rick- said: So these properties are all owned by a single person with no plan to sell separately? If you wish to preserve an easy option to sell separately it sounds a fair bit more complex than otherwise. If operating as a pooled resource there may be options to get more efficiency out of the system. (Multi-tenant inverters exist, someone posted a link here recently). Yes, no plans to sell. I've looked at the multi tenant systems (solshare or something). They are pretty pricey (5-10k) and have 15 outputs (5 x 3phases) so make the most sense in blocks of flats. 2 hours ago, Mr Punter said: If that is the case, make no provision for them. Do not suggest to tenants that they are authorised to install batteries. A world of liability for you. That is the most hard nosed approach but the benefit to the tenants is much more limited - especially with lower export rates.
JohnMo Posted 1 hour ago Posted 1 hour ago 22 minutes ago, Beelbeebub said: especially with lower export rates If MCS or octopus approved why not higher export rates, they are not limited to 3-4p kWh. 1
JohnMo Posted 1 hour ago Posted 1 hour ago 3 hours ago, Mr Punter said: If that is the case, make no provision for them. Do not suggest to tenants that they are authorised to install batteries. A world of liability for you. You don't need to, plug in batteries are almost here, if they want batteries they will have them like it or not. 1
Beelbeebub Posted 1 hour ago Author Posted 1 hour ago 22 minutes ago, JohnMo said: If MCS or octopus approved why not higher export rates, they are not limited to 3-4p kWh. I was thinking of the higher rates! They were 15p, now 12p And I suspect they will keep falling as solar generation gets more and more common. https://www.theguardian.com/environment/2026/aug/02/solar-powers-record-share-britain-electricity-july
