SteamyTea Posted Thursday at 14:26 Posted Thursday at 14:26 Environment How to unlock unlimited geothermal energy, anywhere we want Earth contains more than enough heat to power humanity many times over, but so far only a few lucky places have been able to exploit it. Now we may have a way to tap this vast clean energy source almost anywhere By Katharine Sanderson 21 July 2026 A geothermal power station in Iceland’s Hengill region, one of the few countries with natural geothermal reservoirs that allows it to turn underground heat into power Science Photo Library Deep under your feet, Earth is hot. Really hot. Some of that heat is left over from the planet’s violent formation. More is continually created by the splitting of radioactive atoms in the rocks below. In a few places, Earth’s hidden furnace dramatically makes itself known, bursting through the crust as volcanoes, geysers and rivers of magma. Spectacular stuff, but also extremely useful – if we can get at it. Conventional geothermal power works best wherever geology has done the hard work for us: where fault lines crack the crust and hot water or steam rises close to the surface. That’s why countries like Iceland, New Zealand, Kenya and Indonesia can turn Earth’s heat into warmth for homes and electricity for grids, while much of the rest of the world has barely touched it. Its appeal is obvious. Unlike solar power, geothermal doesn’t fade when the sun sets, and unlike wind power, it doesn’t stall when the air is still. Over the past decade, advances in drilling have begun to loosen geothermal power from its geological shackles. Some projects aim to improve on nature, creating cracks and pathways where none existed. Others are more ambitious still: they want to drill so deep that geothermal power could work almost anywhere. “Ultimately, the whole world is the goal,” says Matt Houde, co-founder of geothermal energy company Quaise Energy. That would turn it from a niche resource into something far bigger – a way to tap the planet’s hidden heat wherever we happen to need it. How we harness Earth’s heat To convert heat from Earth’s interior into usable energy, engineers pump cold water into naturally occurring reservoirs in hot rock. There, it warms up and returns to the surface as hot water or steam, which can be used to drive turbines and generate electricity. The water is then sent back underground to begin the cycle again. It’s a simple concept, and unlike fossil fuels, geothermal heat sources are practically inexhaustible on human timescales. “If you measure in terms of the energy stored within the Earth’s crust, geothermal heat exceeds by orders of magnitude all hydrocarbons,” says Houde. The trouble is that traditional geothermal requires three ingredients to work: heat, water and rock that is permeable or fractured enough for water to move through it. “Traditional geothermal systems are very constrained to countries and regions within countries where you have this unique combination of conditions,” he says. That is why geothermal has flourished in places like Iceland. Sitting astride the mid-Atlantic ridge, the country has those core ingredients in unusual abundance. The global oil crisis in the 1970s pushed Iceland to exploit that advantage, and geothermal now makes up over a quarter of the country’s electricity supply. That may not sound like much, but Iceland’s geothermal plants can keep generating whatever the weather, making them a steady backbone for the grid. “Geothermal is really well placed to be the glue that will make low-carbon electricity systems work,” says Iain Staffell, a sustainable energy expert at Imperial College London. However, most countries don’t share Iceland’s good fortune. They may have heat or water or fractured rock, but not all three at depths that are easy to reach. Traditional geothermal plants are limited to mining heat from less than 2 kilometres underground. Go much deeper, and the engineering becomes brutal. Drills must chew through hard, hot rock. The vertical shafts that connect the surface to heat reservoirs, known as wells, must survive punishing temperatures and pressures. Even after all that, the rock may still be too tight and unbroken for water to flow through it. A worker surveys the vast interior of a geothermal cooling tower in Monterotondo Marittimo, Italy Alessia Pierdomenico/Bloomberg via Getty Images Still, the prize is enormous. The International Energy Agency estimates that geothermal’s technical potential is around 150 times current global electricity demand, assuming we can exploit heat down to about 8 kilometres. Conventional geothermal typically taps pre-existing reservoirs of hot water or steam in permeable, fractured rock less than 2 kilometres underground, leaving much of that potential out of reach. The implication is clear: to expand the resource, engineers must drill deeper – and create the underground plumbing that nature hasn’t provided. Enhanced geothermal The first of the new geothermal techniques does exactly that. Enhanced geothermal systems target hot but impermeable rock, typically 2 to 10 kilometres underground. Engineers pump in hot water at high pressures to open or widen fractures and create pathways for fluid to circulate. This is known as an enhanced geothermal system (EGS), and it is the most mature technology in geothermal’s new era. But this approach has a downside. Forcing water into deep rock doesn’t just create useful cracks. According to a 2023 review of the research, it can also disturb older, pre-existing faults that are already under strain. Many faults are held still by friction, like a heavy book resting on a tilted table. Pump water into them, and the pressure in their pores and fractures rises. That partly props the two sides of the fault apart, reducing the force clamping them together. If the fault was already close to slipping, that can be enough to induce an earthquake. An investigation commissioned by the South Korean government concluded that a nearby EGS project triggered a magnitude-5.5 earthquake in the city of Pohang in 2017. More than 80 people were injured and the earthquake caused an estimated 300 billion Korean won (£148 million) of damage, making it the most destructive in the country’s history. Is a broken jet stream causing extreme weather that lasts longer? Scientists are scrambling to understand how climate change may be interfering with the winds that carry our weather, with potentially catastrophic consequences Bill Ellsworth at Stanford University in California was part of the team that helped establish what role the geothermal plant played in the disaster. “In Pohang, they drilled a couple of wells that were a long way apart,” he says. The hope was that pumping water into one would fracture the rock enough to connect with the other, creating a route for water to pass between them and gather heat. But trying to force that kind of connection through the subsurface is risky, particularly if the drilling intersects faults that are already primed to slip. That is why newer projects are trying to be more deliberate, says Ellsworth. In Iceland, for instance, engineers try to create EGS reservoirs more gently without blasting them open all at once by pumping cold water slowly and at relatively low pressure. Over months, the cooling rock contracts and cracks, says Lilja Magnúsdóttir, executive vice president of resources at Icelandic energy company HS Orka. Iceland also has an advantage born of necessity: it is a seismically restless place, so the country has already invested heavily in monitoring. At HS Orka, that now includes using geothermal wells themselves as early-warning sensors. When magma begins to move, it compresses the surrounding rock, creating a telltale signal in the well. “It’s a really cool design,” says Magnúsdóttir. But even where EGS projects have learned to manage seismic risk, hard rock still makes an unreliable basis for a plumbing system. Fluid can leak away and contaminate groundwater, for instance. And the same fractures that make the system useful can also make it dangerous. Advanced geothermal One way around this is to stop asking the rock to carry water at all. Where natural fractures and reservoirs don’t exist, an alternative to EGS is to drill a sealed loop through hot rock. Engineers drill down, then sideways, until the boreholes connect underground, before lining and sealing them with steel and cement. That creates something like a buried radiator where fluid circulates, but never comes into direct contact with the rock itself. This closed-loop system is known as an advanced geothermal system (AGS), and it has been tested successfully in Germany, where Canadian energy company Eavor has developed a geothermal power plant at Geretsried, which began construction in 2022 and started producing electricity last year. Because closed-loop systems don’t force fractures open in the rock, they should reduce the risk of induced earthquakes. And because they don’t depend on continually pumping water into and out of those fractures, they should reduce it further still. In a few places, including south-western Iceland, Earth’s buried heat lies close enough to the surface to be tapped easily by geothermal plants. Water from this plant also supplies the nearby Blue Lagoon geothermal spa Dieter Telemans/Panos Pictures There is another possible advantage. If the working fluid stays inside a sealed pipe, it doesn’t have to be water. Companies can, in principle, use fluids that pick up and release heat more efficiently. Eavor’s working fluid is a company secret. The firm China Huaneng Group, meanwhile, has built the first geothermal demonstration plant that uses supercritical carbon dioxide – CO2 that is compressed and heated until it becomes not quite a gas and not quite a liquid. In that state, it is dense and flows easily, and is very good at moving heat. The firm’s test facility began operating in May this year in Zhengzhou, China. But these systems have their own difficulties. Eavor has had to scale back the number of wells it planned to drill after rock debris clogged parts of the pipe network. Its plant works, but not yet as efficiently as hoped. That points to a broader question: can closed-loop systems circulate enough fluid, and draw heat from the rock fast enough, to be commercially useful? “The jury is still out,” says Ellsworth. “Time will tell whether these ideas of having just a single closed loop will be actually successful.” And while AGS could be safer and cleaner than inducing fractures deep underground, it is still limited to places where hot rock lies within reach, usually a few kilometres down. To make geothermal truly global, companies will have to drill much, much deeper. Supercritical geothermal The deeper you go, the hotter Earth gets. Go deep enough and water crosses a strange threshold. At about 374°C (705°F), under sufficient pressure, it transforms into a supercritical fluid – akin to the CO2 in the China Huaneng demonstration plant – and can carry far more heat than ordinary hot water or steam. “There are a few countries where geothermal does provide a sizable mix of the energy supply. But strictly the heat itself, which is fundamentally what geothermal energy is, is actually available anywhere if you go deep enough,” says Houde. Supercritical temperatures are usually found at depths of at least 5 to 20 km, and often deeper. The rocks become harder the further you go: basalt or granite rather than the softer sedimentary layers often found closer to the surface. This rock chews through even the hardest tungsten carbide or diamond drill bits. Then there’s the time spent not drilling at all but instead replacing worn-down drill bits or equipment that begins to fail at higher temperatures and greater depths. These delays quickly push up costs, says Houde. Quaise Energy uses millimetre waves, a portion of the electromagnetic spectrum, to laser through hard rock found at great depths Quaise Energy Quaise, which is based in Houston, Texas, wants to get around this by drilling in a different way – without using a drill bit at all. Its plan is to use conventional drilling for the upper part of the well, then switch to high-powered microwave energy once the rock becomes too hard. The hole would be lined with corrugated steel, helping the microwaves travel downwards. When that energy hit the rock, it would heat it until the rock cracked, broke apart or even vaporised. “There’s no drill bit mechanically destroying the rock here, it’s just the interaction of the energy with the rock,” says Houde. The rock would be reduced into a fine ash that is purged from the well with a nitrogen-rich gas and collected at the surface. Quaise isn’t alone in pursuing non-contact drilling: Slovakia-based GA Drilling is also trialling laser- and plasma-based systems, and carried out its first field tests in 2023. Once the hole is open, Quaise wants to create a deep, EGS-style reservoir. Water would be sent through fractures in superhot rock, picking up heat before returning to the surface to generate electricity. In principle, it is geothermal freed from geography. Rachael Tremlett/New Scientist Quaise’s test holes are still just a couple of kilometres deep, but the company sees them as a proof of concept for something much larger. Its first planned superhot geothermal plant, located in Oregon, is intended to come online by 2030, accessing temperatures up to 400°C (752°F) at a depth of 3 to 5 km. A potential future site would push deeper, potentially to 10 km. “By 2035, we want the first superhot well producing energy at a depth greater than 10 kilometres,” says Houde, who thinks his company’s technology could transform any region into geothermal country. But there are still serious uncertainties. One is whether such deep wells can be kept open under the immense pressures found kilometres below ground. “It’s unclear whether that is possible,” warns Ellsworth. Houde accepts that the hardest engineering lies ahead. “I think it’s very viable for getting to these initial depths to prove superhot geothermal,” he says. “I think it’ll become increasingly more challenging to push the frontier on how deep we can go.” Iceland offers a glimpse of how these different strands of geothermal might converge. Instead of simply resting on its laurels as one of the world’s great geothermal success stories, the country is fast becoming a test bed for what comes next, says Magnúsdóttir. Its deepest geothermal well – the second well by the Iceland Deep Drilling Project, a consortium of the country’s leading energy companies and its energy authority – has already brushed against the promise of superhot geothermal. It was completed in 2017 and goes down 4.7 kilometres. “It is the first well in the world where supercritical conditions were confirmed in the geothermal well,” says Magnúsdóttir. Icelandic operators are also using EGS techniques to get more from existing fields, stimulating deeper faults to reach another kilometre or so of heat. Next year, the Iceland Deep Drilling Project plans to drill its third well. “There, they just have to go down to a little over 2 kilometres to reach supercritical conditions,” says Magnúsdóttir. But even at that relatively shallow depth, the engineering challenges remain fierce. The main problem is well integrity. At such high temperatures, the steel casings that line the well can expand, deform and fail. In Iceland, engineers have been testing fixes, including flexible connectors between sections of casing. This sort of engineering will be crucial if geothermal is to win over investors. Projects are expensive up front and slow to prove, and often need permits before developers know whether a site will work commercially. But the reward for patience can be unusually durable. “It’s very, very costly,” says Sanjeev Kumar at the European Geothermal Energy Council. “But once you’ve drilled that hole in the ground, that lasts for over 100 years.” That is the promise and the problem in miniature. “We know that very deep geothermal energy would be fabulous if we could reach it,” says Ellsworth. “We just don’t yet know if it’s possible.” 1
-rick- Posted Thursday at 14:54 Posted Thursday at 14:54 Seen stuff on the millimetre wave drilling technique before. Seems like a really cool technology. Glad to see they are still moving forward and don't appear to have hit showstopping issues yet.
Gus Potter Posted Thursday at 22:36 Posted Thursday at 22:36 8 hours ago, SteamyTea said: rth contains more than enough heat to power humanity many times over Interesting stuff, early technology, not to be ruled out. As an SE I've always been interested in rock mechanics. It's a fascinating subject, not bedtime reading for all mind.
MikeSharp01 Posted Friday at 06:05 Posted Friday at 06:05 While this is exciting stuff and I applaud the work being done I have not seen the counterveiling discussion around moving energy from the core to the surface and the consequences there of. If we cool the core what are the consequences? As I said this is exciting stuff but we should have learned by now that our use of planetary resources has consequences and geothermal energy may not be a 'renewable' resource. 1
saveasteading Posted Friday at 08:21 Posted Friday at 08:21 2km is a deep hole. That will be quite a pump that shifts water through it. I expect the microfissues , even the borehole will close up under pressure. So it interesting but a while away.
SteamyTea Posted Friday at 09:34 Author Posted Friday at 09:34 1 hour ago, saveasteading said: 2km is a deep hole. That will be quite a pump that shifts water through it. I expect the microfissues , even the borehole will close up under pressure. We currently have mines deeper than that. They will almost certainly have to pump out water. https://en.wikipedia.org/wiki/List_of_deepest_mines The UK has mines almost as deep. https://en.wikipedia.org/wiki/Boulby_Mine They probably could have mined deeper, but they stopped at the resource they were after.
-rick- Posted Friday at 10:46 Posted Friday at 10:46 4 hours ago, MikeSharp01 said: While this is exciting stuff and I applaud the work being done I have not seen the counterveiling discussion around moving energy from the core to the surface and the consequences there of. If we cool the core what are the consequences? As I said this is exciting stuff but we should have learned by now that our use of planetary resources has consequences and geothermal energy may not be a 'renewable' resource. I think I saw this discussed in the past. Iffy recall but I think the jist is that the amount of energy in the core is massive and any level of human extraction is likely inconsequential to that. More locally you obviously have similar problem to fracking in that if you disturb the local geology you may have water and other things going places they weren't before which may be problematic. The heat in the core is caused by rotation of the planet and is linked to orbital mechanics (IIRC). On those scales current human endeavour is almost nothing. The comparison is climate change where through our actions over 150/200 years we have made a meaningful difference in atmospheric concentrations of potent gases.
SteamyTea Posted Friday at 11:02 Author Posted Friday at 11:02 9 minutes ago, -rick- said: The heat in the core is caused by rotation of the planet and is linked to orbital mechanics (IIRC) A bit, most is radioactive decay There is some tidal warming. It is a bit strange to go to all this trouble when there are easier alternatives to develop. https://goexplorer.org/using-the-ocean-to-power-tropical-islands/ They spent, I think, £1.5m on the Jubilee Swimming Pool geothermal project. It failed and they put a heat pump in. Seems strange when they have a warm ocean literally 10 feet from it and a local firm that makes Water Source Heat Pumps. I am sure I could get an AI to write up a gushing proposition for just about any energy source, present it to some greedy, but ignorant, investors, and laugh.
saveasteading Posted Friday at 11:02 Posted Friday at 11:02 1 hour ago, SteamyTea said: mines deeper than that I have forgotten an awful lot. But I kind of remember that there is an absolute limit to the height of a pump, regardless of size. Because of the sheer head of water mostly. In a mine there is tunnelling and it could be done in stages.
-rick- Posted Friday at 11:05 Posted Friday at 11:05 (edited) 4 minutes ago, SteamyTea said: A bit, most is radioactive decay There is some tidal warming. That doesn't sound right to me. Got a source? I thought it was mostly caused by the effect of the moon compressing earth as it orbits. Like the moon causes tides, it causes relatively small changes in the earths shape as it orbits. This produces heat. Edit: Either way, our actions aren't going to affect either of these energy sources (at our current and foreseeable future demand) 4 minutes ago, SteamyTea said: It is a bit strange to go to all this trouble when there are easier alternatives to develop. https://goexplorer.org/using-the-ocean-to-power-tropical-islands/ I thought the main selling point of this millimetre wave stuff was that it would dramatically lower the cost of drilling and if their calculations held would end up cheaper than solar as a way of generating electricity. Edited Friday at 11:07 by -rick-
SteamyTea Posted Friday at 11:24 Author Posted Friday at 11:24 (edited) 18 minutes ago, -rick- said: That doesn't sound right to me. Got a source Which bit. Here is the radio active decay. https://en.wikipedia.org/wiki/Earth's_internal_heat_budget Here is the tidal heating. https://en.wikipedia.org/wiki/Tidal_heating About 0.0073 W/m2 most in the oceans, so not really relevant. All these thermal forcings are generally measured at the mW/m2 scale. As much as I line innovation and large engineering projects, we currently do not have time to wait for the Golden Goose. We need to crack on with Wind, Solar, Hydro, Storage and Demand Management. We have everything we need to do that, and have actually had it for the last 30 years. Edited Friday at 11:24 by SteamyTea 1
-rick- Posted Friday at 11:56 Posted Friday at 11:56 31 minutes ago, SteamyTea said: As much as I line innovation and large engineering projects, we currently do not have time to wait for the Golden Goose. We need to crack on with Wind, Solar, Hydro, Storage and Demand Management. We have everything we need to do that, and have actually had it for the last 30 years. 100% The worry with something like this is that the sceptics see this and start using it as a reason to not spend money now on existing solutions.
-rick- Posted Friday at 12:17 Posted Friday at 12:17 To add, one of the great potential use cases of a technology like this is if it works you could go to the site of an old coal/gas power plant. Drill a deep hole and then start using the heat to drive the existing turbines using the existing power lines. It has potential to be an excellent solution to base load. Again not something to wait for, but if it materialises in say 5 years as viable, then it could seriously reduce time to net zero for planet earth if it can be rolled out at scale. 1
SteamyTea Posted Friday at 13:07 Author Posted Friday at 13:07 Forgot about this on my doorstep. 3MW electric and some thermal. I think they are selling on the back of lithium extraction. https://gel.energy/about/united-downs/ https://www.bbc.co.uk/news/articles/cewzg77k721o
sgt_woulds Posted 10 hours ago Posted 10 hours ago On 24/07/2026 at 12:02, SteamyTea said: It is a bit strange to go to all this trouble when there are easier alternatives to develop. https://goexplorer.org/using-the-ocean-to-power-tropical-islands/ I remember this was a big thing in the mid 90's (when all the real interest / progress in renewables kicked off). But then? Nothing! Open cycle OTEC was the really interesting version since you didn't need working fluids such as ammonia; they claimed fluid based was closed loop, but there is no such thing in reality, so there would have been some leakage into the environment. As a plus, open cycle OTEC produces desalinated water as a by-product, and in the next few decade that will probably become as valuable as oil. You'd think the Saudis would jump on it.
sgt_woulds Posted 10 hours ago Posted 10 hours ago At the time I wondered if it be simpler / cheaper / more reliable to use a TEG (Seebeck device) instead. Power output would be extreemly low, but with no moving parts, maintenance costs would also be low with an almost unlimited lifecycle. At the time, TEG were very inneficient (I remember 3% for one back in the 90's using a depleted uranium heatsource). Have they improved since?
Post and beam Posted 10 hours ago Posted 10 hours ago On 23/07/2026 at 15:26, SteamyTea said: Scientists are scrambling to understand how climate change may be interfering with the winds that carry our weather, with potentially catastrophic consequences In the short term that this might be referring to there will not be more heat energy moving about the planet. So surely more heat in northern Europe means less heat somewhere else.
-rick- Posted 9 hours ago Posted 9 hours ago 46 minutes ago, sgt_woulds said: At the time, TEG were very inneficient (I remember 3% for one back in the 90's using a depleted uranium heatsource). Have they improved since? Not as far as I know. Want to do better you start needing to get into things like stirling engines.
SteamyTea Posted 6 hours ago Author Posted 6 hours ago 3 hours ago, -rick- said: stirling engines Efficiency = 1-Tcold/Thot So like any reciprocating engine, it is going to be pretty poor.
-rick- Posted 6 hours ago Posted 6 hours ago (edited) 10 minutes ago, SteamyTea said: Efficiency = 1-Tcold/Thot So like any reciprocating engine, it is going to be pretty poor. Almost any engine is an order of magnitude better than the seebeck effect. Edited 5 hours ago by -rick-
SteamyTea Posted 5 hours ago Author Posted 5 hours ago 6 minutes ago, -rick- said: seeback effect Yes.
DamonHD Posted 5 hours ago Posted 5 hours ago All heat engines are still limited by Carnot. I have a bunch of largish Seebeck devices in my shed never fitted. I was going to do solar thermal + Seebeck, but went big on solar PV instead.
SteamyTea Posted 4 hours ago Author Posted 4 hours ago 1 hour ago, DamonHD said: All heat engines are still limited by Carnot. Not sure, but I seem to remember that forced induction engines follow a different cycle. Not that it really matters in the above cases.
