I purchased 4.8m x 2.4m A242 mesh sheets without flying ends.  the way the sheets have to be laid means that there are some areas with 3 sheets overlapping. We are having a 150mm slab and the chairs raise the mesh 40mm off the bottom.  I don't suspect that it is an issue, but just wanted to check as I don't want BC failing the inspection on Thursday and then having a mad panic to try and come up with a solution to fix the problem.
If by
7 minutes ago, flanagaj said:
'without flying ends'
you mean the sheets have a rebar strip all round the perimeter why not just cut that off where 2 or more will overlap? If I have misunderstood your Q then I am sorry not to give you an answer!
This and other Qs suggest that good progress is ... progressing. You must be v pleased to be coming out of the ground now. Got any pics?
If there is only 1 layer you will be fine with the overlaps.  If you can get someone to help placement it would help a lot as the sheets are heavy and awkward.  You may want some tie wire where the sheets join and allow for a 300-400mm overlap (40x wire size).
I don't think I can start cutting sections out, as then it won't be connected to the other sheets.   I might ask building control to comment
What is going on top of the pour, we had 3 at some points like you, but our pour is 200 with insulation and screed on top.
So, if the concrete is a bit thin at points then it will be well covered.
600mm is the minimum overlap. Your BCO will fail if this is 300-400mm.
They got a tape measure out and checked the one I’m on now, so beware!
