Tim_C Posted Sunday at 16:15 Posted Sunday at 16:15 Hi everyone - I'm Tim Β Newbie selfbuilder here, in the early stages of planning our self-build project in South Wales (But currently living in Bristol). Looking to build a family home to passive house principles, and avoid any Grand-designs style crises during the process! Β Excited to be part of this forum, which is a great source of info! I look forward to picking your collective brain more as we make our design choices and progress with the project.Β 4
Dreadnaught Posted Sunday at 20:41 Posted Sunday at 20:41 Welcome. @NickfromwalesΒ comes from down the coast in Wales. 1 1
Nickfromwales Posted Sunday at 20:49 Posted Sunday at 20:49 4 hours ago, Tim_C said: Hi everyone - I'm Tim Β Newbie selfbuilder here, in the early stages of planning our self-build project in South Wales (But currently living in Bristol). Looking to build a family home to passive house principles, and avoid any Grand-designs style crises during the process! Β Excited to be part of this forum, which is a great source of info! I look forward to picking your collective brain more as we make our design choices and progress with the project.Β Hi and welcome. Β Glad you're not looking to bother with the PH cape and matching slippers, as you probably need to live 1.5x to get all that extra bother and cost back. Β Timberframe or ICF or other in mind?Β 1
Tim_C Posted Sunday at 21:54 Author Posted Sunday at 21:54 54 minutes ago, Nickfromwales said: Hi and welcome. Β Glad you're not looking to bother with the PH cape and matching slippers, as you probably need to live 1.5x to get all that extra bother and cost back. Β Timberframe or ICF or other in mind?Β Β Thanks for the Welcome! Β Potentially both Timberframe and ICF. Β The plot is sloping, so needs a lower ground floor which dug into the hilside and partially below ground level. Working assumption at the moment is a raft foundation, tanked ICF lower ground floor then timber frame 1st/2nd floor. Definitely would be interested to hear if anyone on the forum has experience of this, given it's less common.Β Β Β Β Β Β
Nickfromwales Posted Sunday at 22:03 Posted Sunday at 22:03 5 minutes ago, Tim_C said: Β Thanks for the Welcome! Β Potentially both Timberframe and ICF. Β The plot is sloping, so needs a lower ground floor which dug into the hillside and partially below ground level. Working assumption at the moment is a raft foundation, tanked ICF lower ground floor then timber frame 1st/2nd floor. Definitely would be interested to hear if anyone on the forum has experience of this, given it's less common.Β Β Quite a few on here have done basements by a 3rd party, and then plonked a TF atop, as most TF companies won't touch a basement (or anything sub / semi-subterranean) with a shitty stick. Β May be a lot simpler for you to go with ICF all the way, but with timber for posi joists / internal walls etc. One point of contact for responsibility / coordination / liability, reducing risk massively (and avoiding errors and the blame game). 1
saveasteading Posted Monday at 07:14 Posted Monday at 07:14 I've done a few buildings ( schools and factories) on steep slopes. My principle has been to build a platform at the higher level, then a conventional framed building on top. That keeps it simple and vastly more economical. No basement as you get into a different level of complexity and risk.( digging into the ground, waterproofing, stability, access) So that is conventional strip footings ans walls up to level . Then beam and block or precast planks make the surface. You are then out of the ground and on a solid surface. Β With a raft you have a big hole to dig then work in. If the slope is steep there is potential differential movement of the ground. Β If the slope is extreme then you can perhaps have a natural extra storey or part of one. Β Worth mentioning perhaps that in a couple of those jobs the original designers had assumed the dig and raft technique or retaining walls and mass fill to make a platform.Β I met one during negotiation and discussedΒ the principles, and he was simply surprised at the cost difference, not being a contractor. Β Beam and block then a conventional kit above is my suggestion. 1
JohnMo Posted Monday at 09:34 Posted Monday at 09:34 Our site is also sloping original plan was to build-up the front of house to level. In the end we moved the hill about to make a flat area for the house. Ended up way easier. Man with big digger for a few weeks was cheap enough. Or do as @saveasteadingΒ - basements and underground working no thanks. All the cost unknowns are below finished ground level, so avoid to much work there. Β Also we built from ICF - don't see any value adding a timber frame on top, just keep going with ICF.
saveasteading Posted Monday at 10:26 Posted Monday at 10:26 Of course it matters massively where your doors are, to walk out onto land or mid-air.
Mr Punter Posted Monday at 10:42 Posted Monday at 10:42 10 hours ago, Tim_C said: tanked ICF lower ground floor Β If you go with semi basement ICF you will need as a minimum type C waterproofing, which involves a profiled drainage sheet on the walls and floor, a drainage channel formed in the floor perimeter, a sump with a high level alarm end a pump.Β You alsoΒ have to consider where you locate insulation and how you deal with drainage.Β Warranty providers may suck air throughΒ their teeth. Β Far better, if the site allows, change the profile of the land and have your building above ground, even if you need some retaining structures in the garden / drive.
ToughButterCup Posted Monday at 11:06 Posted Monday at 11:06 Welcome. Β 13 hours ago, Tim_C said: ... The plot is sloping, so needs ... Β How much of a slope?Β A gentle slope is a massive advantage. 1 in 1 , not so much. We used about 2000 (ish)Β tonnes of MoT1 and other stuff ( dig-out from elsewhere) to make the raft sit 'comfortably'Β Β Β Tell us about your slope please! Β Ian
saveasteading Posted Monday at 12:13 Posted Monday at 12:13 2 hours ago, JohnMo said: Our site is also slopingΒ If I recall, you are on sand which is very free draining and not seasonally affected. It would be different on clay.
JohnMo Posted Monday at 12:28 Posted Monday at 12:28 13 minutes ago, saveasteading said: If I recall, you are on sand which is very free draining and not seasonally affected. It would be different on clay. You are correct. But either way wouldn't be doing a build part underground, if I had any other options. Too many variables to start costing you big money.
Tim_C Posted Monday at 18:57 Author Posted Monday at 18:57 7 hours ago, ToughButterCup said: Β How much of a slope?Β Β Β Slope is about 1 in 6 Β Appreciate everyone's comments. We're definitely striving for simplicity - doing more earthworks and building a beam&block platform to sit a TF on top definitely sounds appealing. We'll investigate!
Nickfromwales Posted Monday at 20:47 Posted Monday at 20:47 1 hour ago, Tim_C said:  Slope is about 1 in 6  Appreciate everyone's comments. We're definitely striving for simplicity - doing more earthworks and building a beam&block platform to sit a TF on top definitely sounds appealing. We'll investigate! If you go for a block and beam foundation then you'll need a clear perimeter all around the slab, to get the required cross ventilation. This may then provoke a retaining wall £££. 1
JohnMo Posted Monday at 20:52 Posted Monday at 20:52 1 hour ago, Tim_C said: Slope is about 1 in 6 That is pretty flat, our house is around 10m at the deepest and 7m for most of it. So that would be only 1.5m buildup at the most. Ours was a 1:1 slope.
Nickfromwales Posted Monday at 21:15 Posted Monday at 21:15 23 minutes ago, JohnMo said: That is pretty flat, our house is around 10m at the deepest and 7m for most of it. So that would be only 1.5m buildup at the most. Ours was a 1:1 slope. I'm just about to start a new build for a new client and the site was a bit of an odd-ball, with the rear left quarter needing 'attention' according to the geotechnical report, before we could build a raft and a new ICF structure atop. I made the call to drop grade by 500mm, with the added benefit of slightly higher internal ceiling heights but no affect on ridge height, which cured a problem with some beneficial side effects. Β Sometimes you can turn issues into advantages, so a sloping site doesn't always mean a headache!
