Spinny Posted 3 hours ago Posted 3 hours ago Our Bifold threshold is designed to provide a levelish threshold with 10-15mm upstand. On the inside it has a bevelled edge. In a perfect world the top of our LVT floor covering would meet the edge of the threshold bevel all along the 3.5m width. Our floor levelling is a little low and comes up about 7mm short of perfect. Our flooring guy did point out going for perfect might go wrong because the floor level may vary somewhat along the length of the threshold, and if too high at any point then look bad. The question now the floor is levelled is whether to have the floor feathered into the threshold to reduce the discrepency ? Flooring guy says he can feather the LVT up a bit along the threshold and inwards for 6 to 8 inches to reduce the discrepency. However it is possible that it might be noticeable in certain lights etc. Photo illustrates what he is talking about where the lower LVT planks illustrate the effect by raising the upper LVT planks (the ones we are using) by 2.5mm against the threshold in a similar manner to feathering. Anyone done this ? Can anyone advise ? What is the likelihood of this working well VS creating a worse eyesore ? (PS Levelled floor does generally undulate 2/3/4mm in places anyway)
JohnMo Posted 3 hours ago Posted 3 hours ago Maybe overthinking it, lay it, add a bead of sealant, you will never look at it again, neither will anyone else.
Spinny Posted 3 hours ago Author Posted 3 hours ago (edited) Yes Maybe, but 5-6mm seems like it could be a trip hazard, whereas 2.5-3mm would be safer as well as more aesthetically pleasing. Any experience of using feathering compound under LVT ? Looks like it can have LVT laid over after just 15 minutes...? https://youtu.be/Gp4qxdf6f9w?si=mgLwexHuuJtfTctM Edited 2 hours ago by Spinny
Temp Posted 2 hours ago Posted 2 hours ago We have a step of about 10mm into the main bathroom. It has a 5mm bevel on it. In 20 years I don't think anyone has tripped on it. 1
Nickfromwales Posted 29 minutes ago Posted 29 minutes ago 2 hours ago, Spinny said: Yes Maybe, but 5-6mm seems like it could be a trip hazard, whereas 2.5-3mm would be safer as well as more aesthetically pleasing. Any experience of using feathering compound under LVT ? Looks like it can have LVT laid over after just 15 minutes...? https://youtu.be/Gp4qxdf6f9w?si=mgLwexHuuJtfTctM 5-6mm is like 2 x £1 coins on their sides…… Go and take some time to recall stepping in and out of every other doorway of any person you’ve visited in the last 20 years, and then reply here with record of each instance where you tripped over 10, 20, or more mm of thresholds. The results will tell you to put the magnifying glass on Gumtree and rejoin the rest of the population.
