We're building a house that will have metal standing seam roof panels.
We want solar but I hate the ugly carbuncles that are fitted to some homes.
I like the idea of Flextron (bonded to the seamed roof panels in the factory).  I acknowledge the fact that they're probably not the most efficient but the fact that they're innocuous and flat against the roof is more important to me.
My only concern is if the bonding fails and/or inefficiencies increasing over time to the point of them not being productive.
Question:
Does anyone have experience of the Flextron system that would help inform my decision on their use?
Or, does anyone have an alternative for seamed roof installations that are low profile from a visual perspective?
Another thread on this last week - have actually looked a price? Shockingly expensive, not sure how you could ever justify PV going that route. Anything other than standard panels is really an expensive folly.
Ground mount and fence mount are other cost effective options
see current discussionSolar Gurus, please disect!
It's only fair to say that I am not a fan of SS.
Aesthetics? Yes if done very, very well.
Practicality, No.
Cost? I'm afraid they often get drawn on by a party who isn't paying or detailing.
Edited by saveasteading
Lack of space and being in a national park limit options somewhat but, given the opportunity yes I'd agree would be much easier/cheaper.
Seen that - thought this was a slightly different topic and didn't want to change the focus of that thread.
Roof was actually specified by us.  The whole build is going to be barn-like in appearance and, for our area, metal roofing is the more common solution.  The only other common option around here would be clay tiles and I'm no fan of those.
If your only option is stick panels at silly prices I wouldn't bother, just get a battery and that allows a TOU tariff and use cheap periods during the peak ones
We looked at that system, years ago now, and eventually decided against it. If the bonding fails (and it’ll get bloody hot up there) or the panels fail what could you actually do about it with the roof in situ?
Do you mean conventional panels? That’s what we went with in the end. Black PV panels mounted on the seams of a dark grey SS roof, looks nice IMO and no room for birds etc to get underneath the panels, but those panels hide a lot of expensive zinc.
If you’re going with SS and dead against conventional panels then I’d say @JohnMo’s advice is spot on. Get a big battery and TOU tariff.
My panels went up on my standing seam roof
i absolutely hated them, for a couple of weeks I considered removing them and not bothering with Solar at all, two years later I don’t even notice they are there.
people even ask if I have Solar and I have to point them out.
We looked at stick on panels and then decided against.
After the standing seam roof went up we couldn't bring ourselves to cover it with panels on the SW front of the house so installed panels only at the rear, where nobody will ever notice.  And some on the flat roof garage to catch some rays in the winter months.
For the standing seam roof we used the s-5 railess pvkit.  Neat enough for the back but, IMHO, too ugly for the front.
How slimline/innocuous are yours?  Do you have a photo?
One of my key concerns is the panels will be on the car port (which is integrated into the house roof) which means that they will be front and centre to anyone approaching the house.
So, I want them to be as innocuous as possible.  I could accept something very slim and low profile but clunky panels stuck on with half a Lego set would be a big no-no.
Just embrace them, make them a feature. Be proud to be doing your bit for your pocket first and the environment second.
Nothing wrong with panels on show. In six month time you will going out to see they are still there, because you and no one else really sees them.
  • Like 3
I say: Embrace the reality of structure. The ribs are about 35mm and add a lot of strength.
I guess we could use 140mm thick composite without the ribs, but nobody does.
See right hand ribbed roof. The rest is slate.
Slimline, I guess so.
Innocuous, I’d say not.
ours look over the back garden and can’t really be seen easily from anywhere.
This is from a few years ago when everything was fresh, clean and unfinished.
Sadly ours will be on the front but, I have to say, your setup looks much more dicrete than many.
Have you had to take any anti-bird/nesting measures?
No, the panels pretty much sit on the standing seams using the S5 clamps that @Mr Blobby mentioned. There is no space underneath for birds.
That's entirely personal taste. An ancient lead or zinc roof looks much the same.
Here's ours being installed.  @Russdl's look way smarter and low profile, perhaps because of the distance from the ground.
You can see the clamps being installed, they have a disk that sits 15mm above the seam.  We've had no issue with birds trying to go underneath.
I wish I could have fitted three rows of panels on that South facing elevation 😕
I reckon it’s identical and as you say the distance from the ground that the photo is taken makes it look different. Not much though, smart set up.
I think I would have been happy to pay for additional pv to roof connectors so that there was one on each standing seam (as with @Russdl's setup).  The asymetry od skipping one seam would have my OCD twitching every time I looked at them!
I actually powder coated my clamps to be the same colour as the roof 🤪 but not sure it achieved much 🫤
My standing seam is at 400 instead of 600 centres, to reduce canning, something else for you to think about 🤔
Edited by Mr Blobby
I see you have shiny ridge clamps. We had this also, the roofer had ordered cheaper ridge kit than vmzinc that came in ral 7016 but the coating came off.  The roofer agreed to go up on the ridge and shape a peice of roof material to cover the brackets and looks well.
