Definitely not normal. If it's plasterboard then the joins should be away from any edges but that's what it looks like for me.
When I first plasterboarded my front room I just stopped the board at the "easiest point" and guess what, cracked at all these places a year later. Maybe that's what's happened?
For what is worth, since then I've cut my boards to keep away from any edges and it's been rock solid.
3 hours ago, Russell griffiths said:
Thermalite blocks by any chance ?
No, dense block.  Approx 10 mm mortar under the skim coat.  Plastered over the winter, internal temps never went below 10 degrees.  Dried out very slowly, no excess heat or dehumidifiers.  Took a few months for the cracks to develop, but are not along mortar lines, and given the house is on a Kore slab on hard rock underneath then I don't think this is any subsidence issue.
So when you say all the openings are the same, do they all have a crack running down from the bottom left / right edge to the floor?  Nothing at the top?  Ground and first floor?
