flanagaj Posted 3 hours ago Posted 3 hours ago I have been putting in foul drainage this week and now need to put the conduit in for the 2 * 23 KVa cables that will come under the lintels and into the plant room. I do have a 54mm diameter hockey stick and was wondering whether to just put two of those in, or am I better off using another type of conduit? Thanks
Nickfromwales Posted 2 hours ago Posted 2 hours ago 22 minutes ago, flanagaj said: I have been putting in foul drainage this week and now need to put the conduit in for the 2 * 23 KVa cables that will come under the lintels and into the plant room. I do have a 54mm diameter hockey stick and was wondering whether to just put two of those in, or am I better off using another type of conduit? Thanks Ok, so we need cable sizes, eg outside diameter, to comment. What are these cables for?
flanagaj Posted 2 hours ago Author Posted 2 hours ago 32 minutes ago, Nickfromwales said: Ok, so we need cable sizes, eg outside diameter, to comment. What are these cables for? 25mm2 The cable will be from the meter to the CU in the house.
Nickfromwales Posted 1 hour ago Posted 1 hour ago 1 hour ago, flanagaj said: the 2 * 23 KVa cables Singular or plural, squire? 100mm duct is the easiest, as you only need a hockey stick when outside afaik. 2 will come up that with ease.
Onoff Posted 1 hour ago Posted 1 hour ago I brought 63/50mm flexible conduit into the house from the garage recently. Inside that is a 16mm² SWA along with two 20mm flexible conduits for data etc. With hindsight I should have gone for 100mm especially as I'm now considering another EV charger. I was mind (still am) tight for money so the 63/50mm came off FB marketplace cheap. Ah well!
