Electrical conduit for bringing armoured cable into house?
I have been putting in foul drainage this week and now need to put the conduit in for the 2 * 23 KVa cables that will come under the lintels and into the plant room.  I do have a 54mm diameter hockey stick and was wondering whether to just put two of those in, or am I better off using another type of conduit?
Thanks
Thanks
Ok, so we need cable sizes, eg outside diameter, to comment.
What are these cables for?
25mm2
The cable will be from the meter to the CU in the house.
I brought 63/50mm flexible conduit into the house from the garage recently. Inside that is a 16mm² SWA along with two 20mm flexible conduits for data etc. With hindsight I should have gone for 100mm especially as I'm now considering another EV charger. I was mind (still am) tight for money so the 63/50mm came off FB marketplace cheap.
Ah well!
With regards to the 100mm ducting.  Do you simply just put a bend in it or do you buy a preformed smooth bore bend?  If such a thing exists.
Where we are, if you don't have the right ducting the DNO (UKPN) won't run the cable.  They will tell you what they need.
Just re read and I see this is your side of the meter, so 100mm rigid duct will be OK.
Edited by Mr Punter
Just observe a reasonable bending radius and it’ll be fine. Stopping and starting with fittings causes a snag, so one continuous piece, joints in a perfectly straight section only, if needed, and get a 6mm nylon draw rope in it when you lay it.
