flanagaj Posted 2 hours ago Posted 2 hours ago I have been putting in foul drainage this week and now need to put the conduit in for the 2 * 23 KVa cables that will come under the lintels and into the plant room. I do have a 54mm diameter hockey stick and was wondering whether to just put two of those in, or am I better off using another type of conduit? Thanks
Nickfromwales Posted 1 hour ago Posted 1 hour ago 22 minutes ago, flanagaj said: I have been putting in foul drainage this week and now need to put the conduit in for the 2 * 23 KVa cables that will come under the lintels and into the plant room. I do have a 54mm diameter hockey stick and was wondering whether to just put two of those in, or am I better off using another type of conduit? Thanks Ok, so we need cable sizes, eg outside diameter, to comment. What are these cables for?
flanagaj Posted 1 hour ago Author Posted 1 hour ago 32 minutes ago, Nickfromwales said: Ok, so we need cable sizes, eg outside diameter, to comment. What are these cables for? 25mm2 The cable will be from the meter to the CU in the house.
Nickfromwales Posted 44 minutes ago Posted 44 minutes ago 1 hour ago, flanagaj said: the 2 * 23 KVa cables Singular or plural, squire? 100mm duct is the easiest, as you only need a hockey stick when outside afaik. 2 will come up that with ease.
Onoff Posted 20 minutes ago Posted 20 minutes ago I brought 63/50mm flexible conduit into the house from the garage recently. Inside that is a 16mm² SWA along with two 20mm flexible conduits for data etc. With hindsight I should have gone for 100mm especially as I'm now considering another EV charger. I was mind (still am) tight for money so the 63/50mm came off FB marketplace cheap. Ah well!
