Bancroft Posted June 1 Posted June 1 I noticed this wind turbine the other day (outlined against the solar panels) on the edge of a new development. Surprised for two reasons: First, will it actually achieve anything meaningful? It's quite low and surrounded by houses and some high trees to the south west (where prevailing winds come from). How/why has the local planning department agreed to it? It doesn't seem to fit the criteria required for personal wind turbines, even permitted development rights.
JohnMo Posted June 1 Posted June 1 9 minutes ago, Bancroft said: First, will it actually achieve anything meaningful No, not high enough to mitigate wind disturbance 10 minutes ago, Bancroft said: How/why has the local planning department agreed to it? It doesn't seem to fit the criteria required for personal wind turbines, even permitted development rights. Would they have applied?
saveasteading Posted June 1 Posted June 1 It appears to be on a pole along with a small solar panel. It likely powers a street light which illuminates the adjacent footpath. 1
SteamyTea Posted June 1 Posted June 1 1 hour ago, saveasteading said: likely powers a street light which illuminates the adjacent footpath I would sell them to the council. Could save them £1000s on each sale. Probably where the myths that renewables are expensive, and don't work, comes from.
saveasteading Posted June 1 Posted June 1 @SteamyTea I'm not grasping your meaning. I noticed in Spain that all new street lights appear to be solar. At first it seemed to be on commercial estate but now on dual carriageways. The weather helps of course. Must be much cheaper to install than mains, with no trench or cable.
SteamyTea Posted June 1 Posted June 1 4 minutes ago, saveasteading said: I'm not grasping your meaning. Local Authorities have no idea what things should cost, so selling them a £300 wind turbine made for a boat, a fifty quid PV panel, a small battery system for say £500 and a person to put it all together, should probably be about £1000. Councils will probably pay 5 to 6 times that amount. Then, where there is a meeting to fit renewables to council buildings, someone in accounts, will drag out the £5000/kW number and say 'it is too expensive'. 3
saveasteading Posted June 2 Posted June 2 12 hours ago, SteamyTea said: Local Authorities have no idea what things should cost, It will have been an external consultant, or the developer's designer but the same will apply.
Conor Posted June 2 Posted June 2 It's likely powering a device that doesn't have a mains connection - e.g. logger/telemetry system on a utility, LED sign etc etc. Often these units are cheaper than getting a connection to the mains. Also, if there are road opening embargoes, like you would in a new development, there might not be the option to make a connection. 1
sgt_woulds Posted June 3 Posted June 3 It's a street lamp. You can see the lamp above the solar panel (maybe it is self powering at night 🙂) 1
saveasteading Posted June 3 Posted June 3 1 hour ago, sgt_woulds said: maybe it is self powering at night Great idea, the lamp charges the solar panel.
SteamyTea Posted June 3 Posted June 3 1 hour ago, saveasteading said: Great idea, the lamp charges the solar panel. Only if the light emits between 24.25 GHz to 71.0 GHz.
Bancroft Posted June 4 Author Posted June 4 On 01/06/2026 at 16:46, saveasteading said: It appears to be on a pole along with a small solar panel. It likely powers a street light which illuminates the adjacent footpath. Interesting, I wonder if the people putting these up have to comply with the same building regs requirements as a home owner would? Or will it be different because it's the Council so normal rules don't apply...
sgt_woulds Posted June 4 Posted June 4 What building regs requirements would apply to a lampost on a public throughfare?
sgt_woulds Posted June 4 Posted June 4 I remember a billion years ago there was a requirement for 5m distance from ground to blade tip (and from any windows) for building mounted units. Not sure about free standing rules. This will only be 3-400 watt max turbine. Noise will be zero unless you stand right under it.
scottishjohn Posted 7 hours ago Posted 7 hours ago I have been looking at this seriously recently the conclusion is unless you can spend 70k or more on one its a total waste of time although they say these cheap vertical units they are rated at 5kw /10kw -- that is maximum theoretical output before any losses etc and you need to be in winds of 25mph + to get close to that and then the cost of a suitable mounting pole and foundation most of these small units you will be lucky to ever get more than 1kw from them -and do we believe the life span - I do not--its basically an electric motor on its back spinning 24/7 so I have decided better to have some more ground mounted solar panels up in the high level waste garden If I do anything --which will face south-separate invertor coupled to my 17.5kw battery stack as my main array on the roof faces S/w and get little output once you get later in the year because of lower sun angle and little till late morning -- but once the sun gets at them -- i can see 11kw+ so the idea is to fill in the morning and as they face south will also carry on all day another 5kw of panels -- still waiting on costs to make final decision but although I have lots of wind it would never pay back in my life time with a smaller wind turbine so for anyone not in a very windy position it will never work 2
