ab12 Posted yesterday at 10:54 Posted yesterday at 10:54 Having UFH for 3 rooms: a kitchen , a bathroom and a living room. In the bathroom I will be having a walk in shower in the shape of a rectangular box dimensions 165cm long and 90 cm wide but without a shower tray. Worried shower trays break easily and also I think it will more cost effective to create the falls needed in the shower area with dry screed. On one of the longer sides will be a fixed glass screen running from external wall with a gap to walk into the shower space and on the opposite side is the internal wall. Shower head and taps will be affixed to external wall on one of the shorter sides of the rectangular box- see diagram attached I will make a small rectangular partition in the floor where the shower space will be if I use wet screed so can get the falls for the drainage. Floors will be finished with tiles. I am in 2 minds about Dry vs Wet screed. Dry Screed will be cheaper but a bit more laborious which I don't mind. Wet will off course be a quicker install but cost premium attached. For Dry I will go with 75mm thickness and for Wet I think the recommended is 60 -65mm thickness. Considering it's a DIY project which screed finish would you opt for? Are both types of screed equally effective for UFH in terms getting the space warmed up quickly and avoiding cold spots?. I suppose the thicker the screed the more time the slab will take to warm up but equally I suppose the more time that heat will be stored in the slab. BTW I have no prior experience with living with UFH so not sure about which direction to proceed.
JohnMo Posted yesterday at 11:30 Posted yesterday at 11:30 (edited) 57 minutes ago, ab12 said: Are both types of screed equally effective for UFH in terms getting the space warmed up quickly and avoiding cold spots?. Both will be equally slow, which is the whole idea of UFH. Unlikely to be any cold spots - but a floor well put together isn't hot either. Many because most if not all the time it's actually cooler than your body so will never feel hot. I assume you have thought about and installed plenty of insulation under the UFH pipes? Edited yesterday at 11:53 by JohnMo 1
ab12 Posted yesterday at 11:56 Author Posted yesterday at 11:56 14 minutes ago, JohnMo said: Both will be equally slow, which is the whole idea of UFH. Unlikely to be any cold spots - but a floor well out together isn't hot either. Many because most if not all the time it's actually cooler than your body so will never feel hot. I assume you have thought about and installed plenty of insulation under the UFH pipes? In terms of insulation I will putting 150mm PIR even though 100mm will suffice. Going with the extra insulation hopefully should be better. Initially though plan was to fit 100mm and so I purchased most of the boards already. Now have changed mind and will be ordering the 50mm boards. So I will be laying 50mm PIR first and them 100mm on top. In hindsight I should have ordered 150mm board. Other option is to use use 50mm Polystyrene such as Jabalit and then 100mm PIR on top- Cheaper option. Watched a you tube video about this and learnt the following: Polystyrene boards break easily and can be a bit more tricky to cut but I don't have prior experience so basing everything on what I saw in the video. Have you worked with Jabalite? Is it fairly easy to work with?
JohnMo Posted yesterday at 12:14 Posted yesterday at 12:14 14 minutes ago, ab12 said: I will be laying 50mm PIR first and them 100mm on top. In hindsight I should have ordered 150mm board. Good - go with 150mm. But stuck with 100 and 50mm. 150mm are a pain to install well. Stick with PIR at that depth. You 50% more depth of polystyrene boards for the same U value as PIR. A blunt saw is good for cutting PIR. Foam in any gaps. Stagger joints between layers 1
Nickfromwales Posted yesterday at 12:25 Posted yesterday at 12:25 1 hour ago, ab12 said: Worried shower trays break easily and also I think it will more cost effective to create the falls needed in the shower area with dry screed. It requires a methodical approach, and a lot of careful execution. Shower trays don’t typically break easily, more like mechanical damage or accidental dropping of things onto them. If you’re not having a shower tray then maybe consider a wet room former? You just set this in place with tile adhesive, test the drain for leaks, then screed to it. 1
saveasteading Posted yesterday at 13:34 Posted yesterday at 13:34 1 hour ago, ab12 said: should have ordered 150mm board But laying 2 layers allows the staggering of joints. Having recently done 2 layers I'd be thinking of having the thinner layer below, as the top one will be stiffer to resist bending under load (if there are any voids). Jablite is much softer and the saw doesn't get stuck in thck boards. But for 50mm of either, a saw is fine. Both are easy with a machine. We had a contractor do the floor. He used a recip. saw and long blade. Fast but approximate. I've been doing some wall stud infilling. It's a pain. I'm using a jigsaw with 4" blade which only cuts 2". Then repeat other side.. so is slow. With a long blade it wanders wildly. I think ideally with pir I would cut first with a jigsaw then complete the cut with a recip. Also, eps makes lots of dust, pir much less but nasty and needs a mask. Another option.. pir has aluminium foil on both faces. It cuts by stanley knife and so for 50mm you can cut both faces and get a snap-off cut... and it ux marked in 100mm squares. Yes eps snaps rather roughly. 1
saveasteading Posted yesterday at 15:20 Posted yesterday at 15:20 also of note. I have been a hater of expanding foam for years as it is used freely to hide bodges. But Soudal with a gun is another matter as there is control of quantity to some extent, and the nozzle can be extended into voids. BUT NB it acts as a solvent with EPS so must be used with caution. I have learned to squirt in a small amount as adhesive, then a sparing amount, then a 'top coat'. Not fast but a proper job 1
Russell griffiths Posted yesterday at 15:53 Posted yesterday at 15:53 You say diy project does that mean you are laying the screed, what sort of area do you have.
saveasteading Posted yesterday at 15:56 Posted yesterday at 15:56 Continuing this drift from the original question. We have had a difference of opinion with the BCO. Any advice will help, either technical or to my behaviour. I am personally infilling between timber studs at an isolated area where the architecture requires that we add some insulation. 50mm of rockwool would meet the numbers required. Because we have some 150mm eps and pir left from the floor works, I am using that. Obv this far exceeds the requirement. I wasn't there during the routine inspection, maybe as well. BCO isn't happy to see different materials being used. There is PIR and EPS, and even that looks like different products because batches have different amounts of the black specks from graphite additives. He also doesn't like where I have used 2 or more pieces butted within a section of wall. It is all sealed at edges and any joints with aluminium tape. Why have I used more than one piece? Economy and avoidance of waste. Sometimes because there is a nail sticking out so I've cut it for ease of adjustment, or there is a pipe behind and I have used 2 pieces, cut for exactness. And some are where eps has snapped, as mentioned above.... I have used it but taped the junction. In family discussion I suggested we tell him where to go / ask him on what grounds there is any suggestion of a problem / submit proof that this exceeds regs / sign it that I have a degree in Building Science. Pragmatically we are avoiding a row as it isn't worth it. So I've gone back to address the worst and there actually isn't anything that bothers me. I saw one panel where I'd used 3 bits so decided to pull that out and redo. Then I saw why I had done it. The sparky had inserted a noggin so I had pushed what I could down the back of that, in 2 bits to get a good fit. Then I had done the front, with a gap at the noggin but used eps and pir. The boards are so well fitted that one won't come out So I decided to reduce the quality to please the man. I've cut 30mm off one of the blocks, but 30mm off it and joints and placed 25mm board over for better aesthetic effect. Lowering standards to get approval... Grrrrrr. I'm thinking of peeling the aluminium face off PIR and gluing it over any panels with joints. But no, I will not lower myself to that. Thanks I feel a bit better now. we have had a difference of opinion with the 1
Nickfromwales Posted 17 hours ago Posted 17 hours ago 8 hours ago, saveasteading said: In family discussion I suggested we tell him where to go / ask him on what grounds there is any suggestion of a problem / submit proof that this exceeds regs / sign it that I have a degree in Building Science. He would have been reversing his wanker-mobile out of the driveway at max power if he said this to me. What a dickhead!!!!!!!!! 8 hours ago, saveasteading said: Pragmatically we are avoiding a row as it isn't worth it. I think you are saying you fear the repercussions....? I once pulled one private BCO aside at a job on a sizeable and TV-famous site in Oxford, and told him directly that I would recommend the clients sue him for the expense of his unwarranted and bullshit 'frivolities'......... He left, and was immediately replaced with a higher 'partner'. He subsequently got the same "feck you" as his protégé. The clients were terrified they would then get 'repercussions', and I said it would be fine. It was fine. 2 2
saveasteading Posted 9 hours ago Posted 9 hours ago 7 hours ago, Nickfromwales said: fear the repercussions....? Fear is too strong. But I want him to visit again in a good frame of mind. Who knows what he might want proof of, at cost of much time , maybe some fee. The green bit of the regs is ' do a good job' and the rest is suggestions and interpretation. So I will show willing (do a bit), take a flattering photo and then membrane over it. It's a much better job than most he will see and walk past. Eg when I've cut the insulation to just the right shape and it needs to be hammered in with stud offcuts as spreaders...... then it won't come out again for certain. He will have walked past plenty of undersized, maybe underthickness, boards with expanding foam.
ab12 Posted 4 hours ago Author Posted 4 hours ago 21 hours ago, Russell griffiths said: You say diy project does that mean you are laying the screed, what sort of area do you have. All together 3 areas to cover: Area 1 approx 18m2 Area 2 approx 10m2 Area 3 approx 13m2 I was think of laying dry screed with help of about 2 or 3 labourers who will muck in do the screeding. Idea was to order ready made dry screed and levels it off. Off course liquid screed will be much quicker fix but I'm pretty sure there will be a cost differential but I dont know exactly how much. UFH installer recommended WET screed mainly because he feels it is slef levelling and you can get a more level finsih. Personally I think you should be able to get a decent finish with Dry screed aswell
Nickfromwales Posted 3 hours ago Posted 3 hours ago 58 minutes ago, ab12 said: All together 3 areas to cover: Area 1 approx 18m2 Area 2 approx 10m2 Area 3 approx 13m2 I was think of laying dry screed with help of about 2 or 3 labourers who will muck in do the screeding. Idea was to order ready made dry screed and levels it off. Off course liquid screed will be much quicker fix but I'm pretty sure there will be a cost differential but I dont know exactly how much. UFH installer recommended WET screed mainly because he feels it is slef levelling and you can get a more level finsih. Personally I think you should be able to get a decent finish with Dry screed aswell My mate (screeder) and his boys lay dry screed as good as liquid, often better. You can almost paint the floor after he’s done his bit. Benefit of dry screed is placement, as it stays where you ‘put’ it, whereas leveller or liquids want to equalise across the area. If you have multiple different openings this can be of benefit if they're not all matching perfectly.
