saveasteading Posted 6 hours ago Posted 6 hours ago We have a lot of floor tiling to do. A recommended tiler says we "really should" have a decoupling membrane. I can't see any evidence that this isn't just an extra earner or " what most people recommend". The stated reasons online are. 1. Peace of mind. For the tiler or me? 2. Waterproof layer. no need. 3. Allows for settlement of the building. It's all on an existing industrial slab, 30 years in use. 4. a) Allows for shrinkage of slab. Ditto b) Allows for expansion and shrinkage and drying of screed. 40mm screed is already cured and isn't going to expand or contract . 5. Allows for thermal movement due to underfloor heating. I don't see that as significant. Any cracks are microscopic. 6. Ideal for Large Format Tiles – Enhances stability and strength. What difference does size make apart from the cost of big tiles? 7. Esp important with ufh due to heating and cooling cycles. I don't see 30 degrees as extreme 8. Enhances strength. I'd think the opposite is the case. To snap a tile it is bridged over soft material and point loaded. A tile cutter doesn't work with the tile flat on a solid base. So if i drop a pot I want the tile to stay solid, not deflect. My other cons. A. £7/M2 or more, plus waste, plus labour. B. We end up with a 10 To 20mm skin of ceramic, barely stuck down or restrained. C. The decoupler works both ways, and could encourage vertical movement under loads, eg table legs, and the grand piano. D. Even if the slab was poor quality, what is that membrane actually doing? Allowing the slab to move but leaving the tiles exactly where they are? I can't see it. E. The membrane acts as insulation on the wrong side. I've looked hard for any evidence and all I can find is that it is normal. Perhaps in a new build of questionable quality it is wise, and for small areas the cost seems relatively minor. I've currently got an old house with poor quality concrete floors. Large expanses of tile have lasted 15 years so far. Lucky again? And a holiday home abroad with lots of tiles on concrete. The only cracks are where I've dropped a log. I should explain. The project in question has 175 reinforced slab on dpm on stone, 30 years industrial use. Then 300mm eps and pir, and dpm. Then 40 to 50 poured screed with ufh. But I wouldn't be asking if I would not welcome opposing views or evidence. Any comments?
Nickfromwales Posted 5 hours ago Posted 5 hours ago The only concern is 40mm of screed is as thin as it gets. That is the only reason I would suggest decoupling here. 1
saveasteading Posted 4 hours ago Author Posted 4 hours ago 40 minutes ago, Nickfromwales said: I would suggest decoupling If you could expand the logic, or instinct, please? At nil screed of course it would be impossible to tile: at 100mm you appear to agree with my logic. I have some hunch that there is a purpose for membrane at 40 /50mm but I can't grab the logic out of my head. Btw we will have 200m2 of tile (the rest timber laminate) so, at say £10/m2 plus any labour implications, it is a big cost. We're doing well on tile costs so to then add back 1/3 "for peace of mind" wrankles.
G and J Posted 4 hours ago Posted 4 hours ago We"ve literally just had 88m2 of 1200 x 600 tiles laid by an very experienced (read older just like us!) on 100mm screed, which was laid early dec 25 and has been heated by the ufh Has been laid on a decouplinging mat as recommended by the supplier, whther we needed to is perhaps questionable as in the tilers view slab "would have cracked by now if it was going to". However having it allows more peace of mind (for all of us) in not having room thresholds, especially given size of tiles, and allowed a slight overlap (75mm) of the expansion strip in the screed, which then facilitated cuts working out to give best aesthetics.. In the end our view was they are not coming up again in our lifetime (we hope!) so in the scheme of things.......bit of a slipoery slope cost control wise, but we're at that stage of the build to better understand spend. 1
saveasteading Posted 4 hours ago Author Posted 4 hours ago 12 minutes ago, G and J said: allowed a slight overlap (75mm) of the expansion strip in the screed That's another thing that some trades-people "just do". Screed and slabs indoors do not expand. They may benefit from contraction joints/crack inducers but that is for tidy cracks as opposed to random ones.
G and J Posted 4 hours ago Posted 4 hours ago 8 minutes ago, saveasteading said: That's another thing that some trades-people "just do" Agreed, in this case at a very specific point allowing for the steels/load points but also allowed the screeder (traditional dry screed) to go home for the night! 1
saveasteading Posted 3 hours ago Author Posted 3 hours ago (edited) 43 minutes ago, G and J said: allowed the screeder (traditional dry screed) to go home for the night That's a " day joint". Not a bad idea though to put a factory edge to work to. As compared to a piece of 4x2. Edited 3 hours ago by saveasteading
